propellers
MAC
    July 2009
propellers
Posted by MAC on Tuesday, October 18, 2016 10:36 PM
How do I depict propellers spinning on an aircraft
Thanks
Mac
    June 2014
Posted by BrandonK on Tuesday, October 18, 2016 10:42 PM
There are many different ways. Some us PE props, some use plastic discs. It boils down to what you like on your models.
Dynamic propellers or prop blur are some of the PE brands. Clear discs are usually hand made.
BK
On the bench:
A lot !! And I mean A LOT!!
                         14 / 5 / 2
                              Tongue Tied
    July 2014
Posted by modelcrazy on Tuesday, October 18, 2016 10:51 PM
BK is correct. I use the disk method and paint the blur on it.
Here is a link to a tutorial.
http://gregers.fr.yuku.com/topic/11537/Prop-blur-tutorial-Picture-heavy#.WAbti-ArLIU
Steve
MAC
    July 2009
Posted by MAC on Tuesday, October 18, 2016 10:54 PM
Gents Thank you very much for the information
Mac
Posted by Don Stauffer on Wednesday, October 19, 2016 9:09 AM
If you have a decent graphics/photo program on your computer, it may have a rotation blur function.  Scan one of the kit props with a scanner.  Take the image and use the rotation blur function on it- adjust until it is pleasing.  Then print out on a viewgraph/transparency sheet.  Cut out the circle and you have a spinning prop.
    August 2003
Posted by noisey on Tuesday, October 25, 2016 1:42 PM
I replied to a post similar to this a few years ago.  I'll give you the abbreviated version on how I did it. I painted the props (yellow tips in my case), then scanned them into PhotoShop. Using the "radial blur" (spin) function in the "Filter" drop-down menu you can create the spinning prop effect. Once I got the effect I wanted I printed the images on adhesive clear label stock and then mounted them on clear plastic cut to the proper size. As I said at the time, it's more art than science.  I tried making decals, but the plastic label stock produced better results. Check the December, 2014 Online Reader Gallery (B-17G "Tailwind") for an image of the model.
noisey
