RB-36E Cold War Warrior, WIP
    January 2003
Posted by yardbird78 on Saturday, January 23, 2016 12:02 PM
I have had two of the old Monogram B-36 kits in the stash for a whole bunch of years, so I decided to put a couple of other projects on the back burner and build one of these
monsters.  The kit is intended to be an RB-36H, but the kit decals are wrong and useless anyway because of age.  I found some aftermarket decals for an RB-36E from the 5th
Strategic Reconnaissance Wing, 72nd Bomb Squadron that was at Travis AFB, California from January 9, 1951 until September 30, 1958.  The first B-36's that Convair built
were the XB and YB-36 prototypes and then 21 B-36A bombers.  The A models didn't really have a combat capability and were used for crew training.  After a couple of years,
Convair took all 21 of the A's plus the YB-36 prototype back to the factory, disassembled and modified them, then reassembled them as RB-36E Recce Birds.  The biggest mods
were turning bomb bay #1 up front into a pressurized camera compartment and filling bomb bay #4 with ECM and ELINT equipment.
..I am pretty fired up about this build as I have wanted to do a B-36 ever since I was a kid.  The question now is, "Can I keep the fire going long enough to finish a large, difficult
project".  I bought two of the Pavla resin kits for the gun turret bays and will use them for both upper gun bays.  I will open up the very large side oblique camera windows and
smaller tri-metragon windows on each side as well as the three vertical camera windows in the belly of the camera compartment.  Bomb bay #2 will get 40 of the AN-M26 photo
flash bombs, while #3 will get a scratch built 3,000 gallon auxiliary fuel tank, a new "communication tube" down the left side and hopefully some more added detail.  Both levels
of the forward crew compartment will get some added detail and I am hoping to scratch build the entire photo compartment interior.  Now I have to see if I can live up to my
dreams.
The Kit Box
I started simple with the wheels and struts
The Pavla AM turret bay boxes and pieces.  The only real difference between the forward and aft turrets is that the aft bay has a one piece cover.
The upper and lower forward crew compartments, the fwd & aft bomb bay bulkheads and the radio operator's panel at the rear of this area.  This overlaps the gun
bay unit by about 1/8 inch, so I will have to modify that somehow.
The forward gun bay tub.  It requires a HUGE hole to be cut out.
This shows the camera windows and crew observation windows cut out of the right side.  The left side is stock, but won't be for long.
Tags: B-36
The B-52 and me, we have grown old, gray and overweight together.
    January 2003
    September 2012
Posted by GMorrison on Saturday, January 23, 2016 12:20 PM
Holy Habu! Where have you been?
This looks like a great project, I'll be watching. I remember two things from that kit.
One the wing to fuse join had a bad geometry. I tried to fix it but wasn't real successful.
Second, the intakes were screwy looking. Some work with files fixed that.
    January 2003
Posted by yardbird78 on Saturday, January 23, 2016 12:30 PM
GMorrison
Life's events have overtaken me for the last several years, the biggest being taking care of my invalid wife.  That doesn't leave much time for modeling or anything else, but I have forced myself to set aside an hour or two a day to wrap myself up in my own little world and ignore everything else.  Thanks for asking.
Darwin
    March 2015
Posted by Toshi on Saturday, January 23, 2016 12:39 PM
This is a very nice start, I look forward to your progpress.  I'm sorry to hear of your situation with your wife sir, I hope all is well and fine for now.
Toshi
On The Bench: Revell 1/48 B-25 Mitchell
Married to the most caring, loving, understanding, and beautiful wife in the world.  Mrs. Toshi
    May 2009
Posted by Pawel on Saturday, January 23, 2016 1:01 PM
Hello Darwin!
I'm so glad to see you back on the forums!
You got yourself a helluva project - the B-36 is an otherworldly aircraft. I'll be watching this thread with great interest.
Good luck with your build and have a nice day
Paweł
www.vietnam.net.pl
    May 2011
Posted by Real G on Saturday, January 23, 2016 1:13 PM
You have an awesome project going, and are off to a great start!  I love those crazy gun turrets, and you rarely see them on a finished model.  I look foward to seeing your progress, but  beware the finished model is a beast to store!  When I was a wee lad, I had to put a piece of plywood under my model, as one of the main gear legs would not fit on my shelf!  Oh and don't use D cell batteries for nose weight, as they can leak!  Surprise
“Ya ya ya, unicorn papoi!”
    January 2003
Posted by yardbird78 on Saturday, January 23, 2016 1:22 PM
Real G
Thanks for the tip.  I normally use BB's for nose weight.  They are cheap, easy to use and fit in small places.
    November 2003
Posted by mississippivol on Saturday, January 23, 2016 10:45 PM
I ended up putting an old masterlock in mine. Cured that issue quick.
    July 2007
Posted by scorpr2 on Saturday, January 23, 2016 10:56 PM
I will be watching this one, it looks really interesting!  Keep up the good work!
    January 2013
Posted by seastallion53 on Sunday, January 24, 2016 3:51 AM
there is one of these a/c at Castle air museum  in Merced,ca.
Posted by Bish on Sunday, January 24, 2016 5:52 AM
Good to see you back yardbird. Some nice work there, look forward to seeing plenty more of this.
    January 2003
Posted by yardbird78 on Sunday, January 24, 2016 11:11 AM
seastallion53
That one is an H model recce bird and I am basing much of my photo compartment work on it.
Posted by MKelley on Sunday, January 24, 2016 11:34 AM
Where did you get the turrets? I have one sitting in the stash and I would love to add the turrets. Someone mentioned the wing joints, they are a pain in the butt. I am not sure how to fix it so, I am going to watch this thread to see some ideas.
    January 2003
Posted by yardbird78 on Sunday, January 24, 2016 11:51 AM
MKelley
I got them from a company called "Oxonians Plastic Fantastic" in England.  email:
MarkVerney@msn.com
    January 2003
Posted by yardbird78 on Monday, January 25, 2016 10:28 PM
I found a youtube video of a B-36 jettisoning one of those auxiliary fuel tanks and was really fascinated by it.  I think that my scratch built version looks pretty close.
http://youtu.be/ethVLMyxATM
Posted by jeaton01 on Tuesday, January 26, 2016 12:33 AM
Welcome back, Darwin, hope you can stick around.  While you were out I finished my RB-36H.  I would have liked to do a Travis bird as I live near there and used to see tham all the time, but wanted to do one with the white bottom and couldn't find any photos of Travis airplanes in that scheme, just aluminum.  I did rework the wing root, lowering it on the fuselage, but it was a job.  Here's  a link to my build log.
http://www.yolo.net/~jeaton/mymodels/b36/1b36/1b36.html
John
    September 2012
Posted by GMorrison on Tuesday, January 26, 2016 12:37 AM
yardbird78
GMorrison
Darwin
Darwin, I am thinking positive thoughts for you. Best wishes and have strength.
John I see put up a link for his build. Taught that kid everything he knows.
LOLs but seriously it is like the good old SAC GB's again.
    January 2003
Posted by yardbird78 on Tuesday, January 26, 2016 12:19 PM
jeaton01
Your B-36 turned out quite well.  I like the modifications that you made to the prop mounts and air intakes.  I will probably do that to mine as well.  I am not planning on doing the wing-fuselage joint mod as I don't think that it makes enough difference to be worth all that effort.  Did you use the plastic landing gear struts from the kit or metal AM parts?  I am concerned about how heavy this beast will be, especially with the amount of nose weight that will be required.  Your display case is gorgeous.
    January 2003
Posted by yardbird78 on Tuesday, January 26, 2016 12:22 PM
GMorrison
Thanks for the encouragement.  I will probably need it before I get this beast completed.
Darwin
    May 2009
Posted by Pawel on Tuesday, January 26, 2016 1:50 PM
jeaton01
Hello John, I would like to ask you what was wrong with the wing root, so that you had to rework it? On the photos it looks pretty drastic.
TIA, have a nice day
Paweł
www.vietnam.net.pl
Posted by jeaton01 on Tuesday, January 26, 2016 9:28 PM
Pawel, I haven't forgotten I owe you!
The wing is about 1/16 too high on the fuselage, maybe a bit more, and the way it should be is a perfect intersection with the top line of the fuselage and the top line of the wing.  Bugged the heck out of me, but only because this monstrosity of an airplane was real familiar over my house when I was a flea.  Probably just should have found some better meds.
John
Posted by jeaton01 on Tuesday, January 26, 2016 9:30 PM
Thanks, Darwin.  The plastic landing gear seems perfectly adequate on mine.
John
    January 2003
Posted by yardbird78 on Wednesday, January 27, 2016 1:31 AM
The Pavla gun turrets are also available from UMM (Unique Master Models) for a few dollars cheaper than the ones in England.
http://umm-usa.com/onlinestore/product_info.php?manufacturers_id=79&products_id=6506
    January 2003
Posted by yardbird78 on Saturday, January 30, 2016 8:23 PM
RB-36E Update #2
My eyeballs are rotating to the back of my head from working with the tiny instrument decals, so I thought that I would post an update to the Beast.  This is the pressure bulkhead between the back
end of the camera compartment and the front end of bomb bay #2.  The hatch in lower right is the entrance to the "Communication Tube" that ran between the front crew compartment and the one
in the tail.  It wasn't present in the camera compartment so that the guys in there could go to the front or back of the plane.  The hatch on middle left gives access to the bomb bay.  The window
towards the bottom is so they could monitor what was going on in the bomb bay without depressurizing the compartment.  The items on the top shelf are electronic components and the center and
bottom row are instruments and controls for these "black boxes".  I have applied a few decals and need to put on several more.  The silver disc in picture #2 is how the bulkhead looked when I
started working on it.  The decal sheet with the 1/72 instruments and controls is by Mike Grant Decals.
This is the jettisonable auxiliary fuel tank that goes in bomb bay #3.  I finished the construction and put on a coat of primer.  It still needs a finish coat of green.  See the you tube video above to
see a full scale B-36 jettison one of these things.
    January 2003
Posted by yardbird78 on Friday, February 5, 2016 12:02 PM
RB-36E Update #3
I have made some progress with the camera compartment and started on the modification to the APG-32 tail radar.
This is the front side of the pressure bulkhead 6.0 that divides the aft end of the camera compartment and bomb bay #2.  The hatch on the right is the entrance to the communication tube to the rear crew compartment and the one on the left is for access to the unpressurized bomb bay.  I am considering it complete.
This is the backside of bulkhead 5.0 that divides the forward end of the camera compartment from the forward gun bay.
Just starting.
Adding the "I" beam at the top, the first shelf and the hatch to the gun bay.
Adding the shelf and cabinet for the Camera Operator's control panel.
Just for a little diversity, I started on the modification to the fairing for the APG-32 radar that controls/aims the two tail guns.  The early B-36s had a single antenna/radome and later models had twin antennas.  The kit provides the twin antenna version with a much larger and longer fairing.  This has to be cut out and replaced with a smaller one.
    May 2009
Posted by Pawel on Friday, February 5, 2016 3:35 PM
Hello Darwin!
Nice scratchbuilding! What are your references on that? That's always the biggest problem for me. I'd also like to ask - what's happening with the tail?
Paweł
www.vietnam.net.pl
    January 2003
Posted by yardbird78 on Friday, February 5, 2016 8:42 PM
I have 7 or 8 different books on the B-36 for reference plus a lot of photos from the internet.  I also took about 200 photos of the B-36 at the Strategic Air Command Museum in Ashland, Nebraska, when I visited there in 2011.  Most of the B-36's had a tail radar with just a single antenna and a short fairing.  The J and H models had two antennas side by side and a much larger fairing.  I have cut out the large fairing and will rebuild it with the smaller one.
    May 2009
Posted by Pawel on Saturday, February 6, 2016 11:44 AM
Allright, I got it - thanks a lot and good luck with the mods, have a nice day
Paweł
www.vietnam.net.pl
    January 2003
Posted by yardbird78 on Sunday, February 14, 2016 11:43 PM
RB-36E Update #4
This is bulkhead 5.0 with the construction finished and the camera operator's panel to the right.
The same bulkhead with a coat of primer and the Camera Operator's panel temporarily in place.
