about Academy's AH-60L DAP...
I am building this model, and I'm about to glue in the cockpit/engine pod (or whatever you call it
). However, I have test-fitted it twice, and I noticed that the bottom of the cockpit floor will be partially visible through the lower side nose windows when everythign is glued in. Is this normal, or do I need to fix it with sheet styrene or something?
