Winter diorama.
    February, 2016
Winter diorama.
Posted by German Armour on Friday, November 09, 2018 10:41 AM
Hello all.  Would anyone have any good ideas for a winter diorama/base?  I've built academy Tiger II and want to put it in a winter base, dug in.
Any ideas/tips would be greatly appreciated.
 Never give up, never quit, never stop modelling.Idea
    April, 2003
Posted by keavdog on Friday, November 09, 2018 11:36 AM
Micro baloons make great snow
Thanks,
John
    December, 2002
Posted by Bish on Friday, November 09, 2018 2:47 PM
I recently started useing krycell from procision ice and snow, i really like this stuff.
I would check referance pics, a dug in Tiger II sounds a bit unrealistic to me. Are you going for eastern or Western front.
'I am a Norfolk man, and i glory in being so'
On the bench: Hasegawa 1/72nd Ju 188A
                      Fine Molds 1/72nd Me 410
    February, 2016
Posted by German Armour on Friday, November 09, 2018 6:55 PM
I'm going to not base it on any period photos, just for practice making dioramas. Would there be any tips on groundwork under the snow layer?????
    August, 2012
Posted by Rambo on Friday, November 09, 2018 11:34 PM
I also would go with Krycell percision ice and snow it looks great. For ground work I use foam insulation from the hardware store can carve it out and build up layers with it. I then cover that with Scupltamold. Heres my last winter dio using Krycell
BF 110E 30
BF 110E 31
Clint
    November, 2009
Posted by Gamera on Saturday, November 10, 2018 9:49 AM
Oh wow, I've used the 'snow' stuff for model railroads (Woodland Scenics I believe) but those micro-ballons and Krycell snow material look waaaaaaaaayyyyyyyy better!!!
I'm not sure I'd do the groundwork any differently than normally. If everything is being covered by snow just do mounds for drifts with plaster or paper mache. If just a light dusting of snow just do the static grass normally and sprinkle the snow material over it.
    January, 2013
Posted by BlackSheepTwoOneFour on Saturday, November 10, 2018 10:42 AM
So where do you find this Krycell stuff? Never heard of it. I've been thinking of doing a dio with either a Spitfire, Lightning P-38 or Lancaster bomber.
    December, 2002
Posted by Bish on Saturday, November 10, 2018 10:49 AM
As far as i know it sold by just one company, Precision ice and snow. They are UK based and i am not aware of any other supplies.
https://www.precisioniceandsnow.com/#
They do a whole range of winter products including sheets of ice, a white wash paint which i used on the Lowe above, snow wash and some other items.
    December, 2002
Posted by Bish on Saturday, November 10, 2018 10:50 AM
Gamera
I am the same, i just do the ground work as i would for any other base.
    February, 2016
Posted by German Armour on Saturday, November 10, 2018 11:05 AM
Well actually they have 1 supplier in the u.s. It's http://www.thescenicfactory.com/product_p/snk-01.htm so there is a place to get it.
    August, 2012
Posted by Rambo on Saturday, November 10, 2018 8:50 PM
German Armour
where I got mine at, they also have amazing looking pine trees good for a winter dio.
Clint
    February, 2016
Posted by German Armour on Monday, December 31, 2018 6:26 PM
If anyone want to know, here's the Tiger II, also I added zimmerit with a woodburning tool a while back
I need ideas on what to do for groundwork.  The stuff on it is sculptimold...
    May, 2017
Posted by bugman9317 on Tuesday, January 01, 2019 2:14 PM
You could do anything for the ground work, really depends where your vision is.. Where is it at? For regular grass,woods I like using sifted dirt as my ground layer or if you don't have access to any dirt you can use grout for dirt.
    December, 2002
Posted by Bish on Tuesday, January 01, 2019 2:16 PM
I use celluclay with i add paint to when i mix it. Then just cover with grass, bushes, and anything else.
    February, 2016
Posted by German Armour on Tuesday, February 19, 2019 9:57 PM
Well, here is the almost finished dio.
Just what should I use to secure the snow so it doesn't keep falling off the base???????????
    August, 2012
Posted by Rambo on Wednesday, February 20, 2019 12:12 AM
What are you using for snow? If it's krycell then spray a layer of hairspray down first then sprinkle the snow on top of it. If it's just sitting loose then you may want to reclaim as much as you can and start over or try to spray over it with the hairspray and hope it doesn't fly everywhere.
Clint
    February, 2016
Posted by German Armour on Wednesday, February 20, 2019 8:43 AM
Rambo
Hi Rambo In reguards to the snow. I used woodland scenics soft flake snow.
    August, 2012
Posted by Rambo on Wednesday, February 20, 2019 4:27 PM
Then I would still suggest the same thing, put down a layer of clear flat or hairspray then sprinkle the snow over that working in layers. Don't do one thick layer but three or four thin layers. I found on krycell that hairspray works the best not sure about that brand.
Clint
