I have a trick for you. I use the spray varnishes all the time and a legendary car painter taught me that if you take a large container of hot tap water (I use a big bucket) and let the rattle can sit in there for 15 minutes, dry off the can and nozzle and then shake it for 5 minutes the contents will be perfect for spraying. I do this every time and its never failed me.
The paint and carrier in the can gets smoother and atomizes better when its warm. Hot tap water is not enough to cause unexpected explosions (unlike throwing rattle cans in a fire or microwave) so you're safe there.
