DiscoStu
Of Models & Monsters
I'm relieved you mentioned that cause I thought it was my fault that it wouldn't fit right. Anyway I did what I could.
Interesting. Wonder if it's a flaw common to the kit.. I'm having the same issue on the P-400 on the bench right now. It has me at a stopping point as I work on a solution.
DiscoStu, if you're building the Hasegawa Bell P-400, when you go to attach the canopy you will need to squeeze the fuselage a little until the edge if the canopy and the fuselage edge match. Then you can glue the canopy to the fuselage. I had to hold the two together with a couple of Harbor Freight plastic clamps until the glue had set overnight. I used Tamiya Extra Thin to attach the canopy.
