Scenic glue
    February 2013
Scenic glue
Posted by Recon89 on Saturday, November 14, 2015 4:35 PM
I ran out of the commercially available spray scenic glue. Can I water down white glue to spray with the same effect? If so, what would be a good ratio?
Thanks.
    June 2006
Posted by SteveM on Saturday, November 14, 2015 6:58 PM
I do, about 75/25 water to white glue if I wanna use a sprayer. Not an exact measurement or anything. A drop or two of dish detergent in the mixture seems to help break surface tension so it spreads a little more evenly.
I might make a thicker batch with more glue, depending on what I want to set down.
Steve M.
On the workbench: ginormous Kharkov dio
    February 2013
Posted by Recon89 on Sunday, November 15, 2015 8:08 AM
Thanks, I'll start with that ratio. Just doing a snow scene so I don't need a thick spray.
