Painting white over grey primer
    March 2015
Posted by Benschechtman on Thursday, March 26, 2015 11:19 PM
After many years of modeling I have discovered the wonderful substance called mr. Surfacer which I use as a filler then cover with tamiya grey primer to prevent color bleed as the plastic is white. I'm trying to paint the model white (it's a 1/144 revell saturn V) and as we all know white is hard to paint effectively without a base coat. I was wondering if there was a color that you use that is effective at preventing bleed through?
    September 2012
Posted by GMorrison on Friday, March 27, 2015 11:19 AM
I don't build space too much but I build airliners- same thing.
I like starting with gray primer, it makes it easier to see where the white paint coverage is too thin.
If I understand your question, one coat of gray, two coats of white.
Posted by Tojo72 on Friday, March 27, 2015 11:23 AM
I use the Mr Surfacer 1200 for primer ,when I spray white,it's light coats building up slowly till it's covered
    April 2009
Posted by Cadet Chuck on Friday, March 27, 2015 12:52 PM
Tamiya makes a very good primer in white, as well as gray.  White primer might be the best way to go.  I think you will find it is as good as Mr. Surfacer.
    October 2007
Posted by Milairjunkie on Friday, March 27, 2015 4:06 PM
I'll second the Tamiya white primer option!
    May 2009
Posted by Pawel on Friday, March 27, 2015 4:30 PM
Hello!
I'm also opting for Tamiya white primer (in a spray can), when painting larger surfaces. Although it goes on a lot better on top of a coat of Tamiya grey primer. Recently I used that method for those builds:
and also for this one, currently in progress:
Sometimes, like when painting wheel wells, it's good to put white on top of a silver layer - works very nice too.
Hope it helps, have a nice day
Paweł
www.vietnam.net.pl
    November 2008
Posted by plasticjunkie on Saturday, March 28, 2015 1:26 PM
I like Mr. Surfacer but it has a very strong chemical odor. It sprays beautifully and produces a great primer coat. For some reason, I used it the last time and damaged the needle bearing in my brand new Badger. I have been hesitant to spray it again so I tried Tamiya's grey primer thru my AB and I think they are about the same in delivering a super smooth finish. No problems with my AB after using the Tamiya primer.
 GIFMaker.org_jy_Ayj_O
    March 2015
Posted by Peaches on Tuesday, March 31, 2015 2:32 AM
I just use Rust-O-leum white primer. More cost effective.
WIP:
Academy F-18 (1/72)
On Deck
MH-60G 1:48 (Minicraft)
C-17 1/144
KC-135R 1/144
Academy F-18(1/72)
Ting Ting Ting, WTF is that....
    August 2005
Posted by Phil_H on Tuesday, March 31, 2015 5:59 AM
I often find that flat white covers much better than gloss white from the same manufacturer (this is at least true for Tamiya acrylics). You can build up coverage with flat white, using fewer coats than you would using gloss, then apply a gloss white top coat.
    November 2008
Posted by plasticjunkie on Tuesday, March 31, 2015 2:47 PM
I also decant Krylon white and black primers and do agree that the flat colors cover better.
    December 2006
Posted by Fly-n-hi on Tuesday, March 31, 2015 5:46 PM
I get great results when I prime with Tamiya Fine Grey primer and then prime again with Tamiya White primer.  It seems like when I just use the white primer only it tends to collect in the corners but it covers evenly with a coat of grey primer underneath.
    January 2014
Posted by jelliott523 on Tuesday, March 31, 2015 5:54 PM
On this build, I used both grey and white Krylon primers.  I started with the grey after everything was put together as a base to see any "ghost" panel lines and imperfections, after they were fixed I then coated it with white Krylon.  Then I applied several thin white coats of Model Master pure white that I decanted and sprayed through my AB.
    August 2008
Posted by tankerbuilder on Sunday, April 5, 2015 10:31 AM
Hi ;
I find that using White Primer ( Tamiya or Rust-O-Leum ) is best for the larger models .Then a sparkling coat of Gloss and /or Semi Gloss renders your model a work of art ! This is primarilly how I do Motoryacht hulls .
    January 2003
Posted by murph on Tuesday, April 14, 2015 9:03 AM
Everyone has a different method.  I use Model Master enamels almost exclusively.  When spraying white or yellow, I always use their light grey, FS 36495.  I then spray very light coats of either gloss or flat white, depending on what the project is.
Retired and living the dream!
    July 2019
Posted by Bobstamp on Saturday, April 17, 2021 10:32 PM
Phil_H
I'm using Tamiya Pearl White rattlecan paint for a ship, but it doesn't seem to be covering very well. I sprayed it first with Tamiya white primer, which also failed to cover some small blemishes. The Pearl White paint seems to be glossy, but not extremely glossy. I thought that a second coat might complete the job, but there was hardly any change to its apparent translucence. Suggestions?
Bob
On the bench: A diorama to illustrate the crash of a Beech T-34B Mentor which I survived in 1962 (I'm using Minicraft's 1/48 model of the Mentor), and a Pegasus model of the submarine Nautilus of 20,000 Leagues Under the Seas fame.
    May 2011
Posted by Real G on Sunday, April 18, 2021 1:12 AM
When I built my Saturn V, I too started off with Tamiya grey primer, followed by two coats of the white primer (satin/flat), followed by two coats of semi-gloss white.
I used to work close to home, so I would spray paint the parts in the backyard during my lunch breaks.
The car guys tell me that's how they do red and yellow paint jobs - start with a flat version of the final color, then finish off with the gloss color.
“Ya ya ya, unicorn papoi!”
    August 2005
Posted by Phil_H on Sunday, April 18, 2021 3:11 AM
Bobstamp
I hope you're using TS-45 Pearl White and not PS-57 Pearl White.
    July 2019
Posted by Bobstamp on Sunday, April 18, 2021 4:10 PM
Real G
Thank you, Real G. Spraying grey primer first makes sense. It should do a better job of covering than white primer, which in turn shouldn't have to "work" as hard to cover, and then a final coat or two of the Pearl White. I'll try that. I've already sprayed so many coats that it won't make much difference!
Bob
    July 2019
Posted by Bobstamp on Sunday, April 18, 2021 4:14 PM
Phil_H
Thanks for the caution, Phil. I am using Tamiya TS-45 Pearl White spray paint.
Bob
    September 2012
Posted by GMorrison on Sunday, April 18, 2021 4:51 PM
Your primer needed to be rubbed down and revolted at least once.
Pearl White is a little Gray- is that an effect you want? never too late to rub things down a little and re coat.
Sounds like a hospital ship.
Bill
    July 2019
Posted by Bobstamp on Sunday, April 18, 2021 5:35 PM
GMorrison
Bill
It is a hospital ship, the same Repose I've been working on forever. An employee in a model store told me that model from the 1950s are more frustrating than rewarding to build. I didn't listen, but at least I've learned a lot! Now...
Rubbing down the primer? Please explain. I thought the idea of primer was to provide "tooth" for the final paint. Rubbing it down, which I assume means polishing, would seem to defeat the purpose.
I assume that you meant "re-coated" rather than "revolted"! Darned spell checkers!
I chose the pearl white paint because I didn't want the model to look factory-new. Of course, I'm making so many errors that it's going to look very war weary regardless of the paint I use!
Bob
