Hi guys,
I just happened to bop in and I noticed that this last post was made on April 1, and no one has chosen to answer, and even the writer seems interested, as he has offered no further clues or suggestions.
As stated on the fist page with the guidelines for this forum:
"if no one can answer a difficult question within a five-day week, the forum is open to anyone who wishes to posit the next question"
So here is my next go at it:
Up until well into WWI did this famous aircraft genius discover a simple solution to a problem that had been plaguing seaplanes up to then.
Their biggest challenge, along with dealing with the drag of that water itself upon take-off, was in breaking the surface tension of the water.
This simple discovery fixed the problem, and it has been used by all nations that successfully designed and built seaplanes ever since.
What was the fix?
If you need a clue, simply study the hull/float configurations of early WWI seaplanes vs. those that came later, and it should be obvious.
As a bonus, name the aircraft genius.
Tom T
