1/48 Hasegawa F-22A Raptor WIP
    December 2006
Posted by Fly-n-hi on Thursday, September 18, 2014 10:16 AM
P mitch
Fly-n-hi
Only just seen this thread and like a few others I have this in the stash so glad to see someone building one. I must say the panel lines that you mentioned being out don't bother me at all, it looks like a F-22 so thats fine by me
Phil
Thanks, P mitch!
I've polished and masked the canopies.  I used the Novus polishing compounds to remove some small scuffs. I decided to mask them both so that I have the option of using either one since I'm still not sure which squadron markings I will be using.
    December 2006
Posted by Fly-n-hi on Thursday, September 18, 2014 10:26 AM
I've also assembled and painted two of the AIM-120C AMRAAM missiles.  Obviously I'm not going to use them on this kit but I figured I'd make them anyway to see how they look.  I might use them on a future build:
Posted by Jim Barton on Thursday, September 18, 2014 2:57 PM
Beautiful model so far!
"Whaddya mean 'Who's flying the plane?!' Nobody's flying the plane!"
    December 2006
Posted by Fly-n-hi on Wednesday, September 24, 2014 7:02 PM
Thanks Jim!
I'm getting more painting done.  I've painted all of the outer edges the lightest grey color.  I'm using the colors recommended in the instructions.  I mainly use Mr Color paints anyway so it works out well for me.
I added some black to that light grey color, sprayed it on randomly, then added some white to the color and sprayed it on randomly as well to give it a weathered appearance:
This light grey color doesn't really show up to well against the primer.
And yes...I'm gonna weather this one up like the F-16 and the F-15!
    December 2006
Posted by Fly-n-hi on Sunday, September 28, 2014 11:50 AM
    January 2014
Posted by Silver on Sunday, September 28, 2014 11:58 AM
An interesting note :To get that realistic metalic sheen on the surface gray that the F-22 has is to dry brush w/a very micro amount of S'J aluminum powder On to the cured surface .Make this the final step and Handel w/care.S'J powder is now hard to get but other brand types do exist.
    December 2006
Posted by Fly-n-hi on Sunday, September 28, 2014 3:26 PM
Here's the F-22 with the first layer of paint.  Actually, its the first layer plus some post shading.  I'm trying to give the paint some tonal variation in preparation for the weathering.
I just used the colors recommended in the instructions.  This seems to be the standard formula now for getting the "Raptor Sheen" in the paint.  Its just mixing in steel colored paint with grey paint at about 1:1.
I like the appearance of this paint.  Like I said earlier in the thread I'm going to give this one some weathering.  So I didn't want the fresh out of the paint shop look to the paint even though most F-22s are very clean.
I thought I took some pics of the paint before the post shading but I guess I didn't.  Oh well.
Next up will be the camo and then some shading of various panels.  Then I will decal it, seal it and then start the real dirty weathering.Yes  Unfortunately, we have company arriving today so I had to pack up all my building stuff for a few days.
    January 2014
Posted by Silver on Sunday, September 28, 2014 7:22 PM
To get a realistic Metallic sheen on the gray surface just dry brush a micro amount of SN'J metallic powder.
    April 2014
Posted by el_capitan on Wednesday, October 15, 2014 8:12 AM
Hi Silver,
I myself was wondering how to achieve the Raptor's metallic sheen, and found your suggestion very interesting. Do you know of a source for SnJ metallic powders, or what similar/equivalent products there are?
Thanks in advance.
    December 2006
Posted by Fly-n-hi on Thursday, October 16, 2014 9:44 AM
Silver
If you use the paint mix recommended in the instructions you get just the right amount of "sheen."  The paint  they use to get the sheen is a new Super Metal paint line and it works very well.  Anything more metallic would have too much sheen in my opinion.
I'll try to post a pic of this F-22 in the sunlight.  The sheen will be very obvious, then.
Posted by Texgunner on Thursday, October 16, 2014 10:38 AM
This pic is maybe 4-5 years old.  I don't know if the current appearance is different.
"All you mugs need to get busy building, and post pics!"
    April 2010
Posted by Mustang8376 on Thursday, October 16, 2014 1:06 PM
I believe FineScale had an article in the last current issue on how to achieve the metallic sheen for the paintjob.  Has anyone else tried it?
Current build: 1/32 Hasegawa F6F-5
Completed:  1/48 Hasegawa F-16C, 1/48 Revell Mig-21PFM, 1/48 Revell/Monogram AH-64A, Revell/Monogram 1/48 F-14D, AMT 1/420 USS Defiant, AMT 1/650(?) USS Enterprise, 1/72 Bandai VF-1J, AMT 1/537 USS Reliant, Academy 1/35 M1-A1 Abrams, Academy 1/48 F-86F30, Linbergh's USS Gato
    December 2006
Posted by Fly-n-hi on Thursday, October 16, 2014 3:54 PM
The article uses a mixture of aluminum, graphite and grey.  It's basically the same idea as what the instructions call for.
    September 2013
Posted by Dean30 on Friday, October 17, 2014 3:09 PM
Fly have a look at this if you're curious about painting. I saw this a while ago and think it might be useful.
As far as I could ever see it's the closest I have seen to the paint on an F-22, I think he basically did what the instructions said as the guy doesn't say much about the painting but here's a link anyway, it might be useful to you.
He said something about using a thinned translucent grey over silver, perhaps that's the key instead of mixing?
    September 2013
Posted by Dean30 on Friday, October 17, 2014 3:10 PM
    December 2006
Posted by Fly-n-hi on Friday, October 17, 2014 5:10 PM
I appreciate the suggestions but I've already got the amount of sheen I'm looking for.  Mine's going to be one of the dirtier line jets.  Those pics above look like a fresh paint job.  That's not really my thing.Cool
    December 2006
Posted by Fly-n-hi on Thursday, October 23, 2014 2:53 PM
I completed a pair of the AIM-120C AMRAAMs that came with the kit just to see how they'd turn out.  Not bad me thinks:
I'm not going to use them but I thought I'd share the pics anyway.
    December 2006
Posted by Fly-n-hi on Friday, October 24, 2014 5:22 PM
Alrighty, I've got the basic camo painted on.  I've noticed in my research that , it seems, no two F-22s have the exact same camo pattern.  There was alot of variation out there.  I just sort of made up a pattern using several images.  I've also applied some post shading to the camo:
After this I will give a general lightening/post shading to the camo spots, paint a few of the light grey areas that I skipped earlier, paint some of the detail panels and paint some of the dirty areas.  Then I will gloss coat and decal it.  Then the fun weathering beginsBig Smile
Dre
    June 2007
Posted by Dre on Tuesday, October 28, 2014 12:06 PM
This looks great, Fly.   Right up there with your usual awesome builds.
    December 2006
Posted by Fly-n-hi on Tuesday, October 28, 2014 4:15 PM
Thanks, Dre!  I've faded out the dark camo spots a little and I've masked off the remaining light grey panels that I skipped during the first round of masking:
It will probably sit like this for a while since I can only paint now when my wife isn't home.  She's always home since she works from home so who knows how long it will be before I get to it again.
    December 2009
Posted by ww2psycho on Tuesday, October 28, 2014 8:10 PM
Am I the only one thinking why they used a camo scheme on a stealth plane?
Great build! I'll do one eventually.
    December 2006
Posted by Fly-n-hi on Tuesday, October 28, 2014 10:16 PM
ww2psycho
Ha!  I hadn't really thought of that.  But its probably the same reason they put guns back onto the F-4s.  Eventually, its gonna come down to old school dog fighting.
Actually, the camo itself is a form of stealth.
Posted by Tojo72 on Wednesday, October 29, 2014 7:33 AM
Really looking good, the missiles were impressive although the decals were tedious but worth the effort.
    December 2006
Posted by Fly-n-hi on Wednesday, October 29, 2014 9:31 AM
Thanks Tojo!.  There were 33 decals per missile!  I only used 17 per missile, though.  I didn't bother with all of the little "NO HOLD" decals that went on all the fins.  I figured nobody would see them anyway.
Posted by Jim Barton on Wednesday, October 29, 2014 4:40 PM
Great job on the missiles!
I remember years ago watching a B-2 and an F-22 flying very low (not much more than 500 feet off the ground) over a friend's house one New Year's Day. They were on their way to a flyover of the Rose Bowl in nearby Pasadena as a part of the pre-game festivities before the kickoff.
    December 2006
Posted by Fly-n-hi on Wednesday, October 29, 2014 6:51 PM
Jim Barton
That would have been cool to see!
    June 2013
Posted by RobGroot4 on Friday, October 31, 2014 4:08 AM
Something you mentioned above made me curious- You mention discoloring to denote replaced panels.  My background is Navy, but if you look at the fuselage sides of many Navy aircraft (particularly F/A-18s) you often see panels that are much lighter.  This is from internal repairs (electronics, hydraulics, engines, etc.) followed by repainting the panel after the aircraft has been closed back up.  This leaves the lighter/cleaner patch.  Does the USAF use the same practice on its aircraft, or do they just replace the panels?  Does anyone have any insight into how the Air Force handles post-maintenance cleanup/painting?  Thanks!
Groot
"Firing flares while dumping fuel may ruin your day" SH-60B NATOPS
    December 2006
Posted by Fly-n-hi on Sunday, November 2, 2014 2:55 PM
I've added some brake lines to the main gear and some electrical lines to the landing/taxi lights on the nose gear:
I may add another set of lines to the main gear.
    June 2014
Posted by BrandonK on Sunday, November 2, 2014 3:25 PM
It's coming along nicely. Can't wait to see it complete.
On the bench:
A lot !! And I mean A LOT!!
                         14 / 5 / 2
                              Tongue Tied
