Painting question
    July 2010
Painting question
Posted by 82ndmedic on Monday, August 2, 2010 9:00 PM
First question on the forum for me and all answers are very much appreciated. I just finished painting the final coat on a Kublwagen painted in Tamiya acrylic xf60 dark yellow. My next plan is to use a SIN filter on that coat  After that I am not sure what to do? I want a Afrka Korp look for this one.
I have never weathered a model before and II would like to try a pin wash or dry brush with enamels or oils. I have some pigments and a few enamels. I believe I have to lay down a protective layer on the Tamiya acrylic final coat before washes, oils and enamels.
Will the filter be good enough protection? Some people use Future floor wax. Do I use a varnish? I have some Tamiya clear acrylic.
Not sure what to put on top of brushed on Tamiya xf60 acrylic final coat and filter. What do I use to cover surface before oils, enamels and washes?
Remember I can't use air brush and everything is brushed on. What about large areas to cover? If it is varnish , do I dilute it? Thanks everyone! I am sure the answer is here already in past posts but it seems everybody uses airbrushes now. Take care Dave
    July 2014
Posted by batai37 on Monday, August 2, 2010 9:05 PM
You would probably have a better chance at a response if you posted this in Techniques or the Painting & Airbushing forums. This forum is specifically for help using the forums.
    July 2010
Posted by 82ndmedic on Tuesday, August 3, 2010 10:43 AM
Sorry about that, new guy.Thanks.
