I would like to share with you one of my favorites diorama. It's called Rusty Ranch.
CONSTRUCTION
AMT – 1949 Mercury Coupe and MAISTO – 1903 Harley Davidson. Customized both vehicles. Also I distressed the balsa wood used on the fences. Entrance gate and mailbox is scratch built using styrene, leafs are mixed herbs. The base is a simple wood photo frame. The display box is made of 3mm crystal acrylic with laser engraved brand.
PAINTING & MARKINGS
First stage is priming with a base coat using aerosol can, then painting mainly with acrylic paint using either Vallejo and Tamiya paints. After base color is dried I use a mix of hairspray + chipped salt to achieve the rusty patina.Rusty patina achieved using acrylics, oils, rust powder pigments.
Hope you all like it.
Thank you.
