Helicopter; Seams ?
    April 2009
Helicopter; Seams ?
Posted by stretch_5 on Friday, February 14, 2020 10:11 PM
Hello All.  I don't build helicopters too often but I am currently working on a Royal Navy Westland Lynx Helicopter and was wondering what seams need to be addressed?  I attached two pics here with toothpicks pointing to seams on the bottom of the chopper that I am not sure if I need to fill or not?  please help :)
https://youtu.be/lrBN0RsuhHA
    August 2014
Posted by goldhammer on Friday, February 14, 2020 11:24 PM
Know nothing about the Lynx, but would assume smooth skin, maybe panel lines.  The smaller of the two you can probably fill and sand with putty.
The big gaps might have to glue in thin styrene strips, or heat and stretch some sprue frame to the appropriate size and glue in.  When good and dry trim with a knife and sand flush.
Then rescribe any panel lines.
    September 2012
Posted by GMorrison on Saturday, February 15, 2020 12:54 AM
Like Goldie, I don't know too much about those things that just pretend to fly, but this pic shows a really smooth underside.
If anything, there's a break where the sponsons attach to the tub of the helo, But the geometry of the model looks to have those be kind of flush across the bottom, where the actual one there; they kind of stick out of the sides like wings.
I think it's just not a well designed area of your kit.
I'd eliminate all of the gaps/ seams.
Modeling is an excuse to buy books
Posted by HeavyArty on Saturday, February 15, 2020 7:42 AM
There should be panel lines present where the sponsons meet the fuselage.  Usually, just liquid glue will seal up the joint enough to represent the panel line well enough and you won't need to use an additional filler.
Check out my Gallery: http://smg.photobuck...v231/HeavyArty/?
