Multiple Kits on the Bench?
    December, 2010
Posted by 1943Mike on Tuesday, January 08, 2019 11:39 PM
How many of you have two or more kits that you're working on at one time?
I'm just curious since I'll probably not live long enough to complete my stash as it sits - and it seems to grow through some sort of spontaneous generation Big Smile
It would help if I had enough room on the small tables I have set up in my hobby room so that I might work on at least two at a time. Perhaps you all could share how you manage two or more kits "on the bench"? My guess is that one would work with one kit until you had to pause (letting oil colors dry, etc.) for more than a few days and then, having come to a temporary pause, bring on a different kit to work on for a while until the first kit was ready to proceed. I suppose that way one could remove the box and parts and partially built model from the bench and put them safely aside until ready to work on again.  Of course if your "bench" is large enough you could just move one kit to the side and bring the other to center stage.
Just curious.
"Le temps est un grand maître, mais malheureusement, il tue tous ses élèves."
Hector Berlioz
GAF
    June, 2012
Posted by GAF on Wednesday, January 09, 2019 12:25 AM
I have multiple kits on the bench... just sitting there staring at me.  Taunting me with my inability to work on them with any regularity.  They task me.  I need to sell them to someone with more time...  Big Smile
Gary
    April, 2003
Posted by keavdog on Wednesday, January 09, 2019 1:21 AM
I'm always working on 3-5 kits.  Different stages.  I find it really supports patience.  If I get to a point - say interior of an aircraft model all tacked together, there's a huge benefit to just let it sit.  Moving on to another kit facilitates that.  For example - the T28B trojan I working on:  I got the fuselage together and glued the wings on which had serious fit issues and I wanted the correct dihedral.  Setting the little bird down on a jig so the wings would dry correctly was the best choice... so on to the next kit that perhaps dried last night.
Thanks,
John
    December, 2002
Posted by Bish on Wednesday, January 09, 2019 2:15 AM
generally i only build one at a time. But recently i have been doing 2. But i would only do this for smaller builds and prefrably where they have similar colours so i can airbrush both at the same time. But i have found it certainly doesn't speed things up, just saves cleaning my airbrush as much.
'I am a Norfolk man, and i glory in being so'
On the bench: Dragon 1/72nd Ar 234B-2b
                      Airfix 1/72nd SM.79
    March, 2003
Posted by Tojo72 on Wednesday, January 09, 2019 5:57 AM
I usually only work on one kit at a time,a couple of times i was waiting for some AM part,so I did start another kit,but thsts the exception for me.
    January, 2019
Posted by Edwin on Wednesday, January 09, 2019 6:39 AM
1943Mike
Big Smile I know that feeling! I remember from way back when I had a serious stash, I used to estimate the number of lifetimes I would neef to build them all. Gave them all away when my hiatus started.
Anyway, I’m mostly a 1 kit at a time guy. Only recently did I start doing 2. After a few weeks working on this car kit (building a replica of my car), I packed it away and started on a zero. Find it helps keep things fresh. I’ll get back to the car after working on this zero.
    March, 2012
Posted by mustang1989 on Wednesday, January 09, 2019 7:14 AM
There aint no way in Hell I can do that. Tried once.............but it just doesn't work for me. Friggin' sensory overload I guess. Hats off to those who can though.
Being really stupid IS "the new smart"!!
    March, 2007
Posted by armornut on Wednesday, January 09, 2019 7:24 AM
    Because of my current situation I have several kits in all stages. I am trying to cut it back to just one kit at a time start to finish. This may actually increase the number of kits I actually finish.
we're modelers it's what we do
    September, 2011
Posted by falconmod on Wednesday, January 09, 2019 7:36 AM
I have 5 on the bench but only 2 of them am I activily working on.  It's easy to move them around when you have boxes that are the top and bottom kind of boxes.   As with everyone it seems like I'm not a fan of end opening boxes!   alway need the find another box to put the parts I'm working with those.
John
On the Bench: 1/72 Ki-67, 1/48 Airfix P-51D
1/72 LS Dinah III, 1/72 Hasegawa T-33A
    June, 2014
Posted by bluenote on Wednesday, January 09, 2019 7:57 AM
Only 1 at a time for me.  I'm one of the rare ones where I don't have much of a stash.  Only 2 in my stash at the moment to be exact.  My stash is the hobby shop!!
    December, 2002
Posted by Bish on Wednesday, January 09, 2019 8:06 AM
I am with you there John. have a top and bottom to the box really helps me to keep a build organised.
                      Airfix 1/72nd SM.79
    November, 2009
Posted by Don Stauffer on Wednesday, January 09, 2019 9:13 AM
I generally work on two kits at a time.  I phase them so that I am doing gluing, or hand painting, or assembly on one while I am painting the other.  I do a lot of projects that require gloss painting, and I use enamel.  That means painting entails a lot of drying time, so I work on something else during the drying time.
I have built a little stand that I keep next to my bench. I built it mainly for rigging of ships (it is adjustable for height), and when I am not rigging a ship I keep inactive kit there.
    July, 2014
Posted by Bakster on Wednesday, January 09, 2019 9:26 AM
Generally, one at a time. However, for the first time I have two on the bench. So far, it is working for me. It's kind of nice flipping back and forth--it's keeping it interesting. Too early to tell if this will work for me long term.
    January, 2015
Posted by PFJN on Wednesday, January 09, 2019 9:46 AM
Hi,
I used to think that one was enough, but lately I've begun to do two or more at a time since I often like to wait for a day or so between coats of paint etc.  Plus, by having more than one kit going, if I get bogged down somewhere on one I can do a little work on another to "clear my mind".  The down side of all that though, is trying to make sure that I don't set one kit aside for too long, that I loose interest Sad
PF
    January, 2013
Posted by BlackSheepTwoOneFour on Wednesday, January 09, 2019 9:51 AM
One kit at a time for me. If I did multiple kits at once, I'd lose interest and ambition to actually finish what I started. Too distracting to be honest...
    December, 2002
Posted by Bish on Wednesday, January 09, 2019 10:05 AM
One advantage of doing diorama's is that when i have to leave the model to dry, thats when i can get on with the base, figure's and so on. Also gives more variety such as adding a vehicle and ground equipment to an aircraft build.
                      Airfix 1/72nd SM.79
    June, 2014
Posted by Tanker - Builder on Wednesday, January 09, 2019 10:15 AM
Hoo Boy !
 You must've gotten a picture of Both of my working areas ! Yup , ten at last count .
plus the U.S.S.Kidd and Arizona for my client . Seems like there's always room for one more though .       T.B.
    September, 2004
Posted by tankboy51 on Wednesday, January 09, 2019 10:21 AM
I only have 1 right now, getting ready to decal a Fine Molds 1/48 Judy.  I usaly have 2 going. I like to be building 1 while painting another. This kit went fast, since I had no refences to go by.  I just built it OTB.  Now the fun of going though the massive collection to decide what to do next, one the new kits from Xmas or one older?
    July, 2004
Posted by stikpusher on Wednesday, January 09, 2019 10:37 AM
Years ago, I only worked on one at a time. And perhaps had some figures for painting while waiting on paint or glue to dry. Somehow that morphed over time into multiple kits going at any given time. And NOTHING was being completed. Step 1 here, Step 5 there, basic paint on another, all ready for decals on another, and somewhere in between on several others. Next thing I know, I have 30+ kits ranging from barely started to almost finished. My main goal over the past few years has been to reduce that number. Last year I started and completed six... twice what I completed the year before..... but finished zero sidelined builds. And I added at least one to that 30+. This year I’m gonna work on that. Nowadays I try to work on one at a time until completion, with occasionally a sideliner for time filler on occasion.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    December, 2010
Posted by 1943Mike on Wednesday, January 09, 2019 12:09 PM
Thanks to all who've commented!
I suppose I should try to do two at a time at least once.
Just now I'm in a funky, slightly unmotivated state of mind looking at the armor kit I'm working on. I ruined the engine and had fit problems with it - my fault. I bought a second kit which I'm hoping to complete right after I attempt to salvage the one I'm working on by building it closed up. I'll display the new kit with all hatches open so as to view the engine and interior as much as possible. Such a tiny kit with so many frustrations for me (Meng's 1/35 French FT-17 with cast turret) so I'm debating working on something else for a short break.
Hector Berlioz
    July, 2004
Posted by stikpusher on Wednesday, January 09, 2019 12:16 PM
Go grab a nice Tamiya shake and bake build to get your modeling moejoe flowing again. Experiences like yours are why I have that huge stock of sidelined builds... frustration strikes and it can kill your desire completely.
       - Plankton
LSM
    September, 2006
Posted by NucMedTech on Wednesday, January 09, 2019 12:43 PM
Usually I have more than one kit going through the winter months (which don't last long in Texas). As spring and summer arrive and I can get more work done in the garage, I will finish my winter kits one at a time. Also, I have taken to working on a kit during lunch breaks at work, something simple that i don't need to have alot of supplies to work with. Helps keep my sanity at work. LOL
-Stephen
Most barriers to your successes are man made. And most often you are the man who made them. -Frank Tyger
    March, 2015
Posted by JohnnyK on Wednesday, January 09, 2019 4:59 PM
I usually have an airplane model and a car model going at the same time. If I get bored working on the airplane I put is aside and work on the car. I would have a difficult time working on two airplanes or two cars at the same time.
    October, 2009
Posted by JacknewbIII on Thursday, January 10, 2019 4:35 PM
I find it interesting to see the building patterns of others. I also build 2-3 kits at a a time and usually have 2 aircraft I focus on and one car going in case I need something different. I find this allows for ample drying time for paint and decals to cure and keeps me moving as I rarely stall out on a build while keeeping a good rotation going.
    November, 2018
Posted by Noah on Thursday, January 10, 2019 7:13 PM
I build whatever I feel like each day so sometimes I will be between 4-5 models. Smile
Noah
    August, 2014
Posted by goldhammer on Thursday, January 10, 2019 10:12 PM
I have 5 in progress right now.  Usually have at least 2 going to vary things and avoid burnout.
    August, 2012
Posted by Rambo on Friday, January 11, 2019 12:06 AM
Most of my builds I like to make into dioramas so I'll work on the base when I'm at a standstill on the model. Or I'll be doing my other hobby gunsmithing right before deer season starts im usually backed up with jobs from my friends and coworkers.
Clint
    February, 2011
Posted by GreySnake on Friday, January 11, 2019 9:55 AM
Right now I'm only working on one kit since I've just returned to the hobby. I usually like to have a couple in progress at a time. That way if I'm waiting for something to dry I can work on something else.
    November, 2018
Posted by Noah on Friday, January 11, 2019 10:34 AM
GreySnake
Ditto  I have tons of in-betweeners that I work on during the paint drying on other models.
Noah
