@Danburnsart...........a few more photos for you :)
My shed (6x8 external) sits on a small decking area alongside another shed which has all the garden stuff in it. Area is pretty shaded as it sits under an oak tree so doesn't get much direct sunlight.
I have run electric out to it from the house, small white cable running in top left side, runs into an isolation switch just inside the door. This way the whole shed is not 'live' when I'm not in there....
I live in the south of UK so need to insuated the shed for winter-time use (may not be as cold as montana in winter but still cold enough!) I bought a bunch of cheap polystyrene sheet (1" thick) and then lined the whole inside of the shed (walls/floor/ceiing) with it then covered up/lined with 1/8" MDF or similar.
Inside is just made using left over/junk drawers, shelving. Table top is the side of an old wardrobe! this was all done on the cheap, the shed itself being the most expensive item! I have a small cheap fan heater set at 20c (about 70f I think) for evening and cooler weather sessions.
I have 2 LED strip lights and a small freestanding light/magnifier........need as much light as reasonably possible. Seriously running out of room on this shelf and so thinking of enlarging it more and facing it with a clear perspex sheet to cut down the dust.
Custom made a paint rack(s) for the paints and have a good old spice rack for the other bottles of stuff (glue, varnish, washes etc etc)
Let me know if I can be of any other help
Stay safe........Steve
Currently on the bench: On the bench: Airfix 1:24 Spitfire Mk IXc (17001) as Silver Spitfire G-IRTY, Revell 1:48 Bristol Beaufighter TF.X (03943)
Finished 2024: Tamiya 1:24 Ford Mustang GT4 (24354)
