I'll toss my hat into the ol' Hind group build!
The green looks a little too dark (the lighting?). Best I can recommend is compare the pics of the cockpit and cabin I posted above your pic and compare with your color. And I came up with the cabin colors by comparing the cabin photo with that EXCELLENT Testors PDF link you hooked me up with. Thank-you!
By the way, are you using the instrument film behind the instrument panel assemblies or are you going to try dry brushing it? The panel seems too thick to really show off the film dials when I dry fitted them. Also, concerning the cabin, I'm thinking about going with the doors open, that will require some additional detailing to pull it off. Do you have the WWP Hind in Detail book? I recommend it for this build. If you don't have it, it is easy for me to scan any pics from it for areas you want to focus on.
I've cut my , floorboard, cockpit panels, and am scratching a fuse breaker panel to match the Hind A as close as possible. Also cut the pilot seat down a little bit. And have gotten some good effects with the plastruct (.080x.100) frames for the eventual fuselage putty and the greenhouse canopy. Tomorrow I will take a snapshot and post my progress, I've been working and re-working(!) the cockpit all night!
Haven't even touched my other 1:35 Hind (upgrade to F model) but I need to as it will be handy to have both sets of cockpit/cabin,rotor parts ready so I can airbrush them both same day on a single mix of paints.
HIGG
