Autumn's Tilly
    August 2014
Autumn's Tilly
Posted by aWintersTale on Tuesday, August 18, 2015 10:40 AM
The British Light Utility Car, saddled with only 30 horsepower finds a tailwind in this diorama as it putts merrily on it's way. In bringing the elements of the diorama all the way to the edge without a defined border, I wanted to present less of an enclosed story to tell, and more of a snapsnot of a temporary and momentary scene using some motion techniques. Thanks for looking.
Tamiya "Tilly" in 1/35 scale.
Base out of Foamular material from Home Depot.
Tub on the left consists of ultra-fine dirt that was swept up from underneath the eaves of my house, after a rain storm. The black soot that is often left after a rainstorm turned out to be the finest material for using as base material. It almost as fine as powered pigment, but when rolled between your fingers, it does not ball up, but drops like dirt. Amazing stuff.
Static grass used was only two colors: beige and green in 2mm length. But because it was put down using layering, it gives the appearance of more than two colors. Applying very thin near the center of the road, while gradually getting thicker towards the hills also helps in the grassy character.
The mud puddle created with Envirotex epoxy was formed using brown pigment powder as opposed to paint, giving a translucency and suspended-sediment look. The epoxy was poured only in the indention, but through capillary action "crawled" out of the depression and soaked the surrounding area.
Test fit of Tilly and trees from Scenic Express, which were sprinkled with fall-colored leaves from the same company.
Two pound fishing test line (use super light tackle to entice those finnicky lunkers) dipped in the same epoxy with a tiny amount of brown pigment gives transparency to the water droplet splash. Angled droplets might suggest forward movement of the Tilly.
Positioning the leaves only where they might be held there by the force of the wind might also suggest forward movement.
With the angle of some trees suggesting a prevailing west-wind, and the leaf litter reinforcing this suggestion, hopefully this might add some sense of movement.
It wasn't untill I epoxied the front-right wheel, did I notice from this picture, the airborne rear-left wheel. So I did this...
Waiting on Water Effects to arrive, to add some ripples and splashes. Till then, thanks for looking. Modelers, may you all find Mercy and Grace this autumn.
    May 2015
Posted by Griffin25 on Tuesday, August 18, 2015 10:49 AM
Looks awesome! Love the colors. The contrast between the well weathered truck and the autum colors is great. It really looks like fall all the way.
Griffin
Posted by Bish on Tuesday, August 18, 2015 12:53 PM
This is really nice. Its hard to pick any one thing out, it all works so well. But i do like the puddle, definatly going to be taking some ideas from this.
    May 2013
Posted by Greg on Tuesday, August 18, 2015 1:09 PM
Your dios are always a treat.
    August 2014
Posted by aWintersTale on Wednesday, August 19, 2015 12:27 AM
Griffen, Bish, and Greg, thank you. Wanted to add a temporary subject for scale, proportion, and reference sake; please note the tuna.
More reference material; mind the tuna.Whistling
Okay. Enough reference material.
Posted by Bish on Wednesday, August 19, 2015 5:00 AM
I hate to tell you this, but i think that puddle might be a bit small for that Tuna. Big Smile
    August 2015
Posted by Poilu on Wednesday, August 19, 2015 5:22 AM
Very well done!  The autumn colors look great!
All the best,
Dan
Posted by Gamera on Wednesday, August 19, 2015 7:55 AM
Drive faster the tuna is following us!!!
Love what you've got here! I love the wheel off the base, figured you'd done it on purpose to indicate the driver's speed until you pointed out the accident. Really love how you worked the accident into the idea of the dio!
The groundwork looks great, love the bent trees from the blowing wind.
PS: So the correct term here is 'car'??? I looked up 'lorry' and apparently it applies to a much larger vehicle with an open flat bed?
Posted by Bish on Wednesday, August 19, 2015 8:04 AM
Gamera
Almost, Lorry, what you would call a truck, is any large vehicle thats bigger than a van. A car is used to transport people. Useing modern terms, this Tilley would be classed as a van, which i believe is a light truck in the US.
Posted by Gamera on Wednesday, August 19, 2015 11:19 AM
Bish
Gamera
Thanks Bish, it does fit with what the website described as a 'van'.
    April 2014
Posted by keithace on Wednesday, August 19, 2015 11:54 PM
I was impressed by the road...wow..
    March 2015
Posted by Toshi on Tuesday, August 25, 2015 7:16 AM
What an amazing diorama!  I love the color changes.
Toshi
On The Bench: Revell 1/48 B-25 Mitchell
Married to the most caring, loving, understanding, and beautiful wife in the world.  Mrs. Toshi
Posted by Jim Barton on Thursday, August 27, 2015 2:15 PM
I love it!Yes
"Whaddya mean 'Who's flying the plane?!' Nobody's flying the plane!"
    January 2015
Posted by M. Brindos on Monday, September 14, 2015 3:37 PM
I think its brilliant. I love the colors most.  :)
IS it finished yet? I'm really looking forward to seeing more.
- Mike Brindos "Lost Boy"
Posted by Bish on Monday, September 14, 2015 4:10 PM
That puddle does look really nice. How did you find the water effects, I really must get some of that soon.
    August 2014
Posted by aWintersTale on Wednesday, September 16, 2015 9:34 AM
Hi Mike. For now, I am leaving it for another dio. However, I am always open to suggestions. I like the observation and input of others, and the idea of considering products and techniques that might make that idea doable. Then I could say, I used such and such a product and technique to make an idea from Mike doable on this part of the dio. Now that would be cool.
    August 2014
Posted by aWintersTale on Wednesday, September 16, 2015 9:42 AM
Hi Bish. The Water Effects product was from Woodland Scenics, and it was specifically used over the Envirotex resin to alter the flat and calm puddle, and add disturbance. The earlier pics show the undisturbed resin, while the later ones show the addition of Water Effects along with white pigment to show some water movement. These things together, along with the plastic "curl" of water closest to the tire, hopefully gives the impression of some water activity. Storm
    June 2015
Posted by Axeman on Wednesday, September 16, 2015 10:59 AM
That is just.....WOW !
the groundwork is,well all of it is....Fine Art ! Bow Down
