Tamiya P-51D build, my second "Short-Fuse Sallie"
    September 2013
Posted by Don Eisenhart on Thursday, March 3, 2016 6:55 PM
Howdy all,
The image below is my first attempt at SFS, and not really knowing the history of the P-51's, a history lession as well.  As few things are off, and some lession learned, which I am hoping to share, and to have shared with me!
Begining with the end in mind, as Steven Covy would say, I am hoping to build an enhance and lightly weathered after SFS was assigned in June 1944, with August 1944 being the circa.
Posted by oortiz10 on Friday, March 4, 2016 11:20 AM
Hi Don,
It looks like I might be a little late with this, but I thought I'd share how I did the paper tanks for one of my Mustangs.  First, I sanded to eliminate the seam.  I'm sure you're aware that doing so also eliminates the scalloped look of the paper at the front and rear of the tanks.  I was able to replace the scalloped look by using scraping the parts with a #10 General Purpose Xacto blade.  I scraped from the forward-most strapping towards the nose, and from the rear-most strapping towards the tail.  A couple of scrapes was all it took to restore the subtle indentations.  After the scraping was done, I took some fine sandpaper and rounded the "peaks" that resulted between scraped areas.  The great thing about this process is that  you can vary the depth of adjacent indentations to give the tanks a little more "personalilty."
If you're interested, here is the post showing my Mustang with its paper tanks, and a larger picture that better illustrates the final results.
Good luck with your build!
Cheers,
-O
(Edit for broken link to Mustang build post: http://cs.finescale.com/fsm/modeling_subjects/f/2/t/153434.aspx )
-It's Omar, but they call me "O".
    January 2015
Posted by BrandonD on Friday, March 4, 2016 11:49 AM
You're both better people than I am. I looked at the tanks for my P-51D and said, "Nah, I am building this as it sits after a combat mission in which he dropped the tanks."
It's the lazy way, haha.
-BD-
    September 2013
Posted by Don Eisenhart on Friday, March 4, 2016 1:43 PM
O,
Very nice indeed.  Nice soft edges on the overall, paint as well!
    September 2013
Posted by Don Eisenhart on Friday, March 4, 2016 1:45 PM
BD,
If it meets you end goal, and you are happy with it, well, mission accomplished!
    March 2015
Posted by Toshi on Saturday, March 5, 2016 1:56 PM
Nicely done so far!
Toshi
On The Bench: Revell 1/48 B-25 Mitchell
Married to the most caring, loving, understanding, and beautiful wife in the world.  Mrs. Toshi
    September 2013
Posted by Don Eisenhart on Saturday, March 5, 2016 4:13 PM
oortiz10
Hi Don,
Cheers,
-O
O,
All I can say is TANKS a bunch for the good tip!
DD
    February 2012
Posted by lawdog114 on Monday, March 7, 2016 9:44 PM
Looking good Don.  I'm guilty of the same with the paper tanks.  They are certainly are an exercise in patience.  That said, they were basically made out of paper mache then painted silver, so in reality I doubt they were perfect to begin with.   I may try O's idea next time though.  Also with the new cockpit, make sure you sand the sidewalls paper thin or the new addition will cause a flat dihedral.  Here's my recent build if you need a loose reference on Tamiya P-51
http://cs.finescale.com/fsm/modeling_subjects/f/2/t/162455.aspx
Joe
    September 2013
Posted by Don Eisenhart on Tuesday, March 8, 2016 6:15 AM
lawdog114
Joe
Thanks Joe,
There will be a gap between the fuselage and the cockpit, but a little Bondic will fill that in.  I love that stuff!
    March 2005
Posted by Devil Dawg on Sunday, March 20, 2016 12:06 PM
Great job, Mr. Eisenhart! Looking forward to seeing the finished product. Unlike a lot of modelers, I think that you can't have too many P-51 kits............
Devil Dawg
On The Bench: Tamiya 1/32nd Mitsubishi A6M5 Model 52 Zeke For Japanese Group Build
Build one at a time? Hah! That'll be the day!!
    September 2013
Posted by Don Eisenhart on Sunday, March 20, 2016 12:27 PM
Devil Dawg,
Thanks, and please my name is Donnie, or Danger Don to my Cowboy Friends.
I feel the same way about Spitefires!
DD
    February 2012
Posted by lawdog114 on Wednesday, March 23, 2016 1:34 AM
Looking good Donnie.
    March 2015
Posted by Toshi on Thursday, April 28, 2016 1:42 PM
Everything looks fantastic.  I await patiently for your finale of your Mustang build.
Toshi
    February 2012
Posted by lawdog114 on Monday, May 2, 2016 10:04 PM
Looking good Donnie. Indeed it takes alot of fiddling to get AM pits to fit right in these. i normally use the True Details version. That radiator/intake area is one of the worst areas of this kit. Alot of sanding and rescribing...
    September 2013
Posted by Don Eisenhart on Tuesday, May 3, 2016 5:42 AM
Lawdawg,
Yeah, after a day or so of fitting, I went with what I had, which was not a perfect fit.
Then, the welds on the bottom seperated, so filler to the rescue.
And, I have not even address the raditor intake...
Posted by Gamera on Tuesday, May 24, 2016 11:47 AM
OUCH! And she was going so well, I hope you're at least able to save that beautiful cockpit you painted.
So did the Alclad craze the plastic or was it the Tamiya gloss you sprayed over it? Just wondering, I've used Alclad for years and never had any issues with it. Though it does say it will craze unless you lay down an undercoat, I always use Testor's MM gloss black.
    September 2013
Posted by Don Eisenhart on Tuesday, May 24, 2016 12:46 PM
Gamera,
I am thinking the Tamiya never really gassed out.
On the painted wing, you see here and having nothing really to loose, I shot Alclad black primer, base coat gloss black, and airframe aluminium within about 4 fours or so, just to see what would happen.
Rough finish to be sure as there was no polishing, but no crazing issues.
Which remindes me, how do you polish (which grit) inbetween coats?
Thanks,
Don
Posted by oortiz10 on Tuesday, May 24, 2016 1:07 PM
Hey Don,
I know you posed the question to Gamera, but if it's OK, I'd like to chime in with an answer.
As far as sanding between coats for a NMF goes, here's what I do.  I use Alclad's proprietary primer as a base coat.  Once it's on, I like to wet-sand with a 3200 pad.  The Alclad primer goes down pretty smooth on its own, but I like to wet-sand to make sure it's butter smooth and to even things out.  If I need to, I'll respray the primer; touch-up any spots that I sanded through.  Then, I'll wet-sand again to even things out.  Once everything's nice and smooth, I'll spray my first light coat of Alclad.  Again, wet-sanding to make sure everything's even and smooth.  (Notice I keep repeating smooth?)Then I'll spray a second light coat and repeat the process.  Usually, I'll continue my NMF with a third light coat, followed by a final wet-sanding pass with a 4000 grit pad.  Finally, I'll spray again and finish with wet-sanding again with a 6000 grit pad.  Yeah, it's tedious and a bit repetitive.  Might even be overkill and wasteful, but I've been very happy with my NMF results.
Hope this helps!  Good luck with SFS.  I think you might be able to salvage her with a good base coat (primer) and some sanding.  Good luck!
-O
Posted by Gamera on Tuesday, May 24, 2016 1:13 PM
Ahh ok. I normally just shoot the MM gloss black on the bare plastic as a primer. Find and fix any rough areas and then shoot more MM gloss black to get an even shiny undercoat. I've  had few issues with painting like this so I rarely ever polish it at all. I let this dry overnight at least though generally I leave it for a few days. Then I hit the model with Alclad, let it dry overnight, decal, and a few days later hit the model with a light coat of Testor's Metallizer overcoat varnish, it seems to dull the shine less than other brands of finish coat. Bad thing is it's out of production now so when I'm out I'll have to find something else.
PS: Looks like O and I posted at the same time Wink. Good advice there, and his NM finishes look great! Look up some of his work here, he's a heck of a modeler.
    September 2013
Posted by Don Eisenhart on Tuesday, May 24, 2016 1:24 PM
oortiz10
Hey Don,
-O
O,
Thanks.  I have not scrapped her yet.  As you know, I have a lot of work into her already.  I have already bought another 8th USAAF 1/48 (along with a 1/72), and I am planning on swapping decals.
What is NMF?
Don
    September 2013
Posted by Don Eisenhart on Tuesday, May 24, 2016 1:25 PM
Gamera, Thanks! Don
Posted by oortiz10 on Tuesday, May 24, 2016 1:46 PM
Don Eisenhart
...What is NMF?
Hey Don,
NMF means Natual Metal Finish.
Hey Gamera,
Thanks for the compliment!
Happy Modeling!
-O
