Replacing brake cylinder diaphragms on Renwal Visible Auto Chassis Model
    February 2018
Posted by renwal rob on Friday, February 16, 2018 4:22 AM
I'm new to this forum, but have been building models for many years, and I'm particularly fond of the large 1/4 scale Renwal visible engine series. I'm currently stumped by the brake cylinder in my Visible Auto Chassis. The kit I purchased must have been exposed to heat, because the little balloons that are supposed to act as diaphragms in the cylinder were all fused together and unusable. Does anyone out there have some advice or a recommendation for replacing these diaphragms so that my brake cylinder works?
    January 2015
Posted by PFJN on Friday, February 16, 2018 10:05 AM
Hi,
Sorry that I don't have any input to help with your problem, but welcome to the forum, and I am looking forward to seeing how your 1/4 chasis turns out.  Ever since I heard of that kit I have been fascinated by it, but have never seen many pictures of it. Smile
Pat
1st Group BuildSP
Posted by Tojo72 on Friday, February 16, 2018 10:15 AM
Hello and welcome to the forums. Try the Auto section,maybe more lookers.
    September 2012
Posted by GMorrison on Friday, February 16, 2018 10:29 AM
There's quite a market out there with toy and kit parts. I've found stuff like replacement parts for the old gas station give away cars and oil tankers. GI Joe stuff, McDonald's Happy Meal toys.
I see a lot of Renwal stuff on eBay, so look around from that angle.
Good luck!
Bill
    September 2003
Posted by checkmateking02 on Friday, February 16, 2018 4:55 PM
Welcome to the Forums!  Hope you find a solution to the problem.
fox
    January 2007
Posted by fox on Friday, February 16, 2018 8:26 PM
Welcome to the Forums! Glad to have you aboard.
Jim  Captain
 Main WIP:
    July 2012
Posted by littletimmy on Friday, February 16, 2018 10:53 PM
If you could post a picture of the part's in question, it would help.
Off the top of my head, I would suggest Looking at diaphram's in aquarium air pump's. But I would need to see a picture to tell you what size of pump to "canablize".
If the part really is a "balloon" check in a Party type store. They will have all kind's of balloon's to chose from.
By The Way ..... Welcome to FSM.
 Dont worry about the thumbprint, paint it Rust , and call it "Battle Damage"
    June 2014
Posted by Tanker - Builder on Saturday, February 17, 2018 6:56 AM
Hi Rob ;
 Welcome . In amswer to your question . Are those parts even similar to " O " Rings found in say Hypodermic syringes for Diabetics ? If so that might solve your problem .The end of the plunger has a semi-"O " ring and a shape like a small balloon otherwise.
 I used to use my wife's discards for that kind of stuff . I did a PONTIAC for a court case that could've used that chassis . That's what I used for both the Master cylinder and the Wheels .
 I did use a slightly larger syringe for the Master Cylinder
