Cracks in the plastic
    November 2017
Posted by FuzzBall on Saturday, November 18, 2017 12:37 PM
Has anyone experienced cracks in places where there should not be any? I have a 1/12 1957 Chevy Sport Coupe with cracks developing in the plastic in front of the wind shield. It was my fault for them. Any suggestions?
    January 2006
Posted by Wirraway on Tuesday, November 21, 2017 3:53 AM
Cant say I have had cracks appear in the model itself. My old Revell 1/32 P38 Ligthning has cracks in it, but that is cracks in the putty, not the plastic. All the rubber tyres on my 1/24 fighters have started to crack as well...
"Growing old is inevitable; growing up is optional"
" A hobby should pass the time - not fill it"  -Norman Bates
GIF animations generator gifup.com
    June 2014
Posted by Tanker - Builder on Tuesday, November 21, 2017 8:15 AM
Hi ;
 Are you in the process of a build ? If so then do this . I had the same problem . I solved it by taking a strip of .020 plastic , cutting it to shape and gluing it under that strip between the windshield and the hood opening .
    You can sand a taper on the windshield side and the window will still fit right .
Posted by Don Stauffer on Tuesday, November 21, 2017 8:45 AM
Depends on how wide/deep the cracks are.  I usually use some solvent cement to repair those areas, though sometimes I can get the thin CA to wick into the cracks. If there is a stress point there, then, like in the above message I try to see if I can glue on some structural support if I can do so without changing visual appearance.
There are a few kit companies that make some pretty fragile kits.  I know who these folks are, and try to use extra caution when building their kits.
    July 2013
Posted by modelmaker66 on Tuesday, November 21, 2017 10:40 PM
Did you say that you caused it? Is that not it's own answer or am I not understanding the question?
    January 2009
Posted by fermis on Wednesday, November 22, 2017 7:31 PM
Like Don suggested...I'd dab some thin cement (I use Tamiya extra thin) over the cracks. Allow some dry time and sand it smooth.
