Attaching canopy and photo etch
    November 2007
Posted by moose421 on Sunday, December 21, 2014 12:54 PM
Hello, Since I am new to doing quality aircraft builds what is the best way for attaching canopies. I have an Eduard Bf-110G-4 that requires me to attach photo etch pieces to the canopy. I am worried about clouding. What is the best way to go about this. I also want to add some detail to the canopy like the gun sight for the Schrage Musik. Any help would be appreciated. Thanks Moose
    March 2010
Posted by Nathan T on Sunday, December 21, 2014 1:06 PM
Hey Moose, use canopy glue, such as micro crystal clear or Gator grip. Both of these are safe for clear parts and dry clear. Strong enough too. Another alternative is Future. Apply it with a small micro brush. Good luck with the 110. I know it does have a few clear parts to deal with...
    January 2014
Posted by jelliott523 on Sunday, December 21, 2014 1:09 PM
I typically use the Testors clear parts cement.  Its pretty close to thinned Elmers glue.  It comes out a creamy white colored out of the bottle but dries clear.
Another method that I've heard about but haven't tried is to dip the canopy in Future (Pledge Multi-Floor) and this will prevent the fogging.  Again, I have not tried this myself so I cant say for sure if it works.  I've also hear that people will just use plain old white glue and thin it down a little and use that.
    March 2010
Posted by Nathan T on Sunday, December 21, 2014 1:13 PM
Dipping in future and using ca is a dangerous game. Especially when future used as a glue or clear pArts glue is plenty strong for this.
    January 2014
Posted by jelliott523 on Sunday, December 21, 2014 1:26 PM
Nathan T
That is specifically one reason I haven't tried it yet.  I had heard people on some of the forums claiming that the future created some kind of impervious chemical barrier to prevent fogging when using CA.  Thanks for your input on this, I think I'll stick with the methods I have used all along.
Posted by Bish on Sunday, December 21, 2014 1:37 PM
I always using CA when attaching PE parts to a canopy. I have found fogging is only an issue when there is no where for the CA vapour to escape to, this is why they fog when using CA to attach a canopy.
    January 2014
Posted by jelliott523 on Sunday, December 21, 2014 2:08 PM
Bish
Thanks Bish for that clarification!  Have you heard anything about dipping the canopy in future to supposedly stop the fogging from occurring, sounds questionable to me.
    September 2003
Posted by checkmateking02 on Sunday, December 21, 2014 2:34 PM
I don't know if it would work for a closed up canopy, but I've used CA to attach fuselage window in B-17's and B-24's.  Then I set the fuselage half in front of a fan and let the air blow across it.  I figured if the moving air blows the fumes away, they can't settle on the window.  So far it's worked, but this is done before the fuselage is closed up.
Posted by Bish on Sunday, December 21, 2014 2:34 PM
No, and I have yet to dip a canopy. Chemistry ain't my strong point but I can't see how the future would prevent it. Might be something worth testing though.
    January 2014
Posted by jelliott523 on Sunday, December 21, 2014 3:15 PM
I may have to give it a go on a scrap model I have at the house.  I have an old O2SU-Kingfisher that I dipped the canopies in awhile ago (several months) and they've been sitting in a sealed box since then to dry.  I'll see how the CA affects them.
    November 2007
Posted by moose421 on Sunday, December 21, 2014 3:18 PM
Thanks for all the tips.  I like using CA when attaching PE.  Just new that fumes and clouding occurred.  I like the fan idea and keeping it open.  Good thing most of the PE will be on before I install the canopy onto my 110.  I might then use the Testors canopy glue to attach the canopy to the aircraft.
Thanks again.
Moose
Just as a side note my work in progress is in the Reich Defenders V, hunters of the night.
Posted by Bish on Sunday, December 21, 2014 3:25 PM
Ok jelliott, I was going to try and dig old and old canopy, but if you have something to hand, that's good. Keep us posted.
Moose, I always use canopy glue when attaching just to be safe but on occasion I have used CA for a bit of extra strength if its not a good fit, along as its an open canopy.
    January 2014
Posted by jelliott523 on Sunday, December 21, 2014 3:30 PM
Bish
I'll be home in a few hours and I'll give it a shot.  I'll take some photos of it as well and do it as a TIP (Test In Progress) Post and put it under the techniques tab.
Posted by Bish on Sunday, December 21, 2014 3:35 PM
Good idea. I think I will dig a couple out, I often use vac canopy's and have a few un used plastic ones. Might be worth having a couple of tests, I might do one with and one without the future.
    January 2014
Posted by jelliott523 on Sunday, December 21, 2014 3:47 PM
http://cs.finescale.com/fsm/tools_techniques_and_reference_materials/f/13/t/153343.aspx
I'm not sure if I linked the above section properly.  But, its a thread I found in the techniques section regarding using CA to attach canopies that have been coated in future.
