telephone poles in North Africa
    February, 2017
Posted by ugamodels on Wednesday, August 23, 2017 10:34 PM
I am working on a diorama with a line laying jeep in North Africa. If I put more than one pole in the diorama and maintain scale, it will be huge AND empty because the distance between poles as fairly large. How might I have telephone lines come in from one side without support on one end? Or do I ignore scale and just put two poles?
Also, how can I make insulators for the poles? I am thinking round plastic rod and putty? But I doubt my ability to sand a tiny round shape.
Thanks!
I type on a tablet. Please excuse the terseness and the autocorrect. Not to mention the erors.
    September, 2012
Posted by GMorrison on Thursday, August 24, 2017 1:24 AM
Thats a tough one. Two poles doesn't solve the problem.
Try glass beads, the little ones.
    December, 2002
Posted by Bish on Thursday, August 24, 2017 1:52 AM
Check out this dio, he has a telephone pole with wires hanging in mid air.
http://cs.finescale.com/fsm/modeling_subjects/f/19/t/176102.aspx
Black beading or artist wire should do the trick.
''I am a Norfolk man, and i glory in being so''
On the bench: Rudel Stage 3
                     Academy 1/72nd Apache AH.1
    April, 2009
Posted by Cadet Chuck on Thursday, August 24, 2017 8:58 AM
Suggest you refer to the writings of Alexander Graham Bellski.  He was the first telephone pole.
Big Smile
Computer, did we bring batteries?.....Computer?
    July, 2004
Posted by stikpusher on Thursday, August 24, 2017 5:54 PM
something like this in mind?
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    February, 2017
Posted by ugamodels on Thursday, August 24, 2017 7:16 PM
That in fact is one of 2 or 3 pictures I am working from.
    February, 2017
Posted by ugamodels on Thursday, August 24, 2017 7:22 PM
That is what I have been thinking. Good to know it works.
    February, 2017
Posted by ugamodels on Thursday, August 24, 2017 7:25 PM
I don't do writings. It's like Playboy - I only get it for the pictures Wink
    January, 2006
Posted by SprueOne on Thursday, August 24, 2017 10:34 PM
ugamodels
Thanks!
Meng makes water and beer bottles in 1/35. These can be modified for insulators.
http://www.meng-model.com/index2_new.php?id=218
http://www.meng-model.com/index2_new.php?id=217
Anyone with a good car don't need to be justified - Hazel Motes
Iron Rails 2015 by Wayne Cassell
    July, 2004
Posted by stikpusher on Thursday, August 24, 2017 10:53 PM
Or Miniart and Italeri make telegraph/telephone poles in 1/35..,
       - Plankton
LSM
    December, 2002
Posted by Bish on Friday, August 25, 2017 2:08 AM
RB also does some very nice wooden ones with metal insulators. There are several different arrangments.
    May, 2017
Posted by Frankenpanzer on Friday, August 25, 2017 4:04 AM
Wooden dowel rods, stiff wire and seed beads. You can get all of it at Hobby Lobby.
    November, 2005
Posted by CapnMac82 on Saturday, August 26, 2017 12:34 AM
Actually, you best bet might just be a single pole, not at all plumb, with the wire slack on the ground sweeping up to the insulator.  Conveys the message without introducing dangling wire into the equation.
Given that you are intending North Africa in the 40s, you probably only need a poel with insulators mounted to the side, rather than on a cross bar.  (Probably little electrification, so a phone line and a telegraph cable perhaps.)
Probably only needs to be about 10' tall to scale (right at 3.75" out of the ground) too.
    February, 2017
Posted by ugamodels on Sunday, August 27, 2017 9:48 AM
CapnMac82
I have a couple of pictures and this is pretty much what I see too. The arms look like metal 'L's with insulators on the end. Although I think the height looks more than 10 feet. I'm thinking of having short pieces of wire "flying " in from the right and then slack down to the spool on the jeep.
    February, 2017
Posted by ugamodels on Sunday, August 27, 2017 9:59 AM
The beer bottles do look like a good possibility! I want to check out the bead option first, since I can do that in person and hopefully only buy what I need. But if that doesn't work out, I think I will do the beer bottles.
    February, 2017
Posted by ugamodels on Sunday, August 27, 2017 10:01 AM
stikpusher
Yeah I have the Italeri poles. I didn't think they had insulators but maybe I am mistaken.
    February, 2017
Posted by ugamodels on Sunday, August 27, 2017 10:09 AM
RB seems to be HO scale. I imagine 1/87 is not going to work too well in 1/35. But I could be wrong.
    December, 2002
Posted by Bish on Sunday, August 27, 2017 11:41 AM
ugamodels
They have 35th ones as well, for some reason under the Misc section.
http://www.rbmodel.com/index.php?action=products&cat=c_bm&sub=35A
Unfortunatly they are out of stock of all of them at the minute, but you might be able to finbd them else where.
    September, 2005
Posted by richs26 on Wednesday, August 30, 2017 12:47 AM
stikpusher
These two linemen are Signal Corps linemen, not Army engineers.  They wouldn't be wearing helmets around electrical lines, plus there are no hotsticks around the scene.  There are also too many conductors for electrical lines.  The insulators are French pattern since this is North Africa.  Using forensic comparatology, the pole scales out to be approximately 21-22 feet in height (using the average American height at 6 feet).
WIP:  Monogram 1/72 B-26 (Snaptite) as 73rd BS B-26, 40-1408, torpedo bomber attempt on Ryujo
Monogram 1/72 B-26 (Snaptite) as 22nd BG B-26, 7-Mile Drome, New Guinea
Minicraft 1/72 B-24D as LB-30, AL-613, "Tough Boy", 28th Composite Group
    October, 2003
Posted by sharkbait on Wednesday, August 30, 2017 12:43 PM
Traveled around Africa a lot but never North Africa. In a lot of places such as Gabon, Nigeria, Somalia, Rwanda  ect. The old poles were cement vs wood because wood would not last long. Never bothered to take photos but as I recall they were square, tapered towards the top. Most dated from "Colonial daze"
You have never been lost until you've been lost at Mach 3!
    February, 2017
Posted by ugamodels on Thursday, August 31, 2017 10:34 PM
Thanks! That photo and another in the same series from the same photographer are one source of detail for me. Combined with some jeep photos I think I about have figured out what I am going to do.
    November, 2005
Posted by CapnMac82 on Friday, September 01, 2017 11:19 PM
Yeah, and unless they are Signal Coprs people (who would have either a 3/4 ton truck or a 1.5 ton telco truck)
they'd be laying out commo wires along the ground, and not up on poles.  ground laid wire is easier to repair if combat or vehicle damaged.  Not climbing poles is way faster, too.
Artillery units might have a cable real mounted o nthe rear of the jeep since arty regularly pays out miles of wire for commo.  Grunt infantry might be a bit more impromptu and just hold the cable reall over the side of the jeep as they went along in 1st gear.
    July, 2004
Posted by stikpusher on Saturday, September 02, 2017 12:17 AM
For hasty communications, wire is laid on the ground. As improvements are made to the rear areas when the battle moves forward and away, the wire dogs will string it up high where it's less likely to be run over or suffer other accidents...
another photo of wire dogs from that same photo essay in Tunisia... on the ground...
       - Plankton
LSM
    February, 2017
Posted by ugamodels on Sunday, September 03, 2017 9:25 PM
The jeep picture I am working from indicates 1sr infantry division near El Guettar in March 1943. As to whether there are poles involved, probably not , but I want something else in the diorama. So I am open to suggestions.
    November, 2005
Posted by CapnMac82 on Monday, September 04, 2017 4:04 PM
Oh, the pole will add "verticallity" to an otherwise flat dio.
But, it can be a bit like a dead tree, too.  The slack wires can help with visual interest, too, as they suggest something out of sight, further away.
And, you can approch that in several ways.  laying wire; checking wire, even using an EE-8 connected in.
    May, 2015
Posted by Griffin25 on Monday, September 04, 2017 6:03 PM
Goof around and drop pins on N African roads on Google maps and see if they have street views. This is probably a more modern Pole but I found it in Tunisia on some random road. Just a thought. The insulators look modern but the pole is pretty old
Griffin
    February, 2017
Posted by ugamodels on Monday, September 04, 2017 9:29 PM
Griffin25
interesting idea. What kind of trees do you think those are? I could put one or two in to add a little depth.
    May, 2015
Posted by Griffin25 on Monday, September 04, 2017 10:02 PM
Olive?
Griffin
    February, 2017
Posted by ugamodels on Tuesday, September 05, 2017 6:35 PM
Olive is my first guess also, but I am no horticultural genus. Probably any short canopy tree will look decent.
    February, 2003
Posted by Jim Barton on Wednesday, September 06, 2017 3:30 PM
My educated guess is that those are olive trees.
"Whaddya mean 'Who's flying the plane?!' Nobody's flying the plane!"
