This is now in my grubby little hands:
For those who are interested, it is the same kit as their original release with the clear upper hull.
The changes are the following:
The clear sprue that contained the clear upper hull and turret parts is now in standard plastic
There is also a cut away sprue too
This should please both modellers who like to build the interior then hide it or the others who can now build a museum type display kit.
BE WARNED:
I have had chance to look through the instructions. The cutaway sprue is NOT REFERENCED in any way, and the builder must make their own substitutions.
ALSO, some interior parts will have to be altered such as the firewall and the upper hull support behind the driver/radio operator IF you use the cutaway. RFM didn't think about that one!
Still, this promises to produce some fabulous builds but spend time and PLAN your build, especially if using the hull cut out shell.
My dilemma is just how to paint the cut out portion edge red, and when!
Aber have brought out a metal barrel for this:
http://www.aber.net.pl/detal,1481.html
Which I have aquired this morning!
