Work Area WIP
    December 2013
Work Area WIP
Posted by jetmaker on Saturday, March 21, 2015 10:36 PM
Okay guys, finally got some breathing room to start work on my new and greatly improved work area. As you know, I had a lot of tasks to catch up on that piled up while I was down with the sickness. One of the things I did was move into a new room (I board with my folks, which I'm totally cool with, and they are too - unless they are lying to me. Guess I won't know for sure until the will is read). I love my new room. The one I was in was the hot room of the house. It faced south and had windows on the south and west. It got beat up by the sun from just after sunrise all the way to sunset. The one I'm in now is along the eastern wall, and it has an awning. It gets gentle, indirect sunlight, and is much more suited for sleeping. My mom and dad are very accommodating, so I could probably talk them into letting me set up a workspace wherever I wanted - within reason - but I like to respect that it is their house, and my job is help keep things fixed and clean, be their sheepdog, and watch the place when they are away. I was in the military (army), and spent a lot of time living in dorm-like, spartan conditions, and I am not only used to it, but I actually kind of prefer it, I think...
Anyway, I digressed a little. I wanted to give a short context of what I'm up to here, so, without further ado...
I have a nice desk that will be my main workbench
I have a toolbox in a closet right next to the desk
I just got a small shop vac for cleaning up sanding dust and other carnage
Here's a transformer toy I rescued for my nephew. It had a wheel broke off, so I glued it back on
Too soon?
Exactly
I have good table that is perfectly positioned right in front of a window that I will use for airbrushing - but probably not rattle cans, I'll use the garage for them
Since I will be airbrushing in the same room where I lay me down to sleep, I will be using a vented spray booth. I did a TON of research on spray booths. I considered buying a ready-made one, but with the prices being what they are, I decided that I should at least try building my own first
After drawing a few designs for a box, I came to the conclusion that a plastic tote is ideal, both from a cost and structural perspective - they're cheap, dimensionally adequate, allow for excellent lighting (clear ones), and no joints to seal. Here's one I got from Walmart
I want to not only extract solid particles - which is relatively easy - but I also want to extract fumes - not as easy. I will be airbrushing acrylics almost exclusively, except for priming, clear coating, and metal finishes (MM Metalizer, Alclad II, etc). I would like to be able to do those without stinking up my pillow too bad. There's a 24hr Mexican food restaurant nearby if I want to do that. So here's the fan I researched and carefully chose
It's quiet and it sucks real good. If only it cooked and did laundry too
Hey look! A squirrel!
Here's what it'll kinda look like. I'm going to run a 90 angle into a 45 angle and right into an exhaust vent out of that bottom window pane
While at Lowe's, I also picked up a 7-gal air tank that I am going to use with my cheapie Chinese compressor. It'll take a while to fill from empty for sure, but I have a cutoff valve, and I expect I'll be able to do a typical spray session without the compressor kicking on. I might put a small fan on the unit while it fills to keep it cool. I removed the small tank you see in the pic
Well, that's where I'm at for now. I hope to be operational in a couple weeks. I can't wait to get a'modelin'
Cheers until then guys!
    February 2011
Posted by Raualduke on Sunday, March 22, 2015 4:14 AM
Looking good so far.  Mike
    January 2014
Posted by jelliott523 on Sunday, March 22, 2015 9:09 AM
Okay Jet, I have to say first thing...  you are one of a kind my friend...one of a kind (okay maybe not, I caught all of your innuendos with no problem...actually got a good belly laugh out of them)
fox
    January 2007
Posted by fox on Sunday, March 22, 2015 10:49 AM
Nice set-up Jet!  The pieces of furniture in there look like they are in excellent shape.  Do you expect to keep them in that condition????Wink
Jim Captain
 Main WIP:
    December 2013
Posted by jetmaker on Sunday, March 22, 2015 8:54 PM
Jim, that is an excellent question. I'm pretty good about keeping spillage and other assorted mishaps at bay, so I'm not terribly worried about that. I have a Tamiya cutting mat (A4 size), but I'm going to get a larger one, and I'm going to use the pane of glass I remove from my window for things where I need a smooth flat surface. Those two things will protect my desk pretty well. As far as the table goes, you can see that the tub (aka super professional spray booth) takes up a gigantic chunk of the table top, so the table will probably be okay too - though it's an old table, and I'm not too concerned if it gets goofed up
My biggest issue at the moment is how I'm going to use the space on my desk. My laptop just sits there like a DMV clerk, taking up space that could be used more productively. I also got my TV/monitor too. I'm trying to come up with some ideas of how I can get them off the desk top but still use them as I do. A wall mount might be in order for the TV/monitor. I might be able to fit my laptop in the middle drawer, but that would only be practical if I can figure out a way to use it without having to open it. I'll be grinding the gears in my head this week working on solutions
    January 2013
Posted by BlackSheepTwoOneFour on Sunday, March 22, 2015 11:21 PM
A bigger table comes to mind...  LOL!
    January 2013
Posted by jibber on Monday, March 23, 2015 2:43 PM
Jet, I don't know how much table is enough, I'm  blessed with a large work room a lot of counter space plus a large work table, and every time I look its filled up. Shelving and peg board has been a blessing, even those plastic nuts/bolts wall hung parts bins really helps too. One thing I really like is that almost everything is within reach when I'm building. All the best, enjoy it but I'll bet it'll be a work in progress for quite a while.
If I can find a good photo I'll post it, maybe for an idea or two.
Terry
    December 2012
Posted by RX7850 on Monday, March 23, 2015 5:40 PM
    December 2013
Posted by jetmaker on Monday, March 23, 2015 6:34 PM
That is a killer work space jibber! Yeah, a bigger table would be nice, especially an L-shape corner station, but space is at a premium in my little room. I'm supposed to start working nights (my request) soon, so things may change after that, being how my folks' sleeping quarters is right next to mine. I'm pretty quiet though, so I probably won't disturb them. I like the comfort and serenity of my room, so I'm making a concerted effort to successfully use it for my modeling hobby. I'm also a bit of a clean freak, so I definitely see it as doable. I guess I won't know for sure until I get going on some builds
I totally expect this to be a continual WIP. I would guess that pretty much every modeler's work area is continually improved. I think I kind of do that naturally with most everything. I'm always looking for ways to make my mom and dad's house more comfortable and efficient. Same with vehicles, work, etc. For now, though, I'm basically inventorying my tools, getting my desk organized for assembly work, and getting that airbrush station set up. Once those goals are accomplished, I'll be ready to continue with my M113 build where I left off before I fell ill with the MOASI (Mother Of All Sinus Infections). I got a lot done this weekend. I got the main parts of the spray booth, as you can see from the pics, and I got all of my tools inventoried - except paints and glues, which I'm either going to do piecemeal during the week, or save for the weekend when I'm off work. I hope to be fully operational by mid April at the latest
    December 2013
Posted by jetmaker on Monday, March 23, 2015 6:37 PM
Oh, by the way, thanks everyone for all the encouragement and ideas. You guys are tops, seriously!
    January 2013
Posted by jibber on Tuesday, March 24, 2015 1:56 AM
You bet, have fun.
