All aboard the skylark
    November 2020
Posted by Also known as Rob on Thursday, November 19, 2020 4:13 PM
Hi,
As a lad built a lot of models. In my teenage years I worked in a model shop in Bristol (UK) on Saturdays so had access to a lot of kits. I started with aircraft, but mostly built tanks as I found the build process more interesting.
Since lock down started I've started making model tanks again. Started with Churchill, then Centaur, Matilda II and Crusade III. All Tamiya 1/35. Recently started a Miniart Valentine which I'm enjoying.
The biggest change from my youth is how much I'm enjoying painting the models. I'm crap at it, but I'm enjoying that at least as much as the construction.
My main problem is where to keep my growing collection. The old "use them for airgun targets" doesn't seem appropriate now.
Posted by Bish on Saturday, November 21, 2020 5:39 PM
Welcome aboard.
“Isn't it enough to see that a garden is beautiful without having to believe that there are fairies at the bottom of it too?”
Posted by Tojo72 on Saturday, November 21, 2020 6:37 PM
Hello and welcome
    August 2020
Posted by Dodgy on Sunday, November 22, 2020 12:03 AM
Hi Rob, welcome to the forums. I am mostly a figure modeler, but after many years have come back to the hobby and once again trying my hand at armour, ships and aircraft. I would call myself a pretty average modeler, but I love it all the same. I'm sure you will get lots of enjoyment here and I look forward to seeing some of your work.
I long to live in a world where chickens can cross the road without having their motives questioned
    November 2020
Posted by Also known as Rob on Sunday, November 22, 2020 11:54 AM
Thank you dodgy. I'll get some photos of my latest project up in the not to distance future.
Over the last couple of days I've been getting to grips with photo-etch for the first time. I think my main lesson so far is that the right choice of glue is essential. I started with slow super glue, but I'm finding PVA easier for the very small parts. It feels like each has it's benefits and I've got to learn where each would be best.
Tags: photoetch
Posted by Bish on Sunday, November 22, 2020 12:07 PM
I always use CA for PE parts. one of the main things with it is knowing what bits not to use.
    November 2020
Posted by Also known as Rob on Sunday, November 22, 2020 12:49 PM
Bish
Actually, what I've called "Super glue" is CA. I've been using VMS Flex. It's great for many of the parts. The problem I've been having is with the very small parts - like individual rivets and wing nuts. I've found it impossible to apply pressure to the smaller parts to fix them without them getting stuck to the item I'm using to press them (knife, bit of wire, or tweezers). PVA seems to give me the time to move it into place and doesn't seem to require the item being held in place the way CA seems to.
Posted by Bish on Sunday, November 22, 2020 1:19 PM
Ye, sorry, on here the term CA is more widely used, i have got into that habit.
I have not heard of that stuff. I used to use zap-a-gap but have switched to my local hobby shops own brand which works just the same but cheaper. It can be tricky applieing those small parts, i built 72nd aircraft and applying PE cockpit control levers in that scale is interesting. Have you got a pair of very fine nose tweezers, they really do help, but have to be kept clean. The problem i find with white glue is that its quite thick and tends to show up on those small parts.
    November 2020
Posted by Also known as Rob on Sunday, November 22, 2020 1:51 PM
I bought a pick and place tool in the hope that it would help with placing the smaller parts. It was fine initially but seem to get bunged up and loose it's stickiness very quickly.
Pick and place tool
I've since found a wax pencil that I'm going to try when it arrives (it's taken me a while to find one as most suppliers seemed to be out of stock).
fox
    January 2007
Posted by fox on Sunday, November 22, 2020 3:37 PM
Welcome to the Forums! Glad to have you with us.
Been building models since 1946 (6 years old). Never stopped. I build whatever strikes my fancy at the time and my wallet says OK Wink. Lots of great guys on these forums that are very knowledgeable and ready to help you with any questions/problems. Favorites are WWI & WWII planes followed by sailing ships (plastic or wood).
Enjoy and don't be afraid to ask for help. Look forward to seeing your work.
Jim Captain
Stay Safe.
 Main WIP:
   On the Bench:  Revell 1/96 USS Kearsarge - 70%
    September 2003
Posted by checkmateking02 on Monday, November 23, 2020 8:13 PM
    November 2020
Posted by Also known as Rob on Tuesday, November 24, 2020 3:16 AM
fox
Jim Captain
Stay Safe.
Thank you Jim.
    November 2020
Posted by Also known as Rob on Tuesday, November 24, 2020 3:17 AM
checkmateking02
Thank you
    October 2019
Posted by Tanker-Builder on Tuesday, November 24, 2020 6:03 AM
Hi Rob:
 Welcome to the Forums. My son says the best part of building a piece of Armor is he has middling painting skills and on Armor it doesn't seem to matter. He calls it " Unintentional Weathering"
    October 2019
Posted by Tanker-Builder on Tuesday, November 24, 2020 6:04 AM
Hey Bish!
 Did you change your Avatar? I like the Lion.
Posted by Bish on Tuesday, November 24, 2020 6:53 AM
Tanker-Builder
Hey Bish!
Not recently, i have had that for a few years now.
    November 2020
Posted by Also known as Rob on Tuesday, November 24, 2020 8:47 AM
Tanker-Builder
Yes I know where your son is coming from, though to a certain extent that applies to any military modelling - because it all a little distressed. I admit to occasionally having broken a piece and thought "don't worry - we can let that be 'battle damage'".
I wish I could find something else to build, but I find nothing else a enjoyable to build and with so many options. I'd really like to build emergency services vehicles but the kits just don't seem to exist - unless you're Russian (see)
    September 2006
Posted by the Baron on Tuesday, November 24, 2020 8:58 AM
Welcome to the forum, Rob!
Yeah, I have the same problem-no place to display finished models.  I have some out on any available horizontal space, but most go back in boxes, till I can finish a room I have designated for display.
I look forward to seeing your builds!
Best regards,
Brad
    June 2018
Posted by DRUMS01 on Tuesday, November 24, 2020 1:24 PM
Hello and welcome into the forray called our forum. I'm sure you will like it here (nice blokes for sure).
Ben
I am a Veteran; to all other Veterans thank you for your service. Retired now and living well
PROJECTS:
- 1/350 USS Alabama (GB) - DONE
- 1/16 1910 Thomas Flyer (WIP)
- 1/78 AC-119 Stinger Gunship (GB-Pending)
Posted by keavdog on Tuesday, November 24, 2020 1:39 PM
Welcome!  My shelves are almost full and need to build more.  A problem we all suffer from.  I'm considering acrylic 1/2 height shelves/stands to effectively double my shelving
Thanks,
John
Ain't no reason to hang my head, I could wake up in the mornin' dead
