Hasegawa 1/48 P-40N
Hasegawa 1/48 P-40N
Posted by jeaton01 on Wednesday, August 8, 2018 11:25 PM
I had so much fun seeing my Planet XP-40Q get to the finish that it just seemed right to go straight on to the next in line P-40 variant.  It's been pretty smooth sailing as I am just doing an out of the box build but with Eduard seat belts and this is such a nice kit.  I've read that the aft cockpit insert can be a mis-fit, so I worked on that by removing some material from the mating surfaces of the fuselage in that area.  I also assembled the tail sections to the forward fuselage parts so I could get a good fit there and that allowed application of glue from the inside.   With the sides and top aligned there is a slight misalignment of some panel lines on the right fuselage half to clean up later, but they may be under the insignia decal.
I went through the instructions to find any other inserted parts but all I found were the lower gun panels, which fit very well and were glued from the inside.  The instrument panel has a lot of relief, like the real thing with panels at different levels and some instruments recessed and other sticking out of the panel.  I used the alternate decals without the black surrounding areas and had pretty good luck, probably because I used Mr. Mark Softer.  Not much was happening with Microsol.  Good enough for my 71 year old eyes.  I wish I had leveled some of the switches on the mid level switch panel, I didn't realize that Hasegawa had molded the switches on them.
John
    July 2004
Posted by stikpusher on Wednesday, August 8, 2018 11:41 PM
Looking good so far!
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    February 2012
Posted by lawdog114 on Wednesday, August 8, 2018 11:48 PM
Coming along nice. Indeed those plugs are a pain. None fall on panel lines either. Great sanding and scribing practice.
Posted by keavdog on Wednesday, August 8, 2018 11:57 PM
Ditto!  Those belts give me fits.  One of the first airplane models I built was the old monogram p40b tigershark.
Thanks,
John
Posted by jeaton01 on Thursday, August 9, 2018 12:03 AM
Do any of you guys know what the vents are for outboard of the gun inserts on the lower wings?  See the last picture on my first post.
John
    July 2004
Posted by stikpusher on Thursday, August 9, 2018 12:15 AM
I can’t say without looking in a book. But they are present on my P-40F kit as well...
       - Plankton
LSM
    August 2012
Posted by Rambo on Thursday, August 9, 2018 12:19 AM
This is going to be a good looking build good luck with that huge nose decal.
Clint
    July 2004
Posted by stikpusher on Thursday, August 9, 2018 12:31 AM
jeaton01
I just looked it up- bomb racks. Starting with the P-40E-1, there were rack attachment points there for small bombs. Or a cover plate could be fitted there.
       - Plankton
LSM
Posted by jeaton01 on Thursday, August 9, 2018 12:11 PM
Thanks, Stik.
John
    February 2005
Posted by RadMax8 on Saturday, August 11, 2018 10:01 PM
Going through the production run backwards, it looks like!
Youre off to a good start on this one. Cockpit looks fabulous, the PE seatbelts are just what the doctor ordered!
    November 2003
Posted by tempestjohnny on Sunday, August 12, 2018 7:10 PM
RadMax8
Yea what he said
Posted by jeaton01 on Monday, August 13, 2018 12:02 AM
Not backwards so much as all over the place, as usualPropeller.
This is actually the second N I have done in the last 20 years or so, the other was the Hasegawa 1/72 kit that had all the international insignia.  And I have a Special Hobby 1/32 P-36 and a Monogram 1/48 P-40B also in the display cases.  Maybe I will do a P-40F or L before I burn out on P-40's, who knows.  Anything but go back to work on the Monogram/Lone Star B-26 I also have underway.  I do need to do something on that one or two days a week, I think I'm suffering from PE fatigue on that one.
I have the neutral grey and some of the ANA 613 OD on the Hasegawa N, prop painting is in progress.  I was surprised to find that the canopy parts which are in three sections are a little too long to fit, at least the way I have things put together.  Of course I figured that out after gluing on the windscreen and aft section, whereupon I found that the funny shaped sliding section wouldn't fit.  I filed off some material from the back edge of that section and it then fit, but the intelligent way to deal with it would have been to test fit and remove the errant material from the back of the aft canopy section, or better yet take some material off of the back of the aft cockpit plug, which actually would improve its fit to the width of the fuselage.
I've also gotten some Accurate Miniatures P-51 wheels adapted to the Hasegawa struts and painted them.  I understand the N used those wheels which are smaller than what is in the Hasegawa kit.
John
Posted by jeaton01 on Monday, August 13, 2018 7:33 PM
More paint.  The next task is to do something to rescue this sweetie from the grip of boring OD and NG!  Not even the Dark Green by itself will save the day.
John
    February 2012
Posted by lawdog114 on Monday, August 13, 2018 9:16 PM
Looking great. I know what you mean about OD. You could try fading and or streaking the upper surfaces to break it up.
Posted by jeaton01 on Tuesday, August 14, 2018 12:36 AM
Yeah, it's going to need some of that, Joe.
John
Posted by jeaton01 on Tuesday, August 14, 2018 7:27 PM
Here's where it's at now.  Most of the little parts to be added later have also been done up through paint.  If you look closely at the horizontal stabilizer seams you will see I am still working them down after applying some thick paint with a fine brush to the join.  I have also added a little aluminum powder in a few wear areas and dome some random addition of faded olive drab in areas that get the most sun.  I am trying as hard as I can to let the paint cure up before I put on a gloss coat for decals, but I usually get a severe case of git'er done at this point which often does not yield the better result.
John
Posted by jeaton01 on Friday, August 17, 2018 12:10 AM
Decals complete.  That big decal on the nose required holding my mouth just right.
John
    July 2003
Posted by ridleusmc on Friday, August 17, 2018 1:50 AM
I love the look of that one.
Posted by keavdog on Friday, August 17, 2018 3:01 AM
Looking good John!  That big red bird head sure breaks up the OD!
Thanks,
John
Posted by jeaton01 on Sunday, August 19, 2018 12:40 AM
Thanks, John and Ridle.
This one is in the display case, it has been a fun build.  At the bottom, some photos next to the Monogram AVG P-40.  I think the bird on the nose may be a parrot, I had a Red Lored Amazon that had somewhat similar coloring way back when, long story you don't wanna know.  You did not want to underestimate the power of that bird's beak!
There's a lot of photos, partly because I built it so I could display it closed cockpit with the Hasegawa hood and open using a Squadron hood, the vacform canopy section fits much better in the open position.
I used some wheels from an Accurate Miniatures P-51 kit on the P-40N as that was what they used instead of the wheels in the Hasegawa kit which are the usual larger standard P-40 wheels and tires.  Quite a difference compared to the P-40B.  The difference in the depth of the fuselage between the two is also very apparent.
John
    September 2017
Posted by kensar on Sunday, August 19, 2018 4:49 AM
Two great looking birds there John.  The parrot nose art really adds a lot of color.
Kensar
    January 2015
Posted by PFJN on Sunday, August 19, 2018 2:24 PM
SurpriseWow, that really looks great.
1st Group BuildSP
Posted by jeaton01 on Tuesday, August 21, 2018 9:03 PM
Thanks to both of you!
John
    September 2016
Posted by ManCityFan on Tuesday, August 21, 2018 9:15 PM
Very nice job on both those birds.  Gotta say, that parrot head is a real show stopper.  Could not have been easy to get those decals on and looking so good!  Great job!!
Dwayne or Dman or just D.  All comments are welcome on my builds.
    December 2010
Posted by 1943Mike on Tuesday, August 21, 2018 10:10 PM
What fine looking models! Super work!
"Le temps est un grand maître, mais malheureusement, il tue tous ses élèves."
Hector Berlioz
Posted by jeaton01 on Tuesday, August 21, 2018 10:14 PM
Thanks, Dwayne.  Yes, the mouth had to be held right while putting on those decals.  It helped to make sure they were very slippery on the decal paper before trying to move them, and then keeping a lot of moisture under them until they were in place correctly.  Easy to stretch them out of shape!
Note:  The next paragraph is out of date as I have re-photographed all of the finished model pictures with the frames corrected.
(One more photo to correct an error I made on the aft canopy framing, as it is only the top longitudinal framing that is inside and is glued on plexiglas.  The two vertical frames are straps over the outside and are metal, and should be painted.  Took it back to the paint shop and painted them.)  In the process the pitot tube went south so I made up a new one with .032 music wire, some scrap pe, some soldering, and some filing to shape.  Actually I smashed the end of the music wire with a hammer to get that flattened part on the front, then pointed it with the bench grinder.
 A replacement photo here with 4 of my P-40's, from lower right cw:  AVG P-40B, 75 Sq, RAAF P-40E, 502FS/337FG P-40N, and the P-40Q.
John
Posted by jeaton01 on Tuesday, August 21, 2018 10:18 PM
Thanks, Mike.
John
