1/32 Tamiya F4U-1A Corsair VMF-214 "Pappy" (FINISHED)
    March 2017
Posted by Just 1 Squirrel on Wednesday, March 15, 2017 6:37 PM
OOOHHH BABY!!! Looking great sir!!!
Can't wait for the finished product!!!
    February 2012
Posted by lawdog114 on Thursday, March 23, 2017 3:50 AM
Thanks all for the kind words.
Panzer, where does one get Mek? Sounds great as Tenax is getting harder to come by and it's expensive. It's still better than Tamiya's Extra Thin in my opinion
I was finally able to sit down and get to painting this one.  740 was in the tri-scheme which calls for Non-Spectacular Sea Blue Non-Spectacular Intermediate Blue over Non-Spectacular White.  Is "Non-Spectacular" Navy talk for dull boring paint?  Anyways, I started with the preshading of the panel lines and then painting in the wing walk and lines.  Some things I'd rather paint in then use decals.  This was an exercise in patience. (Here you can see where I was practicing on the fuel leaks.....more later)
The walks were then taped off and I switched to the white, which would be the underside and part of the "Stars and Bars markings".  I wanted it dirty so I added a touch of XF-19 Sky Grey to the XF-2 Flat White.
Next I added the Montex masks for the Stars and Bars and covered the white areas.  I then sprayed XF-8 Flat Blue mixed with some XF-1 to darken it.  Here it is after everything is masked.  I used Tamiya tape at the mask joints as an insurance policy.
Next I sprayed the NS intermediate blue.  I mixed XF-18 Medium Blue with XF-2 Flat White then added a touch of XF-19 Sky Grey.  I then added Blue Tac worms to prepare for the NS Sea Blue.
My formula for this was mostly XF-17 Sea Blue with a few drops of XF-8 Flat Blue, then a few drops of XF-2 Flat White.
I took a break for a few days and poured over pictures of Corsairs on the Solomon Islands.  I wanted to get it right to the best of my ability,especially since dark colors can be challenging.  I saw that sun fading would be more appropriate than my normal streaking in these circumstances.  I added some XF-55 Deck Tan to the NS Sea Blue and got to it.
It didn't take long to get here...
Once I was reasonably happy, I removed all the masks.  Did I mention how much I love Montex masks?  I may never go back to decals if I can help it.
I added the flaps and started the weathering post shade.  This can be tricky on dark colors.
Opps.....I almost forgot this important part.....Dunce
I did some post shading, mostly dirting up the underside.  I added exhaust streaks too.
As I said, I studied some pics beforehand.  I saw that the area around the fuel tank was pretty weathered from fueling.  I learned that this area was notoriously leaky hence the commonly seen white tape.  I decided to try to duplicate the fading from the fuel on the paint without the often modeled "black exhaust streaks" in the area.  To me it kind of ruins the overall effect.  I initially tried this with diluted XF-64 and didn't like it.  I repainted it then added more XF-55 to the NS Sea Blue and came up with this.  I'm much more happy with it.  I may postshade the area a bit more
I'm ready for some gloss coat I believe....
Time to start on the little stuff...
    March 2015
Posted by Toshi on Thursday, March 23, 2017 4:35 AM
You're doing "Pappy" an extreme justice with this build as it nothing short of astounding.  This is true workmanship.  Everything looks fantastic and I'm very impressed.  You've brought out Boyington's corsair to life once again!!!
like a rabid fan of all things Corasair and VMF 214 let's not forget "Pappy" and his sometimes hairbrained tactics against the JAP's!!
toshi
toshi
On The Bench: Revell 1/48 B-25 Mitchell
Married to the most caring, loving, understanding, and beautiful wife in the world.  Mrs. Toshi
    November 2003
Posted by tempestjohnny on Thursday, March 23, 2017 5:52 AM
Wow.......just wow
    September 2014
Posted by rooster513 on Thursday, March 23, 2017 6:44 AM
Joe that's one of the nicest paint jobs I've ever seen! Those masks worked beautifully. Thanks for sharing your paint mixes also, very helpful to us. This is going to be a real beauty when all finished!
-Andy
    January 2015
Posted by Aggieman on Thursday, March 23, 2017 6:49 AM
Joe, I am in awe of your work here.  You are a maestro with an airbrush.
Posted by Gamera on Thursday, March 23, 2017 8:03 AM
Love her!!!
I suppose I have to try painting insignia someday, your results always look so fantastic. I just hate masking though.
    December 2007
Posted by PANZERJAGER on Thursday, March 23, 2017 9:14 AM
Joe,
1st. let me say this is a stunning paint job!!!!
As for the MEK, It is the main ingredient in Testors liquid cement.
But it is usually available at your local hardware store in quarts and gallons as a type of solvent.
Hope this helps.
 PANZERJAGER
    April 2013
Posted by Greatmaker on Thursday, March 23, 2017 12:43 PM
Decals? Lawdog doesn't need no stinkin decals.Bow Down
    May 2004
Posted by Colin Russell on Friday, March 24, 2017 3:01 PM
Awesome build, Lawdog.  You are an artist without doubt. Your "spectacular" paint should actually be "specular" and I think it refers to the amount of sparkle and light reflectance which the paint exhibits.  Non specular would be a dead flat matt with no sheen at all. I think this is correct and hope it is of value to you.  Keep up the good work.
    December 2010
Posted by 1943Mike on Friday, March 24, 2017 6:58 PM
Master class in airbrushing - advanced tutorial in building a Corsair kit - and it's all free!!!
Big SmileBow Down
"Le temps est un grand maître, mais malheureusement, il tue tous ses élèves."
Hector Berlioz
Posted by jeaton01 on Friday, March 24, 2017 9:16 PM
I would comment but I am not worthyBow Down
John
    March 2016
Posted by ardvark002 on Friday, March 24, 2017 9:17 PM
Lawdog, Your detail work is incredible. The engine is really,really great. Wish I can get to your quality of work. Will follow this build. Aardvark
    May 2008
Posted by MIflyer on Saturday, March 25, 2017 12:23 PM
Colin Russell
That's my understanding, as well. As opposed to the later Gloss Sea Blue.
Kevin Johnson    Ypsilanti, Michigan USA
On the bench: 1/72 Fujimi Ki-36 J-BAAR
    February 2012
Posted by lawdog114 on Wednesday, March 29, 2017 12:03 AM
That it is........."Specular"......or "mirror".  I'm a toolDunce
Thanks for all the nice words.  You folks are entirely too kind.
I'm finally done.  She's dressed up in the VMA-214 markings of Boyington's #740, or at least one of the planes he was known to use.  I used Montex masks for the main markings and Eduard resin wheels, as I didn't like the rubber wheels.  Other than the issues I had with the attachment of the wings, it was a dream..........definitely in my top three.  I wanted to depict her around the time this famous picture was taken, as she wasn't too beat up yet.
I couldn't decide whether I wanted to add the gun and fuel tank white tape.  I've seen Corsairs with and without one or both.  I ultimately decided to forego them on this build.  I might add them on the upcoming Jolly Rogers Corsair.
Thanks or following....
The figure came with the kit.  It's average and nothing special.  Certainly not one of my best efforts but you'll have that I guess.  I normally paint my faces with Testor's enamels and have a few shades I use.  It's been a while since I've used them.  The drybrushing on the face ended up being a little heavy and it "bleached out" a bit.  I may go back and repaint that part..........or I might not.
I can no longer resist the Airfix P-40, so that will be next with Neale's AVG markings.
    November 2003
Posted by tempestjohnny on Wednesday, March 29, 2017 5:51 AM
Stunning is the only word that comes to.mind. The double insignia on the bottom is interesting
Posted by Tojo72 on Wednesday, March 29, 2017 6:35 AM
Fantastic work
    September 2014
Posted by rooster513 on Wednesday, March 29, 2017 6:37 AM
Abosolutely love it Joe! Came out perfect!
-Andy
Posted by Gamera on Wednesday, March 29, 2017 7:40 AM
Your usual fantastic work! Yes
    January 2015
Posted by M. Brindos on Wednesday, March 29, 2017 8:03 AM
Whoa! That IS stunning. I'm going to toss in my vote for you to put that extra attention into that figure. you put that much attention into the bird, the pilot should be just as good. :)
Love this one, Joe!!
- Mike Brindos "Lost Boy"
    June 2014
Posted by BrandonK on Wednesday, March 29, 2017 9:51 AM
One of the best looking Corsairs I think I've seen. Super nice work, Joe.
BK
On the bench:
A lot !! And I mean A LOT!!
                         14 / 5 / 2
                              Tongue Tied
    March 2015
Posted by Toshi on Wednesday, March 29, 2017 10:15 AM
Absolutely Amazing!!!
Toshi
    April 2013
Posted by Greatmaker on Wednesday, March 29, 2017 1:02 PM
As always a work of art! It never ceases to amaze me how you can achieve not only consistent excellence but with every build you seem to surpass the previous one. It doesn't seem to matter whether or not the kit is a "dud". You always seem to make a high quality build.  If I could have just 10% of your consistent excellence. Id be happy.  Your builds, as always, are an inspiration to me.  Looking forward to your continuing endeavors. Thanks for sharing Joe!
Posted by jeaton01 on Wednesday, March 29, 2017 1:29 PM
Mighty fine, Joe, mighty fine!
John
    June 2013
Posted by bvallot on Wednesday, March 29, 2017 2:54 PM
That's pretty damn nice Joe! I might have to refer back to this on the next Corsair I do. Tamiya's rivet detail is amazing.
Well done!
On the bench:
Tamiya F4U-1  Kenneth Walsh
    March 2017
Posted by Just 1 Squirrel on Wednesday, March 29, 2017 5:17 PM
WOW!!! Great work Joe!!  Can't wait for the Jolly Rogers Corsair!
    August 2009
Posted by JOE RIX on Thursday, March 30, 2017 12:07 AM
By Gawd Joe, that is absolutely outstanding! Impecable workmanship from detail to paint to weathering. I am truly impressed. It has been nothing short immense inspiration and admiration to have watched you build this beautiful Corsair. Thank You so much for sharing with us.
Joe
"Not only do I not know what's going on, I wouldn't know what to do about it if I did". George Carlin
    September 2016
Posted by ManCityFan on Thursday, March 30, 2017 8:37 AM
Absolutely fantastic. I can't find the words to describe how good this is. Thanks so much for sharing this!
Dwayne or Dman or just D.  All comments are welcome on my builds.
    March 2013
Posted by patrick206 on Thursday, March 30, 2017 9:55 AM
Just a beautiful job you made of this, excellent in all ways. Fine tribute to Pappy and the Corsair, both of them great old war horses and so worth remembering well. Thanks very much for this post and the photos, you set the bar a mile high.
Patrick
    January 2015
Posted by BrandonD on Thursday, March 30, 2017 12:40 PM
Amazing, Joe. That's a great tribute to Pappy and a fantastic model.
Plus I learned a new word! Spectacular! ;)
-BD-
