decal adhesives
    June 2009
decal adhesives
Posted by redshft1920 on Sunday, July 13, 2014 5:11 PM
Hoping for some suggestions on keeping newly applied decals down. I applied new decals yesterday and while they were easily applied and seemed good last night, this morning I found two decals curling up. Any suggestions would be SOO much appreciated.
Bob in Cedarville, AR
PS... I answered some suggestions below.
Bob Moody in Cedarville AR
    July 2004
Posted by stikpusher on Sunday, July 13, 2014 5:49 PM
What brand of decals? Off the top of my head, I might suggest Future to get them to lay down.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    December 2004
Posted by panzerpilot on Sunday, July 13, 2014 6:48 PM
Use a setting solution, such as Microset.
-Tom
    July 2004
Posted by stikpusher on Sunday, July 13, 2014 7:18 PM
Microset will get them to lay down, but if the decal adhesive is bad or gone, it will not hold the decals down after it dries. It has no adhesive properties, while Future does.
       - Plankton
LSM
    May 2013
Posted by Greg on Sunday, July 13, 2014 7:40 PM
I wonder if perhaps you soaked them in water too long? They will lose their adhesive properties if that happens.
I remember decades ago as a kid decided I would decal as a mass-production thing, soaked a bunch at a time. That didn't work out very well. :)
My guess is meant as an addition to what Tom and Stik recommended above.
    November 2003
Posted by mississippivol on Sunday, July 13, 2014 7:45 PM
Dittos on the Future, or you can run some diluted Elmer's white glue under there, too(if that's more immediately available).
    August 2005
Posted by Phil_H on Sunday, July 13, 2014 7:51 PM
The only decal setter/solvent that I am aware of that has adhesive in it is Gunze's Mr Mark Setter. It's quite tenacious and really pulls them down.
    January 2013
Posted by BlackSheepTwoOneFour on Sunday, July 13, 2014 8:19 PM
I use both Micro Set and Micro Sol when decalling. Not sure if Micro Sol would made a difference with decals curling up.
    April 2009
Posted by Cadet Chuck on Sunday, July 13, 2014 10:06 PM
I use Micro Set on the model surface when applying the decals, then wait a few minutes to let them set, and then apply Micro Sol on the top.  This has always worked well, except you don't have much time to reposition the decals after applying them over Micro Set.  Alternatively, you can also apply the decals over water, wait for them to set, and then apply Micro Sol over them when they are dry.
    June 2009
Posted by redshft1920 on Monday, July 14, 2014 12:38 AM
THANKS for the suggestions...I used Micro Sol and Micro Set for a few years, (2008-2012) but I admit I tried making my own with vinegar and water. I added Vinegar to water until the smell was as close as I felt I could make it, with both of them, and other decals have worked fine with these. I tried this from a suggestion from this forum.
I have experienced MANY different decals and their characteristics and I know some are very finicky, almost impossible to keep from total disintegration. These I used yesterday were Eagle Strike. I also wonder about the soaking time and I can't say if I waited too long or not...again, very tricky to me.
I like the Future suggestion. I'll try that. Can anyone say if I should use an overcoat of Dull coat to help hide the, uh, whatever its called between letters or areas where you can't trim to extreme closeness, anyway, I'll try the Future this evening and see.
THANKS AGAIN, EVERYONE!!!
    August 2005
Posted by Phil_H on Monday, July 14, 2014 12:42 AM
Tip: Don't leave the decals soaking in the water. Dip, then remove, remove excess water (touch the corner to a paper towel) and leave it on a hard surface for about 30 seconds. Test to see if it slides easily on the backing. If not, put it down for another 10 secs and try again.
If you're worried about decals disintegrating, you can cover them with something like MicroScale's Liquid Decal Film. Paint it over the decal (you can brush it on, it will level without leaving brush marks), let it dry, trim the decals close to the edge, then dip and apply as normal. It's water based, so the brushes wash out in water.
    January 2012
Posted by Misty on Monday, July 14, 2014 4:15 AM
be aware that some decals, especially older ones, can react horribly to some brands of decal solutions. try it on one you wont use first (bitter voice of experience speaking). i also tried putting liquid decal film on a still wet decal on the model (i thought it was micro set, almost identical bottle) and it did not go well at all. it works perfectly on dry decals still on their backing though.
dmk
    September 2008
Posted by dmk on Monday, July 14, 2014 1:53 PM
Phil_H
I love Mr. Mark Setter. It's a solvent that literally melts the decals onto the surface.
 It's great stuff, but treat it with respect. Never touch a decal once you've applied this stuff to it. Treat it like you just painted that marking on.  (yes, I've learned this the hard way and basically smeared a decal when I tried to blot it)
    June 2009
Posted by redshft1920 on Monday, July 14, 2014 5:41 PM
Thank you all so much for these suggestions! I have decided to order and try Gunze Mr. Mark Setter to future decal attempts. I used Future with great results last night and I'll always remember that remedy. I ALSO LIKE THE SUGGESTION THAT DECALS SHOULD SET ON A PAPER TOWEL UNTIL MOVEABLE. That sounds like what went wrong with my attempts in this discussion. I'll always remember this as well.
T H A N K S  A G A I N,  EVERYONE! Great suggestions every time from this forum!!!
    November 2008
Posted by plasticjunkie on Tuesday, July 15, 2014 7:43 AM
I use Solvaset and it melts the decals down to the point that they look painted on. The only time I have found that Solvaset to work so so was with thick Academy decals on my 1/25 scale Panther. I tried Solvaset on the smaller cross decals and it kind of got them on. In this particular case I went with brushing Future on the area and immediately lay the decal on the wet Future. Wait a couple of minutes to let the Future grab the decal from underneath then brush some more Future on top of the decal to seal it in. Guaranteed success, no silvering of the carrier film between the numbers but looks like it was painted.
One word though of caution, brush the entire panel with Future or the entire side otherwise you will see a different sheen when the clear flat is sprayed.
Here is a picture of those awful Academy decals applied with the Future method. I even got rid of the step left by thick decal film. I applied several Future coats from the center of the decal feathering it out as I went.
 GIFMaker.org_jy_Ayj_O
Posted by Don Stauffer on Tuesday, July 15, 2014 8:48 AM
There is a difference between setting solutions and decal solvents.  I use setting solutions regularly when applying decals.  They are pretty benign.  Solvents, however, are "medical care" for difficult decals, or applying decals to difficult surfaces (extreme complex curvature, ridges, deep panel lines).  Solvents by their nature partially dissolve decals, and, like any medical care, involve risks.  I only use solvents for problems, and then start out with minimal application, increasing as needed.
Also, there is considerable variation in concentration and dissolving power between brands of decal solvents.
dmk
    September 2008
Posted by dmk on Tuesday, July 15, 2014 9:31 AM
Don Stauffer
To add to what Don said, solvents can also be added later. So you can set the decal using a decal set, but without any solvent , then use the solvent to fix problem areas as they arise.
I've gone back the next day and treated some stubborn decals with Mr. Mark Softener to melt them down into panel lines or get rid of bubbles.  Just gently poke the surface with a very fine point sewing pin and put a drop of the solvent on it, then let it perform it's magic.
I don't think they will work well after you've used Future or other topcoat over the decal though (I've never tried though).
    November 2008
Posted by plasticjunkie on Tuesday, July 15, 2014 10:13 AM
dmk
Correct dmk. If Future is used over the decal then it will seal it up and the solvent will not do anything. Another note about using Future and decal solutions, make sure if you use Future to gloss up the surface for decal application that it has cured for at least a day or two otherwise the decal solution will cloud or haze the area. This doesn't happen with Aqua Gloss from Alclad,
    September 2006
Posted by the Baron on Tuesday, July 15, 2014 11:56 AM
I had the same thing happen with my EagleCal decals for Lt. Klibbe's "Little Chief".  Overall, the decals were very good, but one of the ID code letters cracked, flaked and peeled.  I used Future, and some thinned white glue, as described above.  I brushed it under decals that lifted, and also used it to re-attach pieces that flaked off.
