Matchbox 1/32 Spitfire Mark 22/24
    March 2005
Posted by philo426 on Tuesday, October 21, 2014 12:19 AM
I bought this at my LHS today and it is one huge box.!older kit of a Korean War era Spit.
    March 2005
Posted by philo426 on Tuesday, October 21, 2014 12:24 AM
The engine is basic and lacks the Rolls Royce logo.
    August 2005
Posted by Phil_H on Tuesday, October 21, 2014 12:32 AM
That wasn't too bad a kit for its time.
One minor issue that comes to mind. The guns/ammo access panels on the wings can be removed to show the internals. If you wish to display them open, you may wish to extend the ammo belts somehow, so that they actually reach the guns.
    March 2005
Posted by philo426 on Tuesday, October 21, 2014 8:27 AM
Thanks for the heads up!any other suggestions .comments welcome!
    March 2005
Posted by philo426 on Wednesday, October 22, 2014 11:38 AM
Painted the engine.Kind of looks like a Griffon engine.
    March 2005
Posted by philo426 on Thursday, October 23, 2014 9:04 PM
I forgot to mention something rather odd about this kit.;The sprues are molded in light gray,dark gray and black!
    August 2005
Posted by Phil_H on Friday, October 24, 2014 12:48 AM
Yep. Matchbox always moulded their kits in 2-3 colours to add interest for kids who didn't want to paint their models.
I just remembered something else about this kit -  the upper wing root area has insert pieces to form the curvature between the fuselage and wings. Take a little time there to make sure the alignment is right. Wink
    March 2005
Posted by philo426 on Friday, October 24, 2014 9:17 AM
Yes!might save a bit of body work!
    March 2005
Posted by philo426 on Saturday, October 25, 2014 11:43 AM
The inclusion of the fuel and oil tanks is a nice touch,but will be hidden when I join the fuselage halves.Fit is again quite nice.
    March 2005
Posted by philo426 on Sunday, October 26, 2014 12:01 AM
Put the fuselage halves together.Fit was good but some filler may be necessary.
    March 2005
Posted by philo426 on Sunday, October 26, 2014 12:06 AM
    March 2005
Posted by philo426 on Monday, October 27, 2014 12:13 AM
Put together and installed the vertical and Horizontal stabilizers. That is one tall tail!
    August 2005
Posted by Phil_H on Monday, October 27, 2014 5:48 AM
Looks like she's coming together nicely. Smile
    March 2005
Posted by philo426 on Monday, October 27, 2014 8:52 AM
Yes!Just some minor seam work that i usually have to do with all of my aircraft builds.The Williams Red Lion needed much more!
    March 2005
Posted by philo426 on Monday, October 27, 2014 8:59 AM
    March 2005
Posted by philo426 on Tuesday, October 28, 2014 10:45 AM
I like the 3 piece design of the lower wing sections.Much more thought was given to the design and much better than the usual stick the wings into the side of the fuselage routine.Pretty advanced feature at the time this kit was tooled.
    March 2005
Posted by philo426 on Tuesday, October 28, 2014 10:51 AM
    March 2005
Posted by philo426 on Tuesday, October 28, 2014 10:00 PM
Joined up the wings to the fuselage.In nearly 40 years of scale modeling,I have never seen anything quite like this wing structure.I really like it! Talk about thinking outside the box!
    March 2005
Posted by philo426 on Tuesday, October 28, 2014 11:14 PM
The wing fillets fit quite well!
    March 2005
Posted by philo426 on Tuesday, October 28, 2014 11:43 PM
fit was ok  but not perfect.Some filler will be necessary.
    March 2005
Posted by philo426 on Thursday, October 30, 2014 12:07 AM
The cowl fits fairly well,but not perfectly.
    March 2005
Posted by philo426 on Thursday, October 30, 2014 1:52 PM
Laid down the Ocean gray and dark green cammo.
    March 2005
Posted by philo426 on Friday, October 31, 2014 12:16 AM
I painted the spinner by first primering and then airbrushing the blue.I waited an hour and put the spinner nose down in a circle template and airbrushed Tamiya Flat White.
    March 2005
Posted by philo426 on Friday, October 31, 2014 12:27 AM
Peeled the masking tape from the canopy and re rusted the exhaust headers using Testor's Rust followed by Burnt Metalizer.
    March 2005
Posted by philo426 on Friday, October 31, 2014 10:55 AM
I found a major design flaw /weakness in how the prop blades are supposed to be attached to the backing plate.The glued butt joint will never cut it!i drilled a hole in each propeller blade and drilled 5 holes in the backing plate.I epoxied a short length of copper wire into each hole in the backing plate.When the epoxy cures the blades will then be attached.
    February 2007
Posted by Buckeye on Friday, October 31, 2014 11:14 AM
Looking good!
    March 2005
Posted by philo426 on Friday, October 31, 2014 11:20 AM
Thanks!
    March 2005
Posted by philo426 on Friday, October 31, 2014 6:00 PM
Mounted up the blades and spinner.The modification was well worth the effort.!
    March 2005
Posted by philo426 on Sunday, November 2, 2014 1:46 AM
I am really impressed with the decals.For 30 year old,unbagged markings they went down very well and seemed to respond to Microset.    They did take a long time to release from the backing paper.
    March 2005
Posted by philo426 on Sunday, November 2, 2014 11:41 AM
