Base question
    February 2006
Base question
Posted by Wulf on Wednesday, December 10, 2014 7:10 PM
Gonna do a dio base and I need to be able to "pour" it down.  I need it to seep into and around the subject. Was considering using plaster. How thin can you mix plaster? Will it still set up if it's mixed  thin?
Thanks,
Andy
Posted by Gamera on Friday, December 12, 2014 2:26 PM
Shouldn't make any difference as far as I know how thin or thick the plaster is. Big problem is if it's really thin it's going to run everywhere unless you carefully dam it.
    March 2008
Posted by EasyMike on Tuesday, December 16, 2014 10:52 AM
Peruse the directions on the container.  Some of the premixed stuff advises not thinning it.  Keeping in mind that if water is the thinning agent, thin mixes tend to crack as they dry.
Yes
    January 2006
Posted by dirkpitt77 on Friday, December 19, 2014 5:00 PM
I actually had been researching this lately and came across a great article by a sculptor that went into great detail re: the properties of plaster. I wish I could find it again. If I remember correctly, varying the water/plaster ratio outside the "window" of the ideal mix is not recommended because it messes with the plaster's ability to cure to its strongest in the least amount of time.
  If it were me, I would do a test pour around a similar object as in your diorama. Experiment for safety's sake.  I think if you vibrate or shake the base after the pour, you could get the plaster to settle in nicely around your object.
Chris
    "Some say the alien didn't die in the crash.  It survived and drank whiskey and played poker with the locals 'til the Texas Rangers caught wind of it and shot it dead."
    February 2007
Posted by mitsdude on Saturday, December 20, 2014 12:37 AM
I've not tried it but I've heard of people that mix in some Elmers type glue with the plaster and water. I take it that this gives some flexibility to the end product so it doesn't crack as easy.
Posted by CapnMac82 on Saturday, December 20, 2014 11:17 PM
Cell-u-clay (do they still make that anymore?) was able to be thinned down pretty thin.
    April 2012
Posted by Reserve on Tuesday, December 23, 2014 7:31 PM
Yeah they still make Celluclay but it will also crack and worse, shrink if too wet. I think I'd use plaster, mix it as thick as possible, and then vibrate the base 'till it settles where you want it. This advice presupposes a single level is desired. Regards, Mark
