Question about hand painting
Posted by Tojo72 on Tuesday, July 9, 2019 5:39 PM
I found that Vallejo Model Color line hand brushes very nicely,large color range too.Same applies what was said about thinning and good brushes.
    September 2012
Posted by GMorrison on Tuesday, July 9, 2019 5:40 PM
Ted-
Only 2?
Good advice.
    July 2014
Posted by Bakster on Tuesday, July 9, 2019 6:36 PM
Strongeagle
Ahoy Robert.  Watch this video and you'll never need an airbrush.
https://www.youtube.com/watch?v=BitmaECqO30
This guy has got skills.
This is a pretty clever technique. I think the downside will be the long drying time. I really love the finish and look to it.
    July 2019
Posted by Robert631 on Tuesday, July 9, 2019 8:16 PM
Strongeagle
t
wow, thats amazing. wish i could do something like that
    July 2019
Posted by Robert631 on Tuesday, July 9, 2019 8:23 PM
GMorrison
I see, that explains everything.
I would never criticize anyone for choices made to save money, and I will not do so. In fact, with a little experimentation, you might get that artists paint to work. I've used paint like that (Liquitex) on war game figures before.
But here, it's fighting you and causing the problems. It's made to be very gel-like, and usually in fine art brush marks are ok, even desirable. On a model, not so much, right?
Whether or not you invest in an airbrush, familiarize yourself with quality model paint.
The little Testors square bottles of enamel are really great. They thin out well and hand brush just fine.
Hope that helps.
BTW it's good you posted this. Hopefully you'll take a leap in results and like what you create.
Bill
once im done using the current paint ive got,ill try to look into testors and tamiya paints. id like to get spray cans but it seems theyre about $10 for one color can. a bit out of my budget.
    August 2005
Posted by Phil_H on Wednesday, July 10, 2019 12:29 AM
Robert631
I'd suggest that you not try to continue painting with what you've got. It's not ideal for model painting and will only cause further frustration.
If you're limited to brush painting, as suggested earlier, go for Vallejo Model color paints. Tamiya acrylics are so-so for brush painting (much better suited to airbrushing) and can cause frustration to new players. They can be brush painted, but require patience and  practice. Vallejo Model Color are much more brush-friendly.
    July 2013
Posted by steve5 on Wednesday, July 10, 2019 12:40 AM
what phil said .
Posted by Don Stauffer on Wednesday, July 10, 2019 8:26 AM
I did some brush painting yesterday on some tiny 1:700 aircraft.  Proper thinning made it work.  Thinning to the right mix is just as important for brush painting as it is for airbrushing.  I find I do not need as much thinner as for airbrushing, but it does need to be thinner than what is in bottle (especially for an old bottle).
Posted by Rob Gronovius on Wednesday, July 10, 2019 11:47 AM
Robert631
You can head on down to Walmart and check out their spray paint aisle. They have several decent types of paint, grab some olive drab, neutral gray and sand or tan paint. It is suitable for a beginner with a limited budget; about $5 for a can three times the size of a Testors can.
Paint the underside of the plane gray, upper surfaces with the green and hand paint the camouflage color. Or if you are comfortable, mask with low tack tape like the blue painter's tape. Make sure the paint has cured for a few days before using tape. And then spray with the tan.
If you let me know your modeling preferences, I can send you some kits you might enjoy.
    July 2004
Posted by stikpusher on Wednesday, July 10, 2019 11:47 AM
Phil_H
Robert631
If you’re goung to stick with acrylics, Hobby Lobby carries these Testor Paint sets that are ideal for brush painting. They are formulated for that, as opposed to their Model Master Acrylics, which are more airbrush oriented, and often require repeat coats. I just also suggest getting some better brushes. This paint set cost about $11 before the 40% off coupon. They are a great way to start out.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    July 2019
Posted by Robert631 on Wednesday, July 10, 2019 12:27 PM
stikpusher
Phil_H
Robert631
These are the current paints and paintbrush im using
the paint was $10 total from sams club and the brushs were $5 total from walmart.
didnt want to spend too much since im just starting out but maybe the lack of quality is biting my behind now
    July 2019
Posted by Robert631 on Wednesday, July 10, 2019 12:40 PM
Rob Gronovius
Robert631
I tried walmart the other day and the majority of the cans they had were for larger projects, like houses and larger peices of material. they did have a small section for acrylic spray cans but i wasnt sure if they were the correct ones for modeling.
if you have any beginner WW2 planes that uses one uniform color (no camouflage), that would be a good place to start for me. the camouflage i tried to do on the spitfire turned out pretty badly. im still trying to figure out how to wash the paint off and give it another try
    August 2014
Posted by goldhammer on Wednesday, July 10, 2019 12:50 PM
You can use either brake fluid, or an ammonia based window cleaner, or Easy-off oven cleaner to remove the paint .  Might have to do some scrubbing with an old toothbrush to get off stubborn spots.  None of the above will damage the plastic.  Wash well with water and let dry.
Just use common sense and try to do it outside and not breath the fumes from the cleaner.
    July 2004
Posted by stikpusher on Wednesday, July 10, 2019 6:28 PM
Robert631
The paints look to be artist type paints, and best used on canvas, paper, or some other porous material. They probably do not have the “tooth” to grab onto styrene very well. If you put a coat of primer on your models, those paints might work more effectively. But again, having never used that type before, that is an educated guess on my part.
The brushes that have the larger, stiffer , and coarser bristles will be less useful for this hobby.
       - Plankton
LSM
    July 2019
Posted by Robert631 on Wednesday, July 10, 2019 7:56 PM
yeah thats what i figured, ill make a trip to hobby lobby this weekend and pick up that $11 paint set you posted earlier. maybe some paintbrushes as well. much thanks
    February 2011
Posted by GreySnake on Thursday, July 11, 2019 9:19 AM
I’d suggest getting a hold of some spray cans. I recently got back into the hobby and didn’t have an airbrush at the time and used Tamiya spray cans for the base and Tamiya acrylic paint for the detail. Here’s a 1/35 JS-2 at the start of this year. While it won’t win a contest it’s better then what I could’ve done with a brush.
If you can get a hold of Tamiya’s brand of spray paint it dries really fast as it’s lacquer based.
    September 2006
Posted by the Baron on Thursday, July 11, 2019 11:56 AM
If you're on a budget, then I recommend the craft store brand acrylics, Folk Art, Apple Barrel, or Americana.  They are all water-based, so thinning and cleanup is very easy.  And they are very reasonably priced.  I get mine at Michael's and at AC Moore.  Both stores offer standing discounts.  So does HobbyLobby, who carries them, too.
You can also get decent brushes there, at reasonable prices, natural hair brushes.
As far as being able to achieve thin and flat (not matte, but flat) coats when painting by hand, as opposed to using spray cans, I painted this Maschinen Krieger armored fighting suit by hand, using Tamiya acrylics, thinned out with Tamiya's proprietary thinner:
I got coats as thin as if I had airbrushed them, especially the base color.  The camo spots are a little thicker in some places.  (It's in progress, too.)
Remember, it's just as easy to spray the paint on too thick, as it is to paint it on too thick by hand.  Thinning is the key.
    September 2006
Posted by the Baron on Thursday, July 11, 2019 12:03 PM
And here is an example to illustrate using craft store acrylics.  These are 54mm civilians that I painted, using craft store acrylics.
I primed them with Tamiya's Fine Surface Primer, to give the surface good tooth.  Then I used the acrylics thinned with water for the base colors-flesh, and clothing.  Then I used glazes made with a little water, a little Future, and a little color, to do the shadows in the folds of cloth, and the pick out detail on the faces.  Everything was then sealed with Future, for a classic toy soldier gloss finish.
I did use enamels to paint their eyes-Testor's gloss black.  The enamels stay wet long enough for me to apply the lid lines and the pupils.  In such small amounts, on the small brush that I use for that detail, acrylics dry almost immediately.
Posted by Rob Gronovius on Thursday, July 11, 2019 12:25 PM
Robert631
The bigger rustoleum cans in military looking colors will work fine. Send me your address and I'll see if I have some WW2 aircraft to send your way.
You don't "need" to paint them in camouflage. Use them to practice in a solid color or practice using various methods to do a paint scheme. But you should have a good base coat to add the scheme on top of.
