B 52 and Napalm ? New Question
    October 2009
Posted by greentracker98 on Monday, November 23, 2015 4:40 PM
Quick question Did the B52s ever drop napalm, or was that more for the lower flying aircraft.
I have to get an accessory kit because my B 52 was an open kit and a lot of the bombs are missing. The accessory kit has a couple of napalm cannisters, just wondering.
Thanks
A.K.A. Ken                Making Modeling Great Again
    August 2015
Posted by crown r n7 on Monday, November 23, 2015 6:20 PM
Which B-52 kit do you have?
 Nick.
    September 2012
Posted by GMorrison on Monday, November 23, 2015 6:34 PM
Ordinance load outs on a bomber are all set up for one run over one target.
Fighter bomber can be a little different story in today's wars, but not a B-52 in Vietnam.
I don't know if those aircraft ever dropped napalm, although I doubt it, but they would have dropped a LOT on one area.
    November 2003
Posted by mississippivol on Monday, November 23, 2015 7:05 PM
You would need a lot of marshmallows. ...
Posted by rangerj on Tuesday, November 24, 2015 6:51 PM
While being taken back to  base camp, in a Huey, after an "extraction" from a recon mission we were told to look back and to the right. We could see continuous light flashes. We were told that we should be thankful we were not on the ground in that area because it was being bombed by B-52s. We could not here them (the B-52s) or see them. It was raining bombs and it was an unforgettable sight.
    January 2013
Posted by BlackSheepTwoOneFour on Tuesday, November 24, 2015 7:48 PM
B-52 don't drop napalms. The B-52s usually do carpet bombings using regular bombs. Napalms were dropped by fighter jets/aircrafts like Phantoms, Skyraiders, etc... for low level bombings.
    July 2004
Posted by stikpusher on Tuesday, November 24, 2015 7:55 PM
I'm sure a B-52 could drop napalm, but really don't see it ever being done for numerous reasons. In Vietnam, photos and film show the most common bomb types as 500 lb Mk.82s or 750 lb M-117s.
Considering the standard operations of B-52s to minimize the vulnerability by flying at high altitudes and their top speeds in the combat zone, a napalm strike from 25,000 - 30,000 feet with the inherently less accurate and smaller blast effect of napalm cans just does not sound like a good use of resources.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    November 2008
Posted by plasticjunkie on Tuesday, November 24, 2015 7:58 PM
rangerj
Sounds like an Arc Light mission.
 GIFMaker.org_jy_Ayj_O
    June 2004
Posted by seasick on Tuesday, November 24, 2015 10:55 PM
I believe it was only armed with the M117 750 pound bomb, or the Mk82 500 pound bomb. I'd personally like the USAF to have a bomb like the Soviet/Russian FAB-9000.
Chasing the ultimate build.
    October 2009
Posted by greentracker98 on Wednesday, November 25, 2015 12:51 AM
Thanks Guys I didn't think they would, but thought I'd ask. It's the Big Bad Beautiful kit
    September 2012
Posted by GMorrison on Wednesday, November 25, 2015 1:24 AM
Got it. Frankly, any or no bombs on the old Monogram kit can be used to tell a story.
Look around for a Monogram F-105, that will give you a chance to use the napalm.
SEA models are under represented, go for it.
    July 2004
Posted by stikpusher on Wednesday, November 25, 2015 2:38 AM
Or an F-100, or F-4B/F-4C down south, A-4, F-8, A-1, A-6, T-28, A-37, F-5, A-26, B-57... All of those commonly carried Napalm for sorties in the South.
       - Plankton
LSM
    October 2004
Posted by ikar01 on Wednesday, November 25, 2015 7:12 PM
Standard load on a 52 was 750 pounders under the wings and the bomb bay filled with 500 pounders.  The normal cell would be three bombers and how many tankers they needed.
Normally one to two would come back with hung bombs.
We had a briefing one day by some S.A.C. guy, for some reason, and they showed us a shot of three B-52s.  One was leading and had the other two somewhat behind but they seemed to be lined up with the lead's wing tip.  Then they showed a set of three mountains all filled with jungle.  There was supposed to be a enemy camp somewhere on the mountains.  The next shot had them completely devoid of trees and not much dirt left.  It seemed like a bit of overkill, but was very impressive.
    October 2009
Posted by greentracker98 on Wednesday, November 25, 2015 7:59 PM
Thanks guys
Stik I've been thinking about an A-1 Skyraider. not sure why I like it, maybe its the nickname Sandies
    May 2009
Posted by Pawel on Thursday, November 26, 2015 5:47 AM
Hello!
If you like Skyraiders, here's something for you, from my website:
Hobbycraft 1:72 A-1H Skyraider by Jacek Minich
And another one - that I've built myself - no napalm, but a real Sandy (SAR) loadout:
Hasegawa 1:72 A-1H Skyraider by Pawel
Good luck with your builds and haev a nice day
Paweł
www.vietnam.net.pl
    January 2013
Posted by BlackSheepTwoOneFour on Thursday, November 26, 2015 10:52 AM
I love the bottom pic of the Sandie. I see the rockets but not sure what are the other armaments. Can you ID them for me?
    May 2009
Posted by Pawel on Thursday, November 26, 2015 1:48 PM
With pleasure!
Let's move from the centerline outside - there's a 300 galon Aero 1a drop tank on the centerline. Next, on the left pylon there's a SUU-11A/A 7,62mm Minigun pod in case the wing mounted 20mm guns jammed (happened often), and a 150 galon drop tank on the right side. Next pylon is a LAU-61/A 19 shot FFAR (Folding Fin Aerial Rocket) pod - a variant of the LAU-3, with a shoot-away front cover. Next two are AN-M47 white phosphorous bombs - they could be used as smoke bombs if dropped safe, or as fire bomps when dropped live. Next pylon is again a LAU-61/A, and the final two are SUU-14/A sub-munition dispensers that carried explosive or tear gas "bomblets", often used to incapacitate foes surrounding the downed pilot, often together with said pilot, just before extraction.
You can read more here: http://www.vietnam.net.pl/A1moden.htm and here: http://www.vietnam.net.pl/A1en.htm
I'm glad you liked my model, hope I could help you with my info - thanks for reading and have a nice day
Paweł
www.vietnam.net.pl
    October 2009
Posted by greentracker98 on Friday, November 27, 2015 10:43 AM
Geeked Really cool builds Pawel. they are great. Thanks. On the sides below the cockpit, is that exhaust staining?
I watched a show about FACs a couple of days ago. They told about how the Sandies could stay up on station for hours. Great show
    May 2009
Posted by Pawel on Friday, November 27, 2015 2:49 PM
Thanks a lot, greentracker98!
Yes, it's the exhaust staining. A Skyraider without it is probably inoperational or else there's something wrong with it. I heard those big radial engines leaked oil all of the time and also let a lot of unburned fuel out - that leaves you with nice, black stains right there.
Good luck with your builds and have a nice day
Paweł
www.vietnam.net.pl
    June 2004
Posted by seasick on Friday, November 27, 2015 5:14 PM
The Hasegawa 1/72 scale aircraft weapons set #1 has 6 M117 750 pound bombs.
    March 2008
Posted by kg4kpg on Saturday, November 28, 2015 12:01 AM
rangerj
I remember in Iraq '91, a couple days before we rolled north into Iraq from Saudi Arabia we could see the flashes and here the thunder of the B-52's up at the border getting it ready for our 8" SP guns to come rolling through. It was very impressive, several minutes of flashes then several minutes of thunder soon after.
    October 2009
Posted by greentracker98 on Tuesday, December 1, 2015 5:00 AM
seasick wrote the following post 3 days ago:
Thanks Seasick, I have ^ this on order. It looks like a great addition to the BUFF.
GMorrison. Yes I'm doing the SEA version. I'm waiting for the paint for it right now. I'm doing the camo over black. Would the black be a matte finish or gloss?
Thanks everyone and good luck with all your builds
    June 2004
Posted by seasick on Tuesday, December 1, 2015 9:05 PM
You'll like the aircraft weapons set #1. There are also a good number of Mk82 500 pound bombs. I bought the set a while back and have used the bombs in it on several builds. I put four snakeye on my CF-104, four M117 on my F-100C. Nice to be able to alter a payload to fit your mood.
    October 2009
Posted by greentracker98 on Saturday, December 5, 2015 3:20 AM
New Question. Would the 52's use different bombs under the wing? I still don't have enough 117 bombs to fill up the under wing racks. There were only 6 in the weapons set.
Thanks
    July 2004
Posted by stikpusher on Saturday, December 5, 2015 11:40 AM
greentracker98
Thanks
The bombs on the wing racks would all be of the same type. There would be no mixing of Mk.82s and M-117s. All of one type or the other. Each had different ballistic properties (at least according to Jack Broughton's book "Thud Ridge") and that would throw off the computers by mixing them.
       - Plankton
LSM
    September 2012
Posted by GMorrison on Saturday, December 5, 2015 12:02 PM
And there would be the grave possibility that they would start running into each other.
    October 2009
Posted by greentracker98 on Saturday, December 5, 2015 3:17 PM
Thanks guys Bang Head Boo Hoo
Hmm, Are the bombs in the Big Bad Beautiful kit MK 117s? They look almost the same as the MK 117s in the Hasagawa weapon kit? Would that because of the different manufacturer?
    July 2004
Posted by stikpusher on Saturday, December 5, 2015 4:10 PM
The B-52 kit comes with M-117 (not Mk.117) 750 lb bombs, same as in the Hasegawa weapons set. These are essentially a WWII/Korean War era bomb with a more aerodynamic conical tail in place of the WWII style box fins
B-52's also carried the Mk.82 (part of the Mk.80 series) 500 lb Low Drag bombs which were far more "aerodynamic" and caused less drag when carried externally for the carrying aircraft
The Hasegawa weapons set should include this type as well.
Just curious, but have you tried contacting Revell to see if you can get a replacement set of the kit bombs?
       - Plankton
LSM
    October 2009
Posted by greentracker98 on Saturday, December 5, 2015 9:07 PM
Stik
No, My thunking went to "It's been out of production since god knows when" then I didn't even think to ask Revell. LOL
Hasagawa is calling them MK 117s
Thanks I'll do that, but I'm not holding my breath. I also need to find a windshield for it. It was broken when I got it. I did however find an AM windshield, Maybe I can find that website again.
asking now lol
    September 2012
Posted by GMorrison on Saturday, December 5, 2015 10:45 PM
Glue the windshield together, sand it smooth and paint it black. There's nothing to see inside- the flight deck is completely innaccurate.
