Finished up the Fokker last night. Rigging was tedious but not as bad as I thought it would be. Using the stripped down EZ Line was the perfect choice. The 2 things that made it go smoothly was making a teeny tiny hook from real thin wire to reach between the lines to pull a through to where I needed it to go and little pieces of tape as a 3rd hand. Fortunately there's not a lot. A 1/72 DH.2 would likely push one to the edge of insanity.
The tough part was getting the turnbuckles on the line. .3mm OD brass tubing was used. For those of us that see "MM" and think of something that "melts in your mouth, not in your hand" that .012" OD with a .005" ID. A #80 drill bit is .0135 for comparison.
I've prattle don long enough.. Here's the completed Fokker E.III in 1/72 with a WIF scheme.
