P-40 Color Scheme Question
GAF
    June, 2012
Posted by GAF on Thursday, June 27, 2019 11:24 PM
I'm finishing up a Revell P-40B that's been sitting around for a few years, and I decided to go with something plain for the paint scheme.  I wanted to do a Pearl Harbor bird, and decided to do George Welch's P-40 "160".  I have the Airfix kit and will borrow the decals for that, but the question I have run into is how the underside neutral gray is painted under the horizontal stalilizers for this aircraft.
Now, as shown in this link (and on Airfix box art) the neutral gray underside curves up under the horizontal tail surfaces.
https://www.airfix.com/us-en/curtiss-p-40b-1-48.html
On other schemes, it shows the neutral gray straight across the bottom, and OD below the horizontal tail surfaces.
https://www.bravobravoaviation.com/1762-tm_thickbox_default/p-40b-2lt-george-welch-47th-ps-15th-pg-haleiwa-field-hawaii-7-december-1941.jpg
So which is correct?  Are there any extant photos of Welch's P-40, or at least other P-40s in the 15th PG?  Curious to find out.
I've already painted her up with the "curved" neutral gray under the tail surfaces, so I can correct it easily if the OD is there.
Gary
    February, 2016
Posted by lowfly on Thursday, June 27, 2019 11:31 PM
I would say the second one. I have never seen P40's with that "Curve" The lithograph in the second photo is probably more accurate due to the fact that the pilot probably signed off on it. just my cents
GAF
    June, 2012
Posted by GAF on Friday, June 28, 2019 12:23 AM
These "Life" magazine photos would tend to support that, but you never can tell what variations in painting may have taken place out in the field.  We'll see if anyone can come up with photgraphic evidence.
https://www.flickr.com/photos/35963591@N00/sets/72157622864527612/
Gary
    July, 2004
Posted by stikpusher on Friday, June 28, 2019 12:51 AM
Go,with the straight line. P-40Bs & Cs we’re produced in OD/NG or RAF camo depending upon intended end user. There would not have been repainting in the field like on P-35s and P-36s from NMF to OD/NG in late 1941.
here is a shot of the factory line ramp area.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
GAF
    June, 2012
Posted by GAF on Friday, June 28, 2019 1:13 AM
Thanks, Stik!  The colors aren't in question, just that minor discrepancy in the neutral gray.  I will note that I checked the Airfix instructions for the paint scheme and found they (unlike the box art) shows the OD under the horizontal stabilizers.  Guess the artist was taking some liberties, though I do wonder about why they showed it that way.  Oh, well!
Gary
    July, 2004
Posted by stikpusher on Friday, June 28, 2019 9:24 AM
I hear ya. I was not making my reply so much about the colors used, as to one of the replies that mentioned field applied paint jobs. The P-36s in Hawaii were in the process of being painted in OD/NG from NMF at the time of the Pearl Harbor attack. The P-40s arrived factory painted, fresh off the assembly line, so they would have no need for locally applied paint jobs. They were comparatively new aircraft, having just entered service.
       - Plankton
LSM
GAF
    June, 2012
Posted by GAF on Friday, June 28, 2019 11:20 AM
Well, never say "never"!  I found a couple of images that show the curved NG bottoms for the P-40s.
The blurb on the last page actually says that the early P-40s had the "curved" neutral gray scheme, but it doesn't say when they changed over.  So, what did the 47th Pursuit Squadron have?  Need to do a little research on Welch's P-40 and when it was produced.
Thanks!
Gary
    September, 2005
Posted by richs26 on Friday, June 28, 2019 11:56 AM
Only the P-40-CU's and re-winged P-40G's had the NG upsweep as they were painted before the new paint specs were released.  The P-40B/C's had the lower NG.  This is per Dana Bell's book, #5 P-40 Warhawk.  Only B's and C's were in Hawaii with only 12 C's there.  The B/C's are identified by having the fuel and oil fills located behind the left rear glass.
WIP:  Monogram 1/72 B-26 (Snaptite) as 73rd BS B-26, 40-1408, torpedo bomber attempt on Ryujo
Monogram 1/72 B-26 (Snaptite) as 22nd BG B-26, 7-Mile Drome, New Guinea
Minicraft 1/72 B-24D as LB-30, AL-613, "Tough Boy", 28th Composite Group
GAF
    June, 2012
Posted by GAF on Friday, June 28, 2019 12:10 PM
Richs26,
Thanks!  That's good info.  Guess I'll repaint the fuselage under the horizontal stabs. Smile
Gary
    September, 2005
Posted by richs26 on Friday, June 28, 2019 12:29 PM
And don't forget to replace the cranked British pitot tube of the R/M P-40 with a Curtiss straight arrow one.  Also make sure the US Army markings under the wing are dark blue, not black.
GAF
    June, 2012
Posted by GAF on Friday, June 28, 2019 12:37 PM
Well, let's not go overboard!  Stick out tongue
Gary
    January, 2014
Posted by Silver on Friday, June 28, 2019 2:28 PM
No one can match the exact colors.Its to long in time past.The art of modeling is to get as close as you can to the finish.Also in the detail department.Have fun building and painting.Museum WW2 aircraft are repainted with a beginners touch.Sharp lines an heavy glosses.
