Old model...New model???
    August 2016
Posted by tonycip on Wednesday, August 24, 2016 7:44 PM
Hi all, I just got my first model, Italeri M1A1 Abrams 6438. When I bought it I didn't know they remake models.. How do you know when a model was made? the kit I have has a bunch of resin parts copyright of 2004 on the box...but did they update it since then? Hmm
Posted by echolmberg on Friday, August 26, 2016 9:56 AM
Hi Tony!
One really good source for finding out this kind of information is from a website called scalemates.com
https://www.scalemates.com/
I did a quick search for "Italeri M1A1 Abrams 6438" and it appears that the kit was released in 2004.  It looks like it is an updated version of Italeri's kit # 6390 which came out around 2003/2004.  If you scroll down to the bottom of the page, you'll find a timeline showing when a particular kit was released and/or if it's been reboxed.
Here's the Scalemates page I pulled up when using the search parameter I mentioned above:  https://www.scalemates.com/kits/103478-italeri-6438-m1a1-abrams
And here's a review of the kit with a few more details (also taken from Scalemates):  http://www.perthmilitarymodelling.com/reviews/vehicles/italeri/it6438.htm
Hope that helps!  Big Smile
Eric
Posted by Rob Gronovius on Friday, August 26, 2016 10:30 AM
The Italeri M1A1 with resin and the M1A2 are the same basic kit both released around the same time and are both original Italeri kits. They sort of goofed when they made the kits; the straight M1A2 was a rather rare version of the Abrams only used by a few battalions in a couple of divisions for a few years before it was replaced by the updated M1A2SEP.
They also made a mistake when they tooled the back deck (engine compartment). They molded a few of the grills in place on the upper hull that should be molded onto the removable part of the back deck. In other words, when the deck is removed to replace the engine, those grills are a permanent of the deck and would not be able to stay on the upper hull. So the engine compartment and resin engine set up are incorrect.
Compare the kit's smaller "T" shaped compartment to this Legends Model correct compartment. Notice how the four small grills that are on the Italeri upper hull are actually on the removable back deck of the Legend part.
    August 2016
Posted by tonycip on Friday, August 26, 2016 5:15 PM
Eric, very helpfull link thanks for sharing, and Rob, thanks for all the fact's on the model I would not have known, like my model is jacked.. : ).  just kidding thanks for the replys .
Why are my post's taking over a day to post? will it always be like this on here?
very annoying..
    August 2014
Posted by goldhammer on Friday, August 26, 2016 5:49 PM
Rob is the go to guy for US Army equipment, along with Gino.
Once you get past a few posts and the "probie" period they will pop up immediately.
Posted by Rob Gronovius on Saturday, August 27, 2016 2:15 PM
It's not really an issue if built with the engine compartment in place or just to remove to show additional detailing. The accuracy issue is when trying to depict a diorama with the engine on the ground and guys working on it. It's not a bad kit; it's just not any better than the kits that were already out (Dragon or Trumpeter) and was surpassed by the Dragon kits in 2005 (AIM & SEP). Those two kits made the other Abrams kits obsolete over night.
    August 2016
Posted by tonycip on Sunday, August 28, 2016 7:50 PM
Thanks again. since this is my first model in over 30 years, I'm just trying not to get my feet wet try a few new techniques I've lerning about on here. I'm just getting started so new build thread soon  : ) .
