Instruments-For the sake of realism
    October 2019
Posted by Tanker-Builder on Sunday, October 9, 2022 7:51 AM
Cars and planes, and some Armor, for sure!
      Intruments! They can add a tremendous visual for the observer! Now here's the thing. Many are molded in such a way, if you enlarged them they would make no sense at all! The method I use is one some others have used in the past, and I think is a good one.
      For the general instrument in the Plane or Armor I use the same guages used in Cars. Why? Well, think about it. In analogue guages which are the most common? Fuel, R.P.M. Oil Pressure and Amps. if I don't miss my Guess, Right?
       Beautiful Guages can be had by the model cars. Another nice thing, P.E. Guage Bezels. Now that will make them stand out too. Plus the bezels can be mounted with a touch of clear paint and then when dry, you can go back and use, Canopy glue, Elmers, Aleens or The good old Clear paint or Floor gloss.
       Building your panels from scratch would help too. That way you can do them one at a time and the look will blow the compatition away. Of Course, as with anything you do, do it to the best of your Ability.You won't be disappointed!
    March 2022
Posted by missileman2000 on Sunday, October 9, 2022 10:41 AM
There are differences between gauges used on aircraft and cars.  Most aircraft white symbols on a black background.  There are a few of the reverse, but rare (ie Piper).  And bezels are universally black or very dark flat gray. There are two types of bezel, one just a thin black circle on instruments installed from behind panel, and the other a bezel that may be used in the mounting.  These are cast bezels, and have most material on cabin side of panel.  But they are flat black or dark gray  Flat metal can be used with the kind mounted from behind, as long as they are dark.  This type of mounting should show mounting screws.
I have compiled a number of aircraft instruments from google searches, and can print these on photo paper and stick behind holes drilled in panels.  I'll maked up a group image and post that later.
    October 2019
Posted by Tanker-Builder on Sunday, October 9, 2022 4:29 PM
Hi Guy!
         Ah! I should've gone into more detail. I sorry! I was just trying to show for somepne who wants the detail, but for whatever reason has no research or doesn't want to get that serious. Someone who loves flying, but who knows little about planes and wants his model to be a work of art anyway. Yeah, come to think about it I should've clarified that and I didn't.
    June 2018
Posted by DRUMS01 on Sunday, October 9, 2022 4:37 PM
I think if your talking about 1/48 or smaller you may get away with car decals for aircraft gages in most cases, so I sort of agree with your statement.
But I believe aircraft 1/32 or larger need aircraft specific decals. Now I am not a rivet counter but I think an altimeter, artificial horizon, or speciality gages can be easily seen and only be replicated with the real thing, especially if their is a clear view through the canopy.
Other than that I think your spot on with individual gages, displays, bezel, etc. they can be a game changer.
Then there's stuff like Quinta 3D cockpit decals and others. While most are awesome, some seat harnesses that are full 3D suffer a little on the metal components of the harness, especially if they are conforming to the curves and details of the seat.
Just my humble opinion
Regardless, todays aftermarket offers so much more than just a few years ago. We are indeed lucky to be modeling in this era.
"Everyones the normal until you get to know them" (Unknown)
LAST COMPLETED:
1/35 Churchill Mk IV AVRE with bridge - DONE
NEXT PROJECT:
1/35 CH-54A Tarhe Helicopter
    April 2020
Posted by Eaglecash867 on Sunday, October 9, 2022 5:44 PM
Airscale makes really good instrument dial face decals.  They look really good, but I have found that you usually want to go one scale smaller.  For a 1/32 aircraft panel, the 1/48 decals are a better fit as the 1/32 scale decals are just slightly too large to fit within the bezel in most cases.
It is mostly military aircraft that have front-mounted instruments in them due to easier removal for maintenance...that is, as long as the aircraft manufacturer left you enough rope to pull them out far enough to disconnect them.  Some of them, like UH-1s, have everything front-mounted, but pitot and static lines are aluminum tubing.  That's OK though, pretty easy to reach up behind the panel on those to disconnect the tubing/fittings.  Or you can go in through the access panel on the nose.  In the civilian world, there are a few exceptions to the rule of seeing screws with back-mounted instruments.  In a 1955 Bonanza, for example, the nuts are captive on the back of the instrument panel, and you actually have to use a long screwdriver to go from behind the instrument and take the screws out...after removing the firewall kidney panel of course.  The surface of the panel inside the aircraft though is totally smooth.
Love the Quinta stuff too, so I use that whenever they have a set available for the aircraft I'm building at the time.  I've tried a few other brands of 3D printed cockpit decals, and nobody else comes close to Quinta yet.  Since they're thin and flexible, they're easy to cut up and rearrange too...so you can turn an Su-25K into a Ukrainian Su-25M1 with the help of a little Evergreen plastic and your imagination.
"You can have my illegal fireworks when you pry them from my cold, dead fingers...which are...over there somewhere."
    October 2004
Posted by ikar01 on Monday, October 10, 2022 2:53 PM
I would usually use deecals for the instruments but I still have some of the Waldrton instruments and die punch sets that I use depending on the project.
The die punch sets have come in handy for certain other projects I have done and not alwways because of instruments.
