Tamiya, Why You so Crazy?
    April 2015
Posted by Mark Lookabaugh on Tuesday, August 4, 2020 9:12 AM
I'm working on the Tamiya 1/700 Prince of Wales battleship.
Don't get me wrong, I'm all about fine detail, but some of the parts on this kit are just ridiculously small.  The pic below is of the float plane pylon.  It's so small that I had to get out the optivisor and a specially-ordered pair of needle tip tweezers to handle it.
I was on guard against lost parts, so I was working over a large white platter and using adhesive on the tweezers.  Even still, because these are so light, one went flying away into the void never to be found again.  Not even sure how to craft a replacement because of the size.  ARG!!!!!
Posted by Tojo72 on Tuesday, August 4, 2020 9:30 AM
Brutal, just brutal,pure torture.
About the size of the drop tank on my Hasegawa 1/350 Zeros, all six that I built.
    July 2014
Posted by modelcrazy on Tuesday, August 4, 2020 9:53 AM
Ha! I laugh at your tiny airplane part size Big Smile The interior of a 1/350 Zero
25mm type 98 AA gun
Steve
    September 2006
Posted by the Baron on Tuesday, August 4, 2020 10:26 AM
Mark Lookabaugh
Don't get me wrong, I'm all about fine detail, but some of the parts on this kit are just ridiculously small.  The pic below is of the float plane pylon.  It's so small that I had to get out the optivisor and a specially-ordered pair of needle tip tweezers to handle it...
I think that's a big reason that 1/350 and larger scales have become so popular for ship modelers.  The model can have more detail, too, but it's a little easier to see than working in the smaller scales.
If you want to see some real fiddly work, look for the 1/1200 kits that some guys super-detail.  I'm amazed at guys who take an old Pyro Table-Top Navy kit, for example, and refine the detals, even to the point of rigging a model that's about 8 inches long.
    May 2011
Posted by Real G on Tuesday, August 4, 2020 1:24 PM
See, that is why 1/700 should be rightfully called “the Devil’s scale”!  1/72 gets a bum rap; 1/700 is way more crazy.
I just got in the new Fujimi 1/700 Hiryu and accessory detail set, and the AAA guns are insanely small.  I’ll get pics up on my Hiryu thread.
“Ya ya ya, unicorn papoi!”
Posted by Don Stauffer on Wednesday, August 5, 2020 7:24 AM
the Baron
Mark Lookabaugh
On the other hand, there is a guy in the ship forum that builds (scratch builds) ships in really small scale.  He has started a thread on a 1:1500 scale cruiser he just completed- check it out.
    December 2003
Posted by scottrc on Wednesday, August 5, 2020 7:32 AM
Mark Lookabaugh
Ya, that strut on the pylon is way out of scale, so I would replace it with a PE strut.  Also add the guy wires to the Walrus for added detail.
Make a replacement pontoon out of a drop of expoxy or CA.
Instead of tweezers, I use a toothpick with the end wetted or dabbed with white glue that holds the small part enough to position it.  I had way too many parts shoot off into never never land.  Always cut your parts on a piece of tape and a finger over the part too.
Are you using any PE parts like radar or guns?   Once you tried a few of them in 1/700, then you will define crazy, buts its well worth it.  Building in 1/700 has actually helped with the control of my hypertension.
    October 2004
Posted by ikar01 on Wednesday, August 5, 2020 8:50 AM
Helped to control it?  I would have thought that it would increase that problem.  In my case the hyper tension is increased with the problems encountered with the smaller scale.  I have a few 1/700th kits that I have been considering getting rid of and not getting a ship smaller that 1/350th.
    July 2014
Posted by modelcrazy on Wednesday, August 5, 2020 8:57 AM
I have a ton of 1/700, some of which I could get rid of. The problem is, some kits can only be found in 1/700. I need to look through the stash and sell the ones I can get in 350.
Steve
    October 2019
Posted by Tanker-Builder on Wednesday, August 5, 2020 8:57 AM
Hmmm;
 I do like the last action picture in your post. Looks like my cat when something goes Zoom out of the pliars. Just that my cat disappears in the shadows. She's a Sport Siamese. All Black with a shorter than normal tail.
    July 2014
Posted by modelcrazy on Wednesday, August 5, 2020 10:18 AM
Thanks TB
Steve
