White Metal Landing Gear, Really?
    March 2012
Posted by SoCal Dude on Friday, July 6, 2012 12:35 PM
Is this really necessary?
I read somewhere that regular styrene parts will actuall begin to wilt or even collapse over time, but I'm skepticle.  I bought a set of white metal LG for my 1/72 Hasegawa B-24 Liberator, but upon inspection, I thought they were a little soft themselves!
I really would prefer not to spend the extra $$ and just use the kit parts, but I don't want my planes sitting on their bellies either!
Your thoughts and experiences would be greatly appreciated.
    October 2011
Posted by Plastic-surgeon on Friday, July 6, 2012 12:56 PM
SoCal Dude
I still have kits that I have build in the late EIGHTIES which are still standing on their styrene landing gear!!!!   But I must say that the decals have yellowed.......
All that scrathing is making me itch!
Posted by Gamera on Friday, July 6, 2012 1:19 PM
I have used them on a 1/72nd B-29 since I was worried about the weight of the aircraft but generally no, I really don't see the point.
Dre
    June 2007
Posted by Dre on Friday, July 6, 2012 1:28 PM
FWIW, I only use the metal landing gear if it comes in the same box as the kit itself.  Trumpeter is pretty good for including these in some of their larger 1/32 kits, so it's a win-win as the metal is not soft at all.
    April 2004
Posted by keilau on Friday, July 6, 2012 4:27 PM
Dre
The metal landing gear casting allows finer details than their plastic counter parts. I have 2 of the Hasegawa Hi-Grade Series 1:48 kits (F-4 and F-15) from the late 1980's. I really admire the workmanship that went into the landing gear casting.
There are aftermarket metal LG today. But the detail is usually no better than the kit plastic part. Yes, I agree with other posters that the strength alone is no worth the extra money.
The only 1:32 Trumpeter aircraft kit that I have is their M-15. An old cheap kit with no metal part. Can you tell me which Trumpeter kit has the metal LG and the quality of these part.
    August 2010
Posted by flyinyak on Friday, July 6, 2012 4:42 PM
I bought them  for a Monogram B-58 Hustler. Thought they were a waste of money. The seemed to be made with the same molds as the original kit landing gear - flash and all. They ended up in the trash.
    August 2011
Posted by Centerdeck2 on Friday, July 6, 2012 4:44 PM
There are a few kits out there that are a little less stressing with the metal landing gear. When my a-20 lost its fight with the cat, i couldn't get the styrene gear workable again to save my life.  Had to order the metal ones.
Shepherd Book once said to me, "If you can't do something smart, do something right."
    July 2004
Posted by stikpusher on Friday, July 6, 2012 6:20 PM
I have yet to have a styrene landing gear strut wilt or collapse on its own over time. My oldest current builds are roughly 25 years old and doing well. Although many have been broken by cats, earthquakes, kids, etc. That being said, there are a few kits that I have build and no longer have that had very fragile struts and I would have certainly preferred metal struts had they been available at the time. Especially for larger heavier kits (1/32 F-4 Phantom and 1/32 Panavia Tornado) But the biggest and heaviest kits Ihave built, Monogram 1/48 B-17, B-24, and C-47, and 1/72 B-52 all had no need of metal replacement parts. The original kit parts were built more than adequetely enough.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    January 2012
Posted by Misty on Friday, July 6, 2012 7:31 PM
I bought some for my airfix lightning and am distinctly unimpressed. i will use the kit ones and only replace them if they wilt.
    November 2003
Posted by mississippivol on Friday, July 6, 2012 10:04 PM
I've never had any problems with the plastic gear collapsing. Heaviest kit I have is the Monogram 1/48 B-29, and it was built nearly 30 years ago. I do have a problem with the Academy 1/32 F-18C kit's main gear. It's squashing out, causing the plane to settle. It has a metal wire core, however, it just doesn't seem strong enough.
Glenn
    June 2010
Posted by DoogsATX on Saturday, July 7, 2012 12:24 AM
Generally I'm not a fan.
Recently, however, I've found myself purchasing two sets of metal gear struts.
The first was for the HK 1/32 B-25. The thing CAN sit on the styrene gear, but it's wobbly. And you have to install the nose gear before you close the fuselage. That's a lot of accidents waiting to happen during the build. I also went for the G-Factor white bronze stuff. The molding is exquisite and the white bronze isn't soft at all.
The second was a white metal set for the Revellogram B-25. Again, the nose strut has to go in before you close the fuselage. That and this one's a commission build, and will have to be shipped. I'd rather have the gear bend than snap apart...
But I view these two as very much being exceptions. Usually, no point to it.
On the Bench: 1/32 Trumpeter P-47 | 1/32 Hasegawa Bf 109G | 1/144 Eduard MiG-21MF x2
On Deck:  1/350 HMS Dreadnought
Posted by Ish47guy on Saturday, July 7, 2012 12:30 AM
I do have several sets in the stash, but only for the bigger kits that I know are going to need some weight to keep them on the gear (48th B-1 for example), or for kits that the kit gear parts are known to be on the fragile side (48th S-3 MLG kit struts and braces will break if you look at them too hard it seems).
Dre
    June 2007
Posted by Dre on Saturday, July 7, 2012 11:36 AM
Keilau, after checking my stash, these 1/32 Trumpeter kits have metal landing gear in the box:
  • Su-25UB Frogfoot
  • Su-27B Flanker, Su-27UB C, Su-30MKK
  • A-10A Thunderbolt II
  • MiG-29M Fulcrum
  • Me 262 A1-a
Additionally, Tamiya adds metal gear on some kits:
  • F-16CJ Block 50
  • F-15C
  • F-15E Strike Eagle
Overall, the metal parts are pretty much the same as the styrene parts.  At a cursory glance, they all appear to be more or less equal in detail.  I haven't gotten to the Tamiya kits yet, so I can't say whether the metal is soft or not but Trumpeter's metal is damned hard and requires a machinist's file to remove the part lines.  I don't think that they'd ever bend or deform.
Hope that helps.
    January 2003
Posted by yardbird78 on Saturday, July 7, 2012 5:52 PM
The Trumpeter and Hobby Boss 1/32 F-105s definately need the metal landing gear legs.  Most other models do not.
Darwin, O.F. Alien
The B-52 and me, we have grown old, gray and overweight together.
Posted by Ish47guy on Sunday, July 8, 2012 7:21 AM
If memory serves, the Monogram F-105 kit really benefits from the metal legs.  Built three back in the 80s, all the MLG  struts broke at some point.
    May 2011
Posted by dullcote on Friday, July 13, 2012 8:28 AM
Im funny about spending lots of money on parts for an already "High Dollar" kit just to make it right or rectify the kits short commings.  The normal I will purchase,..PE and such but thats about it these days
Its very easy to go all out on a build and buy replacement parts just to be buying them....Most times the "parts" do enhance the look of the kit....but at possibly 3x the price of the original kit?
Metal LG struts that Ive dealt with were certainly a major let down for me. The latest AC kit I bought them for was a Hasegawa P-40....I tossed them back into the spare parts box.!!!
I have had good results scratching LG with Aluminum tube and the looks to me are more realistic and life-like than the Metal AM parts.
Get some tubing and a Waldron Punch tool set along with various sizes of wire and you will be amazed at what you can turn out.
Besides......isnt that the true "Theme" of model building?.......To me it is but thats just my .2 cent opinion.
    January 2009
Posted by paintsniffer on Friday, July 13, 2012 11:44 AM
thanks for the heads up on the Revell B-25 landing gear. I am about to start one so I will look into the metal gear.
The only kit I have that has had any trouble with the plastic gear is the Kinetic Mirage 2000D. The kit struts are just horribly inadequate for the kit, and it's not big kit. When I built the kit there was no aftermarket available.
Also the IBEX JPATS could use some metal struts for the same reason.. With nose weight the kit struts are very borderline.
Excuse me.. Is that an Uzi?
Posted by Anonymous on Friday, July 13, 2012 1:19 PM
I have built the Revell 1/32 Eurofighter the kit is quite heavy and it is sitting on the plastic landing gear supplied, it could do with a stronger nose gear but it's fine and is a few years old and has also been accidentally knocked a few times as well and it has held up fine. The only time I have had any landing gear start to sag was on a 1/48 F/A-18E as the main gear are an awkward shape and I would get it in that instance.
    June 2008
Posted by Hans von Hammer on Friday, July 13, 2012 9:42 PM
Ditto to both...
I have had good results scratching LG with Aluminum tube and the looks to me are more realistic and life-lik(e)
Well, there ya go.. Nothing looks more like metal like metal itself...
Personally, I'm more concerned with axles breaking under stress, rather than the struts...  Of course, some kits are weighted, some not.. For instance, I didn't "weight" my 1/48 B-29, but rather I "trapped" a sheet-metal screw in the right nose-wheel half, then inserted the screw through the hole I drilled in the base, then added the washer/nut... The stress-point then is on the nose strut at the glue-joint in the gear-well, and the model's entire weight is supported on the mains..  This goes for all the "trike-gear" birds I build..
But I look over the axles pretty well, and sometimes it's just easier to replace the plastic axle with styrene-coated wire during the guild, rather than waiting for it break on it's own..  AMT's 1/48 Tigercats are one example of a kit that I did that on the nose-wheel...
If I can't trap a screw in a nose-wheel tire, I drill a hole in the bottom of the "flattend" tire,  epxoy in a piece of Evergreen's styrene-coated wire, then pull it through the base, bending it over to "lock" the rod underneath..
    December 2003
Posted by hkshooter on Saturday, July 14, 2012 6:51 PM
The only white metal I've used was on the 1/48 AMT F7F front strut. It's long and delicate and I figured it would be easier to bend back into shape than it would to repair a break. Outside of that I've never used the product and have seen little to no evidence it's needed. Other than super huge kits I see no need but I'll admit I've not built a kit so big that it may need them.
    July 2011
Posted by Flute Fixer on Thursday, July 26, 2012 12:37 PM
I purchased a set for the Hasegawa B26...so I could get the white metal cockpit floor and bulkhead. I tossed the struts!
    October 2008
Posted by P mitch on Thursday, July 26, 2012 12:49 PM
I have a set of white metal landing gear for my 1/24 Mosquito just because of the shear size and weight of the thing. I cant see it being a problem on anything smaller
Phil
"If anybody ever tells you anything about an aeroplane which is so bloody complicated you can't understand it, take it from me: it's all balls." R J Mitchell
    April 2014
Posted by B_one fixer on Sunday, April 26, 2015 6:28 PM
The only time I have used metal landing gear was on a 1/48 B-1B I did many years ago. The weak point that I find on many kits are the axles and not the gear.
    October 2007
Posted by pordoi on Sunday, April 26, 2015 7:07 PM
flyinyak
Ditto for the B1-B build I did 2 years ago.  Aftermarket parts required more cleaning and sanding  than the kit parts.  I simply reinforced the main gear with brass rod, and to be honest I'm not really sure that even that was required.
Don
    March 2005
Posted by Devil Dawg on Saturday, May 2, 2015 12:48 AM
Whew!! Someone pulled this thread from the "Way Back When...." bin.
I built the Academy 1/32nd F-18 Hornet about 10 years ago, and wished that I had used metal landing gear with it. The kit came with metal inserts for the plastic landing gear, but those inserts were very thin/small diameter, and when I installed a full weapons load-out, after about a week the landing gear slowly began to bend outward (only the main struts - the nose gear held up ok). I tried to fix it, but nothing could save it. I believe that if I had used gear struts made entirely of metal, this would not have happened.
I would only recommend metal landing gear for larger kits, though. Most 1/48th and smaller wouldn't need it. Some 1/32nd kits probably wouldn't need it, either. Just depends upon how much weight is being supported.
Devil Dawg
On The Bench: Tamiya 1/32nd Mitsubishi A6M5 Model 52 Zeke For Japanese Group Build
Build one at a time? Hah! That'll be the day!!
Posted by Don Stauffer on Saturday, May 2, 2015 9:11 AM
It depends on how much weight has to be added for it to sit on its nose gear.  Actually, the weight on the nose gear itself should not be that great- the weight of the model might be, however.  The nose only needs a bit of positive weight. If you have to add a lot of weight, it my end up stressing the mains more than the nose.
I have built kits that had very heavy tails, and a short nose.  These take ounces of weight, and the gear can get pretty wobbly.  In fact, I have built a few kits that needed a lot of weight, but had a big, detailed cockpit forward and a big nose gear box, and it becomes hard to pack in enough lead or other heavy metal to keep the nose gear down!  Mostly these are single engined planes- most multi-engined ones have longer noses giving more leverage from the nose weight.
    December 2009
Posted by Tucohoward on Saturday, May 2, 2015 11:39 AM
White metal gear like SAC, no. Too soft and just a copy of the kit part. I do use G-Factor gear legs whenever possible. Very strong and much more detailed than the kit parts.
Jay
The Mighty Mo says no.
