Amodel Ka-18 1/72 diorama !! the most (un)know chopper in the world (helo finished page 3)
    October 2008
Posted by bsyamato on Wednesday, May 4, 2011 7:11 PM
long time not write something in this section.
Finally bought another two helicopter , the unknow wasp from airfix and this famous russian helicopter...
... i confess , before to see the amodel catalog never see it in other places Tongue Tied
but was love at first sight Embarrassed
it remind me my daddy old fiat 500 giardinetta. Even the doors is hinged on rear!
it's a civilian copter developed from the smaller ka-15 and used as taxy service (used even by russian army but not in combat missions)
then this is the kit out of box
Photobucket
i realized the real size of the kit only when i opened the box Indifferent
Photobucket
Photobucket
the quality of kit are greater than a short run, but less than a good mass production kit.
fitting is not so good and lots of flashes on pieces, but nothing that can fear an averaged modeller.
decals are good printed but a good final test will only after used it.
Photobucket
Few references on the web but on airliners.net i found even a picture of the ip.
Actually i'm very busy with four group build but i'm too fashinated by this subject then go on with works!
glued the cockpit floor to the rear bulkheads and the (avionics or gearbox) box in the middle,
used the two fuselages to aid the right position for the pieces.
Photobucket
and after released the pieces from sprues and lots of flashes glued the tail pieces
Photobucket
Photobucket
test ftting for forward seats, the ip panel is in acceptable detail level, but not have pins for easy fixing.. Tongue Tied
seats need to be lifted few millimeters, and need to be shaped correctly
Photobucket
Photobucket
that's all for now, i hope to do a speed built but some scratchbuilt is needed
Tags: ka-18 kamov
    October 2008
Posted by bsyamato on Saturday, May 7, 2011 11:10 AM
little update
putty on
seat shaped compared to the original
details of pieces on sprue a little merged with Tongue Tied
go down to made more!
    February 2011
Posted by MAJ Mike on Saturday, May 7, 2011 11:37 AM
As usual, it looks great.
 "I'd "I'd rather be historically accurate than politically correct."
"Sic gorgiamus allos subjectatos nunc!"
    October 2008
Posted by bsyamato on Saturday, May 7, 2011 7:04 PM
thanx Mike , this little one will give me more problems that as usual,
but want to see it finished!!!
thinking at a little diorama like this picture
then little copter little update
added some piece of brass to increase the height of seats and try to put the seams of padding
and glued the first rotor, the strange plastic used in this kit mades blade hard to break easily ,and glue good ! (point for amodel) but lots of work needed to remove flashes, one of trims and a pin in the blades (a balancer i presume) was not molded!! need to scrath after
at the next
    October 2008
Posted by bsyamato on Sunday, May 8, 2011 5:01 PM
updates
glued second rotor
these are others pieces that i should glue on the rotors Hmm mh... in mind to replace something
all seats with seams to test fittings
sanded the rear central consolles, withouth this the rear seat was touch the fuselage walls
with the eighted seats the rotor bar touch the pilot seat then i replaced original pieces with brass rod , tape and replaced pedals too
for now that's all, today counting to start painting
    February 2010
Posted by Stage_Left on Monday, May 9, 2011 6:51 PM
Very nice work....
    October 2008
Posted by bsyamato on Friday, May 13, 2011 7:11 PM
Stage_Left
Very nice work....
Thanx!
Some update
sanded some frame on clear parts to aid paint grip
and finally start painting
Seats need to be darked with drybrush and black washing.
ip is the original part, is not too different from real, so i can save some scratch.
    May 2009
Posted by Pawel on Friday, May 13, 2011 7:22 PM
Oh yeah, I heard Kamov OKB (design bureau) was to Mil OKB what Caddilac was to a Buick :D
Keep up your excellent work!
Paweł
www.vietnam.net.pl
    October 2008
Posted by bsyamato on Tuesday, May 17, 2011 7:13 PM
good metaphor to describe the two Manufacturers Cool thanx for comments.
Started to study diorama and modded two little figures (shhh Whisper are 1/87 not in 1/72) from preiser, i'll put two passengers in the cockpit :
and painted other pieces
one of few pictures on web of the little kamov is the cockpit, after study a litte the original ip is wrong Crying
then under with evergreen sheets
main error is in eight, i'll used 3 layer to give rigth thickness to the ip
that's all for now
    October 2008
Posted by bsyamato on Thursday, May 26, 2011 7:14 PM
little update, last pieces on the ip
at the end needed 3 plastic sheet pieces
and added a metal handler... probably an holder for passengers Big Smile
    June 2009
Posted by kermit on Saturday, May 28, 2011 10:49 PM
Silvio,
EXCELLENT scratchwork, as always!YesYes. I just love how you take cheap, ill fitting models and double the parts count by adding your styrene nand metal bits. On top of that i think you have chosen a very interesting, seldom modeled subject. I just love the double rotors on the kamov choppersBig Smile
Your idea for a diorama is very interesting too. And shouldn't be that much work since this is a very small model. Have you got the figures and stuff for it already?
The only sensible thing i can say about that right now is that if you should decide on a concrete airfield setting, make it look like grass is coming up inbetween the concrete slabs, cracked concrete and worn painted lines on it. From what i have seen in books and films i know that most russian gear is built to take a beating and be used on terrain just like that...
Good luck on your build and i will be watchingWink
Richard
"Success is the ability to go from one failure to another with no loss of enthusiasm." - Sir Winston Churchill
    October 2008
Posted by bsyamato on Sunday, May 29, 2011 9:56 AM
thanx for comments richard Big Smile but here refere to me just as bsyamato Embarrassed actually someone mud this name in italy!
i have lots of things to build a diorama, unfortunately not foun actually 1/72 civilian figures Surprise
I choice this little helicoptes because i like the strange old desing and.. i don't know it before i see in amodel catalog!
For the diorama in mind to do a rural setting, this as others russian copter ,was used to connect lands hard to reach with other veichles.
then no airfield, probably some little concrete surface ,but most grass. Then a sort of irregular surface.
The two figures are in 1/87 scale and fit really hard inside. Also have some animal and some other figure i can obtain from airfix/preiser/esci/revell 1/72 figures i have.
Recenlty someone give to me some balsa wood stips that can be used as prop build!
At the next update Big Smile
    June 2009
Posted by kermit on Sunday, May 29, 2011 10:13 AM
My apologies sirZip it! I do know who you are referring tooSmile . You are planning prop blades out of balsa in 1/72?? Can't wait to see you pull that one offYes Have fun my friend.
Richard
    October 2008
Posted by bsyamato on Sunday, May 29, 2011 10:27 AM
kermit
Richard
no no! not prop blades Big Smile calling props as some object in diorama, some wall or something other Yes
    October 2008
Posted by bsyamato on Monday, June 6, 2011 7:03 PM
some update
finally painted and glued the ip
only the two people i put inside avoid me to glue fuselage Big Smile
looking at the main cockpit i drammatically decided to heatform one better Sad
after 5 attempt get a good result surely better than original
put the original on a support
and one of tries
comparing to original
lots of cuts needed but this is the result, also graved the frames.
too clear Indifferent now can see all inside Cool
at the next
    May 2009
Posted by Andrew Magoo on Tuesday, June 7, 2011 7:17 PM
Building helicopters in 1/72 scale is a challenge no matter the subject. That being said you sure have a handle on this subject. So far excellent work, I'm waiting to see the finished product, Magoo
    October 2008
Posted by bsyamato on Friday, June 10, 2011 3:07 PM
thanx for cooments Andrew, hope finish soon me too Cool
Just bring priority on some gb i'm ivolved
    March 2010
Posted by Hercmech on Friday, June 10, 2011 3:11 PM
You are making great progress. One cool little whirly bird!
13151015
    October 2008
Posted by bsyamato on Friday, June 10, 2011 3:40 PM
thanx Herc Big Smile
    October 2008
Posted by bsyamato on Monday, June 13, 2011 5:27 AM
More update!
Finished to paint the figures and closed fuselage
under tape tension
and good point progress
now need a good putty work
    October 2008
Posted by bsyamato on Friday, June 17, 2011 6:26 AM
some update:
also added the little copter to Made In USSR GB !
Added an ip panel on the canopy celing
gluing canopy to the fuselage with white glue (vinyl glue) and all other pieces for preparing to the paint stage
Started the diorama terrain, modelling clay textured with a brushtooth
first layer of 140 humbrol as primer
Lots of putty again needed on the canopy, also the semicircular pieces on it was shaped with cutter in different way, original shapes was wrong.
that's all
thanx for viewing
Posted by VanceCrozier on Friday, June 17, 2011 6:58 AM
Wow! I'm not surprised at the detail you're able to squeeze in there! I recently found Airfix's Ka-25 1/72 kit. I've never built a helicopter before, but this one was just too odd-looking for me to leave behind. It actually seems like a decent little kit, and I'm hoping to steal some tips from this thread!!
On the bench: Airfix 1/72 Wildcat; Airfix 1/72 Vampire T11; Airfix 1/72 Fouga Magister
    October 2008
Posted by bsyamato on Friday, June 17, 2011 10:05 AM
VanceCrozier
Put some sprue pics of the little 25, i'm curious. Unfortunately he's not on the airfix offers i found Sad
For tips steal what you want friend but this ka-18 is a short run kit. Helicopter ,out of rorors are not so different as build a plane.
Posted by VanceCrozier on Friday, June 17, 2011 10:32 AM
No problem, sprue photos are here:
The clear parts for the windscreen & the side doors, the portions that are to be painted actually have some texture molded on to help the painting process along.
    October 2008
Posted by bsyamato on Friday, June 17, 2011 11:20 AM
aargh!! i want one Stick out tongue
When i read one of first aircraft/helicopter encyclopedia the ka-25 was one of first russian copter that remains impressed in my mind.
Pieces seems not so bad but surely are easier to turn on high detail kamov!!
aargh! (said it yet?)
If i miss it ,let me know when you start the little bird Wink
Posted by VanceCrozier on Friday, June 17, 2011 11:43 AM
bsyamato
Will certainly let you know when I start on it,
    May 2009
Posted by Pawel on Saturday, June 18, 2011 5:33 AM
Howdy!
It's a little highjacking, but since the Ka-25 got into the conversation I wanted to share this pic:
1:72 Ka-25 by Paweł Mroczkowski
And there's also a very nice Ka-27 from Zvezda (thay also make a lot of variants)
1:72 Ka-27 by Paweł Mroczkowski
Both of them are very nice kits, with decent fit and not so much detail and were whole lot of fun to build. The problem with them babies is if you want to detail them further, reference is not easy to find, because, as with all soviet/russian stuff it's all still top secret.
Thanks for reading, have a nice day
Paweł
www.vietnam.net.pl
    October 2008
Posted by bsyamato on Saturday, June 18, 2011 12:34 PM
Really nice builds Pawel Yes
Have you posted a wip of these?
The more difficult on the ka-15 probably will be the double rotor, how was on this two kits?
    May 2009
Posted by Pawel on Sunday, June 19, 2011 1:39 PM
Thanks a lot!
I don't have WIPs on those, that was before I joined the forum. Now for the double rotorhead - from what I remember the Zvezda helo (Ka-27) didn't pose too much trouble, I just replaced the kit-supplied styrene shaft with a metal one. Now the airfix kit is a lot weaker here - the rotorheads are heavily simplified and designed to be fixed together. Really awkward, if you do it as per kit instructions you get the two rotors to rotate as one assembly :((( I couldn't live with that, so I used two sets of airfix rotorheads (spares box!), lots of copper wire and styrene shavings and built new rotorheads you can see on the photo, rotating independently on a metal shaft. As I already wrote, getting at reference pics was tricky. Even more so in case of the dipping sonar mounted under the tail boom, which the kit omits alltogether. Hope it helps, good luck with your build. Remember, we're talking about Cadillacs among the soviet helos here Big Smile Have a nice day
Paweł
www.vietnam.net.pl
    October 2008
Posted by bsyamato on Wednesday, June 29, 2011 6:14 PM
hope to see some wip from you Pavel Yes
updates
bad "beginner" mistake on the red... when covered the final gray i not covered all the fuselage , so the red looking really bad on first layer:
a new red layer (used 220 ferrari red humbrol Whistling ) almost resolved the mistake
i not lost  time to mask the fuselage, the line between the two colors will be covered (if all goes good) by the decorative decals.
the tail rudders almost finished (right now completed with the white the gap between the decals)
that's all for now
