Upload Photo Test
    December 2011
Upload Photo Test
Posted by model make on Saturday, September 17, 2016 8:35 AM
Modelers
Do you use insert image?
How do you browse to where your image is?
Thanks!
    December 2011
Posted by model make on Saturday, September 17, 2016 2:17 PM
    December 2011
Posted by model make on Tuesday, November 8, 2016 7:50 PM
    November 2016
Posted by Harrytheheid on Monday, November 14, 2016 1:03 PM
Hi,
I've just joined the FSM forum and used the "insert image" function in my initial two posts -- it didn't work, although that's probably down to me being unfamiliar with the insert command and using it incorrectly. I normally use Photobucket, so I went back and edited both initial posts using the PB "Share" command and then copied & pasted the IMG option into the text I'd previously posted. That worked fine, example shown below.
Hope this helps.
