WIP Revell F-18F Super Hornet 1/48 - COMPLETED!
    December 2013
Posted by route62 on Monday, July 10, 2017 6:06 PM
I bought this kit for a deal at $10 bucks.  The box was rough, it had been opened, and few parts were missing including the canopy.  A visit to Revells online parts order form and a few weeks later the kit is now whole.
I plan to build it OOB and use the decal sheet to depict the Diamondbacks marking as shown on the box art.
At first glance the kit looked promising.  Full decal sheet nicely printed, recessed panel lines, lots of options for underwing goodies, nicely detailed if not totally accurate wheel wells and cockpit.  That all went out the window when assembly started and I was again elbow deep in fixing the fit issues common with Revellogram kits.
Lots of clamping, filling pin marks and so on.  On top of that the kit is warped once the top and bottom halves are mated.  Nothing horrible, but typical with Revelogram kits.
The instructions call to assemble the seats and other cockpit bits prior to installing the cockpit tub into the fuselage but after going over the steps I decided I would have plenty of access to the cockpit tub after it was installed and would still be able to paint it once installed.  I will treat it the same way I paint wheel wells, painting the fuselage first then masking cockpit and wheel wells off and painting it later.
This will make masking easier and I wont break off any of the small bits that normally would be inside the cockpit tub.
The intakes come as 4 parts per side.  Lots of seams to fill.  I will update as progress continues.  Glad I only paid 10 bucks...
    March 2015
Posted by Toshi on Tuesday, July 11, 2017 3:59 AM
Well now, with all the major issues you've mentioned, your technical skills have vastly overcome this project.  Great job sir, keep up the good work.
On The Bench: Revell 1/48 B-25 Mitchell
Married to the most caring, loving, understanding, and beautiful wife in the world.  Mrs. Toshi
    May 2006
Posted by Shipwreck on Thursday, July 13, 2017 4:50 PM
Route62, I think what you are doing is something called modeling skill. Good job and I am looking forward to your progress.
On the Bench:
Revell 1/96 USS Constitution - rigging
Kinetic 1/48 YF-104A 5-2957
Trumpeter 1/350 USS Hornet CV-8
Revell 1/48 B-1B Lancer Prep & Reasearch
    December 2013
Posted by route62 on Tuesday, July 18, 2017 5:25 PM
Minor update on the Super Hornet.  Filled all the seams on the inside of the intakes as best as possible.  Turned out better then I had expected once I painted the insides of the intakes.  The turbine fans are a simple piece but do the job.  I weathered the fans a little but the flash on the camera washed out the weathering in the picture.
installed the intakes onto the fuselage and filled all the other seams.  Just about time to prime and see what still need corrected.
    June 2004
Posted by seasick on Friday, July 21, 2017 12:09 AM
One of the design features of the F/A-18E/F is that the engine blades are recessed into the aircraft and are not visible through the intakes. This feature is also in the F-22 and F-35.
Chasing the ultimate build.
    December 2006
Posted by Fly-n-hi on Friday, July 21, 2017 2:51 AM
For $10 this is one of the best values out there! Good luck with this! Should be fun to see your progress!
    December 2013
Posted by route62 on Friday, August 4, 2017 8:47 PM
Painting has commenced.
With all major assembly and sub assembly done, pre shading was completed.  The majority of the aircraft will be standard 2 tone navy grey so I decided to try some marbling and pre shading together.
Since the model had been sprayed with tamiya primer, it was already a light grey.  Instead of black basing or using black pre shade I decided to use dark grey and white for marbling and panel line shading.
It will be interesting to see how this turns out.  Hopefully I will get some tonal variation and break up the over all color with the panel line shading.  After spraying the color I plan to do some post shading to highlight random panels.
On to the pics...
Fixed canopy in, masked and sprayed black so the inside of the canopy will be the right color.
Primed
Marbled and pre shaded.
    October 2009
Posted by Ultra on Saturday, August 5, 2017 3:19 AM
Im excited to see how your technique turns out this time.  Those last couple of the preshading and marbling look very well done.
    March 2015
Posted by Toshi on Saturday, August 5, 2017 7:07 AM
 Nicely done.
Toshi
    May 2006
Posted by Shipwreck on Saturday, August 5, 2017 8:31 AM
Route 62, I believe that marbling is a great idea. No color is consistent through out and marbling will break it up. I have used it in NMF; It will be interesting to see how it works on a modern grey jet. You certainly have a good start!
On the Bench:
    December 2013
Posted by route62 on Saturday, August 5, 2017 6:45 PM
I was able to shoot the color today.  The results of the marbling with the preshading turned out quite nice.  Subtle variation and the pre shading breaks up the color.
The underside was harder to capture on camera so I am not sure it will show in the pics but the top side shows well.  I plan to do some light post shade on random panels once dry.  I will then mask off a panel here and there and color it a lighter shade of the original color to give the apperance of re painted or replaced panels.
A coat of clear flat to seal in the grey and then mask off the areas that will be red per the box art paint scheme.  Tails were not painted since they are going to be red.
Top side
Bottom
    December 2013
Posted by route62 on Tuesday, August 15, 2017 6:47 PM
Since shooting the F-18F with the base colors I have been elbow deep in masking for the secondary colors.  I bought a Cameo 3 vinyl cutter a couple months back and now feel familar enough with the software to design masks to replace some of the larger decals and paint on the markings.
The VFA-102 Diamondbacks has a great paint job.  I think it was done for an airshow back a few years ago.
Paint scheme in question (computer rendition, could not find a pic of the real thing at this angle)
Decals that came with kit.  (I cut the sheet into smaller sections so I could scan them)
I decided to try replacing the decals on the aircraft spine, wings tips and tails wings with painted on markings.  To that end i used the cutter for the masks.
Cameo 3 cutter
The end result
Here is the masking tape after masks were cut and applied
Now the model is ready for red paint.  I plan to shoot white first to help seal in the masks and then the red.  After learning to use the cutter and creating this first attempt I realize I am only scratching the surface with this thing.  Once I get the art work created, I will be able to paint on roundels, german cross, stars and bars, and lettering to name a few.
With a cad program I should be able to create masks for canopies.
I will post results.  Thanks for tuning in.
    June 2017
Posted by fotofrank on Tuesday, August 15, 2017 8:33 PM
Ya know, I saw this model in real life over the weekend. Just now seeing the pictures of the build, I'm just out of words. When the airplane is done it will look amazing.
OK. In the stash: Way too much to build in one lifetime...
    February 2014
Posted by silentbob33 on Tuesday, August 15, 2017 8:38 PM
That is really cool! I didn't know there was such a thing as the vinyl cutter that you could buy. I'm looking forward to seeing how it all works out
On my bench: Academy 1/35 UH-60L Black Hawk
    December 2013
Posted by route62 on Wednesday, August 16, 2017 10:36 AM
The cameo 3 runs $200 if you do not get it will a bunch of accessories that as modelers we do not need.  The accessories are for the scrapbook world.  You can also get a cameo 2 machine for less and there are other makers for around $100.
I got the cameo after reading reviews and seeing that their software works best for the needs of a modeler.  The software from other manufacturers were more specific to scrapbooking but the Cameo line, the software is more general and works very much like a drawing or photo editing program.  Also The cameo software will let you import from other software like photoshop, illustrator and cad programs.
There are upgrades to the software, specifically if you want to import the other files.  The upgrade runs $30-50 depending on the seller.
So far I have not needed to upgrade.  Perhaps in the future as I get better at creating the artwork.  Also the cameo will cut up to 2mm thick so i can now create parts from thin styrene sheet much like photo etch.  It will also etch metal.  It wont cut metal but it could be used to create panel lines and rivet detal on thin metal.
It also cuts fabric and leather as well as other materials so like I said, just scratching the surface.
Posted by jeaton01 on Wednesday, August 16, 2017 10:45 PM
I'll second the recommendation for the Silhouette Cameo.  I've done quite a bit with mine and it has been a great modeling tool.
John
    December 2013
Posted by route62 on Sunday, October 8, 2017 5:37 PM
Finished up the F-18F today.  Last I left off on this WIP I had completed the masks to paint the diamonds on.  The following pics sum up the build to completion.  On to the pics...
Red applied to replace kit decals:
Main paint job done and onto the decals.  This kit had a ton of decals.
Since I painted this to depict an airshow bird, the weathering was left to a minimum as the reference pics I found show the aircraft basically clean.  I did just enough of a wash to highlight the panel lines and engraved detail.  I applied a semi gloss clear over the red areas and a flat clear on the gray parts.
I built the kit out of the box.  I added seat belts using masking tape.  I was impressed with the kit overall.  The cockpit is a bit basic and would benefit from some resin seats.  No major issues and the decal sheet provided enough decals to do this paint scheme as well as standard two tone grey navy f-18 so now I have a set of decal spares.  Thanks for looking.
    January 2003
Posted by Darren Roberts on Sunday, October 8, 2017 7:13 PM
NOICE!!!!!!!!!!!!!!!!!!
    February 2014
Posted by silentbob33 on Sunday, October 8, 2017 7:23 PM
Great job! Looks like those masks worked out very well for you
    May 2006
Posted by Shipwreck on Monday, October 9, 2017 4:18 AM
Really nice job Route66. You gave me incentive to build mine OOB! Thanks for sharing.
On the Bench:
Posted by Don Stauffer on Monday, October 9, 2017 8:41 AM
Looks great!  I have a fond affection for the 18. I worked at MDC when it was birthed.  It had a difficult birth and infancy, and I was glad to see it survive and become a successful aircraft.
    December 2013
Posted by route62 on Tuesday, October 17, 2017 3:10 PM
Thank you all.  Going back to my preferred cold war jet era with an F-86 build in NMF.  Also working on a Ju88 desert scheme.  I will post WIPs as soon as I have enough of a start on the builds.
    June 2014
Posted by BrandonK on Tuesday, October 17, 2017 10:51 PM
That's a very cool scheme. Very well done.
BK
On the bench:
A lot !! And I mean A LOT!!
                         14 / 5 / 2
                              Tongue Tied
