Is this good resin?
    January 2021
Is this good resin?
Posted by Teenage Modeler on Tuesday, April 27, 2021 10:41 PM
I was checking Michael's website to see if they have resin. They do, but it's not epoxy resin. From what I learned, the best type of resin for dioramas is epoxy resin. I found one in the link below, but I don't know if it's suitable for dioramas.
Link for Michael's website: https://www.michaels.com/alumilite-amazing-clear-cast/10324152.html
Made you Look
    September 2012
Posted by GMorrison on Tuesday, April 27, 2021 11:50 PM
I personally avoid resin for all but the most thin applications. It's not possible to pour any depth without a lot of practice, patience, pracice and skill.
And you saw the statement about yellowing? It's a thing.
Bubbles are all but inevitable and can spoil hours of work.
If you want to see to the bottom of your pond, it works well to embed a piece of glass as the water surface after detailing the lake bottom, and adding texture to the surface with gel medium or even clear silicone caulk.
Bill
    January 2021
Posted by Teenage Modeler on Wednesday, April 28, 2021 7:50 AM
GMorrison
Bill
Hmm, so you mean like add a plastic card for the surface, which means that the inside of the riverbed is hollow? And add some clear glue to the surface?
That's actually a good idea, I'll try it.
Made you Look
