WWI: Joseph Kaeble V.C. June 8th, 1918
    September 2007
Posted by SuppressionFire on Sunday, April 6, 2014 7:24 PM
http://i6.photobucket.com/albums/y211/razordws/GB%20Badges/WMIIIGBsmall.jpg
    February 2011
Posted by Raualduke on Monday, April 7, 2014 3:13 AM
Looks fantastic , cool idea for the base.love the screw pickets
    September 2007
Posted by SuppressionFire on Monday, April 7, 2014 5:29 PM
    February 2011
Posted by Raualduke on Tuesday, April 8, 2014 6:17 AM
Wow! Even more impressive having seen all four sides.great Work
    September 2007
Posted by SuppressionFire on Thursday, April 17, 2014 7:24 AM
Here are the last two photographs of the vignette, one is from above showing the 'maple leaf' shell crater and the other is a closer look at the small shelter beneath the platform. The platform would have been across the width of the trench serving as a shelter from the weather.   The vignette won 'best theme, the great war' at the spring classic hobby show. Also it serves as a small tribute to my late father who was also named Joseph.
    February 2011
Posted by Raualduke on Thursday, April 17, 2014 9:07 AM
How did you do the sandbags?
Posted by Gamera on Thursday, April 17, 2014 10:45 AM
Wow, congrads on a well deserved win SF, gorgeous dio, love everything esp the maple leaf shaped crater.
Kudos sir!!!
    September 2007
Posted by SuppressionFire on Friday, April 18, 2014 6:13 PM
Thanks Gamera,
I'm glad you like the Canadian theme eh!
Raualduke,
The sandbags are sugar packets cut on two sides and turned inside out. Not all packets are the same and any that are at a angle instead of square when turned inside out are tossed. Next Millputt is mixed and cut to fill the sandbag, a small stick was used to pack the putty into the corner. Then the cut side was trimmed with scissors close to the putty. Finally the top was tied with suitable string and the top trimmed. The open side can be used to pack the putty further or add / remove some. Last step is to press the seam into the side with flat nose pliers, if the 'open' side looks good after pressing in a seam then save it for 'top' use, that is not all will look good on both sides.
Keep rows flat on top, press a indentation in the sandbag if a 'top' is resting on it from the next one. After the row is done flatten further with a popsicle stick, secure stick if possible. Seams may need to be redone once its set in the base. I used white glue to secure, along with some of the Millputt that came out of the open side. Two rows is a good time to take a break and let set further, more risks the lower rows flattening or bulging out.
Almost fast as filling & tying a real sandbag! After a few dozen it does speed up a bit.
    April 2014
Posted by cobraman on Friday, April 18, 2014 7:55 PM
Very nice.
    April 2014
Posted by Dawood Sekhem on Friday, April 18, 2014 10:07 PM
The shelter is incredible!!! I love the way you used the sugar packets - clever!Bow Down
    February 2011
Posted by Raualduke on Saturday, April 19, 2014 3:44 AM
Thank you so much for taking the time for a very well detailed reply.  Mike
