1/48 Italeri MH-60K Blackhawk
    April, 2015
Posted by Wolfman_63 on Sunday, July 08, 2018 3:17 PM
Starting on Italeri’s 1/48 MH-60K. With this build I will be using Eduard’s “Big Ed” detail kit. Beginning with the cockpit I added the photo etch parts to the floor and console. As I started on the seats I noticed that the rear of the seats on the reference photos have a bin and bracing as well as a first aid bag behind headrest. Using some stock styrene sheets and rods I made the braces. I used a small piece of nylon cloth to make the first aid bags.
Website:
David's Scale Models - https://www.davidsscalemodels.com
    December, 2002
Posted by Bish on Sunday, July 08, 2018 3:22 PM
Nice start, some good work on the pit and nice scratchbuilt additions.
'I am a Norfolk man, and i glory in being so'
On the bench: Hasegawa 1/72nd Ju 188A
                      Fine Molds 1/72nd Me 410
    July, 2004
Posted by stikpusher on Sunday, July 08, 2018 4:13 PM
on pretty much any MH type, you can paint the interior of the cockpit any color you like. As long as it’s black. Special Ops birds do much of their work at nite with the crew wearing NVGs so the interiors are painted accordingly.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    December, 2002
Posted by HeavyArty on Sunday, July 08, 2018 6:35 PM
Yup, everything forward of the step up in the floor is flat black; floor, IP, walls, ceiling, seats, everything.  This goes for all modern H-60 helos (pretty much all others too).  It is for night flying and the use of NVGs.
Check out my Gallery: http://smg.photobuck...v231/HeavyArty/?
    April, 2015
Posted by Wolfman_63 on Tuesday, July 10, 2018 3:57 AM
Thanks! I will correct it.
Website:
    December, 2002
Posted by HeavyArty on Tuesday, July 10, 2018 6:49 AM
Just noticed that your left seat collective is misplaced.  The collective goes on the left side of both seats.  You have both inboard against the center console.  The shiney rectangle in the lower left of the below pic is where the collective goes.
Also, disregard the painting directions and markings/decals in the kit as they are totally wrong.  The MH-60K is only used by the US Army's 160th SOAR (Special Ops Aviation Regiment) and is only painted flat black with OD markings.
The correct decals can be sourced through Werner's Wings with their NIGHT STALKERS-PART 2- GOTHIC SERPENT to Present decal set.  It has markings for 3 MH-60Ks, one being the correct gray test scheme.
    April, 2015
Posted by Wolfman_63 on Friday, July 13, 2018 4:51 AM
Moving forward after some corrections the cockpit section is almost done. I scratch built the fire extinguisher and painted the cockpit section the correct color. I then started work on the crew area. The photo etch comes with the support cables for one side of the crew seats and I used 32 AWG wire to replicate the other side. The molded in seat belts were  removed. I will make new seat belts out of cloth tape. I am working on making the turn buckles that go from the top of the seats to the supports. Need about 20 of them. Still have lots of details to add to the crew area.
Website:
    December, 2002
Posted by HeavyArty on Saturday, July 14, 2018 1:15 PM
Looking much better.  A few tweeks though.  The seat cushions and collectives should be all black as well.  Everything forward of the step on the floor is black, everything
    April, 2015
Posted by Wolfman_63 on Monday, July 16, 2018 2:51 PM
More details on the crew cabin being added. Seat belts and turn buckles done. Working on the cabin roof. Need a few more details to be scratch built and some more photo etch to be added. Also the decals I ordered for the paint scheme arrived today. They are the Werner’s Wings decals representing the aircraft from Operation Gothic Serpent from the 160th Task Force known as the Night Stalkers. Includes markings from the infamous “Blackhawk Down” operation.
Website:
    December, 2002
Posted by HeavyArty on Wednesday, July 18, 2018 2:05 PM
Nice job on the seat attachments and the PE work. By the way, all the PE pieces should also be flat black.  See a trend here?
Which Werner's Wings decals did you end up getting?  Just a note, there were no MH-60Ks deployed to Somalia in '93 as they were not fielded until '94.  The final MH-60K was retired on 19 Nov 2014 as well.   The MH-60Ks and MH-60Ls were replaced by the newer and more capable MH-60M.
    April, 2015
Posted by Wolfman_63 on Saturday, July 21, 2018 8:50 PM
The Italeri 1/48 MH-60K cockpit and cabin ready to install into fuselage. Working on the adding details to the fuselage. Many of the vents and grates need to be cut out and replaced with photo etch details. Should be ready to close up fuselage soon.
Website:
    December, 2002
Posted by HeavyArty on Monday, July 23, 2018 11:10 AM
Coming along.  One note though, the places you have the yellow straps, for handhold I am assuming, are not correct.  On the actual aircraft there are thick, structural bulkheads here that cover the landing gear leg and walls.  There are no handhold straps there.  The PE pieces that you attached to the front of the roof section represent the front end of the bulkhead around the gunner's window.
Rear side walls.
Gunners' bulkheads.
    April, 2015
Posted by Wolfman_63 on Tuesday, July 24, 2018 4:23 AM
Yes I know there is a bulkhead over the landing gear. However the kit nor the PE set has these parts. When you build your kit, feel free to scratchbuild them. As for the handholds, they are on the reference photos I have. A couple of years ago we had a Blackhawk land in the parking lot at work during a 4th of July celebration. I took many photos while it was there. While it may not be typical of a Blackhawk on a mission and I am not exact on which version the aircraft was, It is what I used for reference.
While I am always open to critiques, comments, and suggestions, it does start to get annoying when every post the same person keeps nit-picking every step. Feel free to start counting rivets.
Website:
    December, 2002
Posted by HeavyArty on Tuesday, July 24, 2018 7:04 AM
Sorry you are upset over help and advice and that noone else is replying to your thread.  Your model is looking great and I am just trying to assist in making it better.  To me, if you are adding all that PE and stuff, why not go the extra mile and finish detailing it.  You can build it as you like though.  I won't give any more advice as it seems to upset you.
    April, 2015
Posted by Wolfman_63 on Tuesday, July 24, 2018 4:01 PM
I never said I was upset, just a little annoyed that with every update you bring up every little detail. As I stated I am open to critiques, comments, and suggestions. As an example I followed your recommendation for the Night Stalkers 2 decal set and purchased the set you posted. I will be painting it as Option 11 on the sheet. I reviewed other references and corrected some noted issues. However, you have to admit calling out every detail every time a builder posts an update can become annoying.
It does not bother me if anyone replies or not. That is their own choice. Many folks like to surf forums to get ideas for their own builds or see how others do things but never really post or reply much. I did it for a number of years as well.
Website:
    June, 2018
Posted by DRUMS01 on Wednesday, July 25, 2018 12:11 AM
I have to say that this is a real nice build and fun to follow. I've prepared the popcorn to watch this one till the end.
v/r,
Ben
I am a veteran; to all others thank you for your service. I hope you found peace after your tour of duty, you have earned it...
PROJECTS:
- 1/48 C-130 - Staged
- 1/16 Kubelwagen (GB) - Started
- 1/350 HMS Roberts (GB) - Done
- 1/35 STRV -103 MBT (GB) - Done
- 1/48 X-15 (GB) - Done
- 1/48 Eagle Lunar Module (GB) - Done
    December, 2017
Posted by Returner43 on Wednesday, July 25, 2018 6:43 AM
Really like the build so far. Can't wait to see more updates as it's progresses. Still learning to work with PE parts myself without damaging them depending on the part.
I do enjoy this community and often browse though a lot of old posts. More often than not I find the answers to what I'm looking for.
One thing I have learnred over the years is that the plastic modeling community can be very detail oriented, sometimes to the point of being anal about some details that the average person would never notice.
In many cases though, when you are building to the level of detail that you are, they might just assume that you are trying to be as accurate as possible and point out those details. You do have to learn to develop thick skin as some members just point out too many things at times and you just have to accept that once you ask for criticism it opens the floodgates for all kinds unless you specify you just want comment on build quality and not focus on accuracy.
Haven't done it in years but I used to post pics of my builds with colors, accessories or modification that were way off and sit back and enjoy the madness that would sometimes ensue from some users losing their minds over those things.
It can feel overwhelming at times but the vast majority of users do have a real passion for these vehicles so they are very, very, very peculiar about the details.
Adding this to my favorites to see the progress. I have only built a Cobra and a Jolly Green in my modeling timeline and seeing yours has been thinking it's time to built another.
    April, 2015
Posted by Wolfman_63 on Friday, July 27, 2018 5:30 AM
The continuing work on the 1/48 Italeri MH-60K Blackhawk. Fuselage together, starting to add photo etch details to the outside of the fuselage. It is slow going as there are over 170 pieces to add. The bottom and nose of fuselage is done. Working on the top and sides now. Still need to do the boom, some more on tail, and the main rotor.
Website:
    April, 2015
Posted by Wolfman_63 on Saturday, August 04, 2018 6:02 AM
After many hours of trimming, folding, and bending the numerous photo etch parts for the fuselage are now installed. Some minor finishing and some minor filling then the fuselage will be ready for painting. Still have some items left to build and detail like the main rotor, doors, and the machine guns.
Website:
    December, 2002
Posted by HeavyArty on Sunday, August 05, 2018 8:05 AM
It is coming along well.  Nice PE work.  One issue though, with that nose radar setup, it is not an MH-60K, but an MH-60L.  The K model has a totally different nose radar setup, like the pic below, along with a few other differences like the sensors on top of the front canopy.
    April, 2015
Posted by Wolfman_63 on Wednesday, August 08, 2018 4:07 AM
Yes, I found out the kit I bought "short shot" two "unused" parts. One of them was the K nose. The instructions tell you it is unused and has you install the L nose. The instructions are incorrect. I have a replacement part being sent to me. Should be here Friday. Already removed the L nose.
The sensors above the canopy are part of the photo etch set. I have not put them on yet because the  top windows need to be installed first and I have not put the clear parts on yet.
Website:
    April, 2015
Posted by Wolfman_63 on Wednesday, August 08, 2018 4:10 PM
Normally I'm a happy kind of guy. But today I am very not very happy. You may have been following my build of Itarei's 1/48 MH-60K Blackhawk SOA. Well the instructions have you install the MH-60L nose. So on one of my posts I was informed that the kit does supply the correct nose. So I looked and the part was missing. I contacted Italeri and they say to confirm part and it would cost 5 euro's to get the part and 20 days shipping. Well I used a coupon and purchased another kit due to time and figured later I can build a MH-60L.
Guess what???? On the newer kits Italeri REMOVES THE PART or has blocked it from being molded!!!!!!
If anyone has an older release of this kit and your tree has part E25 or if anyone knows of a resin replacement, Please contact me. The build is going to be on hold until I can locate the correct KILO nose.
Website:
    April, 2015
Posted by Wolfman_63 on Thursday, August 09, 2018 4:09 AM
Update - Using the power of Facebook groups I have had three others check their kits they had in their stash and they are all missing the same part.
Website:
    December, 2002
Posted by HeavyArty on Thursday, August 09, 2018 9:55 AM
That sucks.  Cobra Company did sell an MH-60K conversion set in 1/48, #CC48002, but they are now out of business.  Lone Star Models bought CC's masters and is slowly releasing them, but the MH-60K set is not currently on their site.  Keep checking there or maybe drop them an email to see if/when they may release it.
Lone Star Models:  http://www.lonestarmodels.com/store
CC Set:
Good luck.
    April, 2015
Posted by Wolfman_63 on Friday, August 10, 2018 4:15 AM
So here is where I stand, Lone Star Models does not know when it will get to the MH-60K set. I contacted them. I found out that Italeri stopped molding this part. Many modelling friends on Facebook have looked in their MH-60K kits and the part is missing. The kit was released back in 2007 and the kit did include this part. It appears that sometime around 2012 Italeri stopped molding this part. It is the only part that is not in the kit.
A fellow modeller in Turkey has the K nose. The kit he has was molded in black. This may be the old RoG version (which Italeri used). He did not use the nose and has shipped the part to me. Not sure of shipping time from Turkey to U.S. so I will be doing some of the smaller details (main rotor, the guns, side doors, etc.). It is actually OK since next week I have two sons who are are going back to college and there is some travel involved.
Stay tuned.
Website:
    April, 2015
Posted by Wolfman_63 on Saturday, August 11, 2018 2:09 PM
So after realizing the Italeri kit does NOT include the correct nose, I surgically removed the “L” nose. Utilizing the numerous modeling forums and groups I was finally able to locate the correct nose from a fellow modeler in Ankara Turkey. The correct nose should be here late next week.
In the mean time I am working on the smaller details. Main rotor, machine guns, side doors have been detailed. Corrected the placement of the smaller antennas and started to base coat the model and rotors. The kit decals only have the black lettering for the warnings and such so I scanned the decal sheet in and changed the colors to the dark olive color used on the 160th Night Stalkers aircraft.
Website:
    April, 2015
Posted by Wolfman_63 on Tuesday, August 21, 2018 4:05 AM
The nose has been received! Back to work this week. Will have an update with photos later this week.
Website:
    December, 2002
Posted by HeavyArty on Wednesday, August 22, 2018 9:09 AM
It is coming together nicely.  The rotor head and blades look great.  The correct nose should look great as well.
Wolfman_63
In the mean time I am working on the smaller details. ...machine guns...
On the MGs, all 160th SOAR helos mount M134 miniguns, not M60s as the kit would have you add.
CMK and Mini World both make 1/48 M134 minigun sets.
    May, 2009
Posted by Pawel on Wednesday, August 22, 2018 3:13 PM
Hello!
I have used 1/72 Mini World miniguns and they were amazing, very detailed and they are cast brass. Exquisite stuff, but pricey, too. That could be a reason, why you might want to consider the CMK set.
Good luck with your build and have a nice day
PaweĊ‚
www.vietnam.net.pl
    April, 2015
Posted by Wolfman_63 on Thursday, August 23, 2018 8:20 PM
The MH-60K is now complete! Overall an OK model. I really still cannot believe Italeri purposely does not include the K nose. I have had many respond that their kits do not have the part as well. The only other thing is the cockpit clear parts do not fit very well. Took a lot of shaping to get them to fit OK. If I ever did another one I would fill the edges and then trim to fit the clear parts. With all the photo etch already installed I was not able to do it. The Werner’s Wings decals are awesome. They went on easily and just the right thickness.
Website:
