1/72 B-52D with Big Belly Mod, Operation Arc Light
    April 2012
Posted by Striker8241 on Saturday, November 9, 2013 3:45 PM
Hi, Bish,
Many thanks for the compliments, my friend! I'm happy if I've contributed something useful to your future project and I'll be looking forward to seeing it take shape - whenever that happens Big Smile.
Cheers,
Russ
    April 2012
Posted by Striker8241 on Saturday, November 9, 2013 4:22 PM
Hey Bish, could you post that Hannants link that has the B-4 stand? I searched the site but couldn't find anything about it.
Many thanks,
Russ
Posted by Bish on Saturday, November 9, 2013 4:31 PM
Yep, no problem.
www.hannants.co.uk/.../GE72030
And if you click the link on the Hannants page, it takes you to the AIM site. They have some nice looking ground stuff but I haven't got anything yet. I had to check as I wasn't sure if theirs was the same platform you had made.
And you certainly have helped a lot. What you produced is sort of what I had in my mind all those years ago, though not so well detailed. Now I am certain I can do it justice. I am hoping to get a purpose built model shed next year with plenty of display space, and then the B-52 will be the first thing on the bench.
    April 2012
Posted by Striker8241 on Saturday, November 9, 2013 6:13 PM
Thanks, Bish.
Their model doesn't look bad at all. It almost looks like a derivative - maybe another US company or maybe European - rather than a model of the USAF B-4 stand. In any case, they left off the hydraulic actuator and line so that is kind of a serious omission IMHO. They do model the hand pump but it doesn't look like any I ever saw, but ours had a cover over it so maybe Hannants left it off.
The most striking difference is the leg assemblies that support the lower frame - they're not there. And the tow bar is too flimsy.If you built one of these for real, the front cross bar would bend or snap as soon as you made a turn while towing the stand. That's why the real B-4 stands had triangular-shaped tow bar frames.
But overall, at this scale, the model looks good and will be a cool addition to a diorama. Only those familiar with the actual stands will notice any difference. And Hannant's model will be a lot easier to build than mine Big Smile.
Thanks again for the link, Bish,
Russ
Posted by Bish on Sunday, November 10, 2013 6:58 AM
Ye, I wasn't sure if it was exactly the same, or maybe a modern replacement. Their site doesn't give any date for use as it does for some of the other items. I noticed that with the tow bars as well.
So you think if I bought these ones they could be modified  to make them more accurate.
I am not sure if these are available elsewhere, the company that makes them seems to have close links to Hannants.
    April 2012
Posted by Striker8241 on Sunday, November 10, 2013 9:37 AM
Well, there are some things you could do, but I'm not sure it's necessary. Most people will not know the  differences anyway.
The lift mechanism and the platform are ok as is. You could remove the kit wheel assemblies and scratchbuild the leg assemblies and braces, and the tow bar, using my instructions. You would definitely want to re-use the wheels.
The ladder assembly is totally wrong. The real stands had three fixed steps and only a single movable step while this model has 4 fixed steps and 3 movable steps. You would have to remove the two top movable steps and one of the fixed steps.
The handrails are not right - the real stand only had a single handrail assembly while this one has two - and there are no guides for the movable step rods. If you look at their model, the movable steps appear to be attached directly to the fixed steps so it's going to look odd if you show the platform in anything but the fully extended position. You could get away with removing and attaching the movable part with handrails directly to the platform. I would reshape the lower handrails so they are smaller and closer in form to the upper handrails  - a scale figure grabbing those rails as they are would be at a 45 degree angle climbing up Big Smile.
The hand pump was inside a rectangular box, not exposed as in their model, and had a straight handle or one with a kink at the end. You would need to add the hydraulic actuator and a hydraulic line connected to the pump.
Keep in mind this model is tiny at 72 scale. Modifying the stand would be lot easier than building my model and would save you a lot of time, but you would have to really be careful.
Russ
Posted by Bish on Sunday, November 10, 2013 9:48 AM
Thanks for the info, I will keep that all in mind. I like to be as accurate as possible, but I think its often a case of keeping it within reason and being realistic as to your abilities. Its good to stretch them, but not to the point when you just trash what your working on. So I think I will get a couple of those ladders and compare them with yours and see what I think is doable.
I will be ordering from Hannants next month, so I think I will add one, and while I won't be building it for a while, I can at least see for myself what needs to be done.
    April 2012
Posted by Striker8241 on Sunday, November 10, 2013 10:05 AM
Striker8241
Ahh, disregard this comment - I looked at the model at another angle and the movable steps are attached to the platform, not to the fixed steps.
Russ
    April 2012
Posted by Striker8241 on Sunday, November 24, 2013 8:58 PM
Hi, All,
Before these old brain cells atrophy, I decided to go ahead and write up instructions for scratchbuilding the revetment around my diorama. If any of you would like a copy, please PM me.
Cheers,
Russ
Tags: 1/72 , B-52 , revetment
    April 2012
Posted by Striker8241 on Friday, January 10, 2014 10:51 PM
Hi, All,
I decided to catch up on some details I didn't have time to do before. I tried out glazing the gunner's compartment windows and I like the effect! Below is a picture of the results.
Cheers,
Russ
    November 2010
Posted by Son Of Medicine Man on Saturday, January 11, 2014 10:03 AM
Striker8241
Hi, All,
I decided to catch up on some details I didn't have time to do before. I tried out glazing the gunner's compartment windows and I like the effect! Some pictures of the results below.
Also, I built a mounting frame for the third bomb clip and installed it in the bomb bay.
Cheers,
Russ
Wow Russ, that is incredible work!  How did you make that mounting frame?
Ken
    April 2012
Posted by Striker8241 on Saturday, January 11, 2014 8:07 PM
Thanks, Ken!
I just made it from some scrap pieces, and some I-Beam stock.
Cheers,
Russ
    April 2012
Posted by Striker8241 on Friday, February 7, 2014 7:57 PM
I had an itch to do a more detailed version of the kit display engine so I ordered a resin version from Roll Models, Inc. The result was pretty rough as you can see below.
The whole surface was stippled and there were some serious holes in the casting. In addition, the shape of some of the engine sections was wrong, especially the exhaust nozzle. It had a solid plug flush with the end of the nozzle and the cone was too large and too long. I drilled out the nozzle and reshaped the cone so it looks much better.
Below is the reshaped engine with the molded on details removed. Now it's ready to add the fuel pumps, tubing, wiring and etc. I also added 7 mm to the front of the engine to replicate the intake shroud  represent the water injection shroud.
To add this to my diorama, I built an engine trailer that was used to transport engines to and from the flight line and frequently to work on the engine while in the shop. It looks like a simple structure but there are some really small and delicate parts that gave me fits.
Cheers,
Russ
Tags: 1/72 , B-52 , J-57 , jet engine
    February 2010
Posted by Bockscar on Friday, February 7, 2014 8:23 PM
Russ;
That sure is a lot of sculpting, the resin parts are supposed to
be more accurate than the injection parts.
The average modeler would have no way to know how to fix
that resin part.
Looking forward to seeing the hardware go on it,
Dom
    November 2010
Posted by Son Of Medicine Man on Friday, February 7, 2014 8:28 PM
Striker8241
Below is the reshaped engine with the molded on details removed. Now it's ready to add the fuel pumps, tubing, wiring and etc. I also added 7 mm to the front of the engine to replicate the intake shroud (I guess that's what you call it Big Smile).
Cheers,
Russ
Incredible work Russ!  Your skills at scratch building are just fantastic!  Yes  Yes
Here is a picture that my Dad took while stationed at Tan Son Nhut Air Base in Viet Nam.  I believe that is the same trailer with an engine on it.  Not quite sure what engine that is.  I also believe that is a B4 maintenance stand to the far right.
Ken
    April 2012
Posted by Striker8241 on Friday, February 7, 2014 8:43 PM
Bockscar
Russ;
that resin part.
Dom
Roger that, Dom. Actually neither the injected version nor the resin version are very accurate, but the injected version is more accurate. I was surprised too about the resin engine - neither the accuracy nor the quality was good. A lot of the details were just gestures rather that attempts to replicate the real engine. But that's ok - I planned to remove all the detail anyway and correcting the basic shape of the engine isn't that hard. It just takes a lot of time.
Also, the basic J-57 engine didn't necessarily have the shroud on the front of the intake - it appears that only the B-52 engines had those. There were a lot of planes that used the J-57 in a wide variety of configurations and finding usable pictures of those used on the D models has been difficult.
Cheers,
Russ
    April 2012
Posted by Striker8241 on Friday, February 7, 2014 8:54 PM
Son Of Medicine Man
Ken
Thanks for the good words, Ken!   Yes, that is the same trailer. Actually, that looks like two engines on trailers, one slightly behind the other. They are probably new or rebuilt J-57s without the afterburners. And that is a B-4 stand off to the right Big Smile.
Cheers,
Russ
    February 2010
Posted by Bockscar on Friday, February 7, 2014 8:55 PM
Ken:
Another great pic from your dad, much appreciated.Smile
Dom
    April 2012
Posted by Striker8241 on Monday, February 10, 2014 7:52 PM
Here's the engine after painting. Ready to add the detail.
Cheers,
Russ
Tags: 1/72 , B-52 , engine , display
    November 2010
Posted by Son Of Medicine Man on Monday, February 10, 2014 8:08 PM
Striker8241
Cheers,
Russ
Very nice Russ!  Great job on painting the metallic look!  Very realistic!  Yes  Yes
Ken
    February 2010
Posted by Bockscar on Monday, February 10, 2014 8:17 PM
Striker8241
Cheers,
Russ
Russ:
The housing around the combustion chamber looks good and burnt!Yes
That is such a tiny project, my eyes hurt just thinking about it; also like that intake shroud,
Dom
    April 2012
Posted by Striker8241 on Monday, February 10, 2014 8:20 PM
Thanks, Guys! Big Smile
Russ
    May 2009
Posted by Pawel on Tuesday, February 11, 2014 2:35 AM
Hello Russ!
A very nice looking engine - now I'm curious, how you are going to do all the plumbing on it. Good luck with the job and have a nice day
Paweł
www.vietnam.net.pl
    April 2012
Posted by Striker8241 on Tuesday, February 11, 2014 6:15 AM
Thank you, Pawel!
As for how I'm going to do all the plumbing, I plan to add the major assemblies like the fuel pump, larger valves and breathers, then add the piping and wiring in layers starting from the inside out. Should be interesting Smile.
Cheers,
Russ
    April 2012
Posted by Striker8241 on Thursday, February 13, 2014 7:48 PM
Hi, All,
I finished and installed the fuel pump assembly and added the oil filler cap. Below are some photos. Next comes the components on the engine casing itself and the plumbing. I corrected the colors a bit but they will be toned down when I add a wash.
Cheers,
Russ
    November 2010
Posted by Son Of Medicine Man on Thursday, February 13, 2014 7:56 PM
Great job on the fuel pump assembly Russ!  Yes  Yes  It is hard to believe that is 1/72 scale!
Ken
    April 2012
Posted by Striker8241 on Thursday, February 13, 2014 8:18 PM
Thanks, Ken!  Now if I only had your painting and detailing ability, it would be 100% better! Big Smile
Russ
    November 2010
Posted by Son Of Medicine Man on Thursday, February 13, 2014 8:46 PM
Striker8241
Russ
Thank you for the compliment Russ!  But I think your detailing is great!  As far as painting goes, I think that if you started using an airbrush you would be as good if not better than me!
Ken
    February 2010
Posted by Bockscar on Friday, February 14, 2014 6:44 PM
Striker8241
Hi, All,
Cheers,
Russ
Russ: That engine is looking real good. I wouldn't get too bent about your painting skills,
when I reduced your picture to about 1/72, it looks real good! That pump and fuel section is excellent, and again, unless someone has been up close to the real thing, they'd never be able to reproduce your details.
Dom
    April 2012
Posted by Striker8241 on Friday, February 14, 2014 6:53 PM
Thanks for the good words, Dom.  The pump assembly is only a gesture - the real setup is incredibly more complex and would be pointless in trying to fully replicate at this scale. As long as it gives the right "flavor" when viewed up close, we're good Big Smile.
Cheers,
Russ
