How to upload photos to a post?
    May 2003
Posted by Terry Bishop on Wednesday, January 29, 2014 5:56 PM
I want to upload several photos of my recently completed HK Model's 1/32 scale B-17, and planned to add a short paragraph about my experiences building it.   There's a green-colored button for uploading images, but
    August 2007
Posted by DUSTER on Thursday, January 30, 2014 10:03 AM
Sounds interesting.
re: photos; First get a Photobucket or any other free to use image carrier account.  Load your pictures to that site. Copy that sites direct  image link .
Then on FSM use the rich text format to open your post. Write whatever  and insert your photos where you wish using that  green "insert image" button-  the photo will appear at the location of you blinking cursor.
HTH
Steve
    March 2012
Posted by Rdutnell on Friday, March 7, 2014 3:35 PM
This doesn't work Duster.  I do it, but instead of showing the photo it shows the address, for example:
http://i1352.photobucket.com/albums/q659/rdutnell/Luscombe%20Silvaire%208A%20-%201-144%20scale/luscombe-LSA8-AOPAExpo-1106a_zps277faa2d.jpg
    March 2012
Posted by Rdutnell on Friday, March 7, 2014 3:40 PM
Sorry Duster, I misread what you said.  What I'm looking for is a way to put multiple pix in without having to do them one by one? In some Forums you can copy the IMG text copied from Photobucket but it doesn't seem to work here.
Posted by Texgunner on Friday, March 7, 2014 3:51 PM
I'll give it a shot, at least I'll explain how I do it. First, start an account at a photo-hosting site; I use Photobucket. Then, upload your pics that you've saved to your computer. After they are uploaded, you'll see the thumbnail pics.
Move your cursor over the pic and you'll see a little gear symbol in the upper-right corner. A drop down menu appears and you choose "get links". Another window will open with several choices for you. You want to click on the one that says "IMG codes". Once you do, it will show "copied". Now, go to the post that you've started here and simply "paste" the code. Do it over again and again and post all ya want!
I hope that helps!
Gary
"All you mugs need to get busy building, and post pics!"
    March 2012
Posted by Rdutnell on Friday, March 7, 2014 3:56 PM
I just tried that in the Test forum with no luck
    March 2012
Posted by Rdutnell on Friday, March 7, 2014 3:59 PM
Well now it worked.  Hmmm.  I did the same thing 15 minutes ago and it didn't.
Thanks
Posted by Don Stauffer on Saturday, March 8, 2014 9:36 AM
I have had trouble with multiple images.  It seems like it is hard to move the cursor down a line after an image frame is in place.  What I have found that seems to work is to add several carriage returns, then move back up to where you want to insert first pic. Now, it will be easier to move cursor down below a frame. If you are putting in a LOT of pix, put in a lot of CRs.
    March 2012
Posted by Rdutnell on Saturday, March 8, 2014 3:58 PM
Thanks Don,
I haven't had problems doing multiple images if I do them one at a time.  What I want to do, and do on other Forums, is do my write up in Word, copying the IMG codes into the Word document as I go.  Then when I am finished, I select the entire document and copy/paste it in to my reply, and the pictures are shown in the post.
As I say, it didn't work in the Test site, then it did.  However, I formatted a file like that for somebody else, less versed in computers, and the result is that you can get the pix only by clicking on them.  They are not imbedded in the post.
