Separating glued fuselage after it has dried
    October 2013
Posted by redryder on Wednesday, August 20, 2014 9:24 PM
Hi guys,
I’m building a 1/72 Hasegawa Mustang. While I was masking off the engine exhaust, I used too much force and pushed it into the body of the plane. The engine exhaust is a separate piece that you glue onto each half of the body from the inside, before joining the halves together. The only way I can think of to retrieve that piece is to separate the body. Sigh…
The body was glued together, sanded and primed many months ago. I don’t have much experience building aircraft, is it still possible to separate the two halves of the fuselage at this stage?
    November 2003
Posted by mississippivol on Wednesday, August 20, 2014 9:34 PM
That would be a very difficult proposition. You could drill a hole where the prop goes, shake the part out if you haven't already, then use that hole to reglue the part into place. Just an idea...
    October 2013
Posted by redryder on Wednesday, August 20, 2014 9:59 PM
That might very well work! Thanks!
Posted by Don Stauffer on Thursday, August 21, 2014 8:50 AM
you didn't say what kind of glue you used.  There is such a thing as a CA debonder if you used CA. I have used it and it works fine.  Solvent cements sometimes make a bond that isn't super strong and you can sometimes take them apart with sheer force, but it is a risk.  In any case you'll need to redo the seams and paint.
    March 2005
Posted by TarnShip on Thursday, August 21, 2014 8:29 PM
drill that hole the size of some styrene tubing,,,,,,,or the size of the outside piece of a tubing telescope
then, you could just glue your tubing in there after you reglue the exhaust manifold, and your prop would still be a slip fit if that is what you wanted
Rex
almost gone
