Help masking 1/72 wheel wells
    January, 2014
Posted by boatdetective on Sunday, February 10, 2019 7:11 PM
Doing one of Eduard's wonderful 1/72 series- an F-6fN. It's time to start painting and I am dreading dealing with the wheel wells. The wells are well defined and I hand painted them to start with...but what do I do now? I just know that Tamiya tape will not stick well enough and there are lots of sharp turns.  Do I paint the wings and hand paint the wells afterwards? How about liquid mask? What are your thoughts in terms of techniques/products?
    January, 2009
Posted by fermis on Sunday, February 10, 2019 8:53 PM
I like to use poster putty (poster tac...blue tac).
It is very handy stuff to have around. I mainly use it for masking camo patterns (leaves a nice, soft edge). It's every bit as good for masking gear wells too!
It's pretty sticky when new, and is a bit of a pain to remove all of it, but once it gets some paint mixed in with it, that problem goes away.
    September, 2012
Posted by GMorrison on Sunday, February 10, 2019 9:09 PM
I thought they were blue like the wings?
    January, 2014
Posted by boatdetective on Sunday, February 10, 2019 9:15 PM
Hmm- the instructions do call out for navy blue. However- I don't know why they would spray paint up in the well following assembly. I assumed that it would be zinc chromate (green) primer like the rest of the interior.
    January, 2014
Posted by boatdetective on Sunday, February 10, 2019 9:16 PM
Ahh- looks good. I'll have to try it. Thanks!
    January, 2009
Posted by fermis on Sunday, February 10, 2019 9:35 PM
Good call G!
With the all over Navy Blue scheme...yes, the wells are the same as the outside.
For the tri-color schemes...white, just like the belly.
    August, 2012
Posted by Rambo on Sunday, February 10, 2019 9:52 PM
Can also get them cheap foam paint bushes pull them off the handle and stick in the wheel wells they will form to hole.
Clint
    April, 2010
Posted by Theuns on Sunday, February 10, 2019 10:47 PM
I use wetted out toilet paper. It feels all gooey but u simply press it into the well and let it dry over night. Then the edges can be filled with poster tac if you want.
When paint is dry simply pull out the now dried paper plug. Works well and does not affect the paint in the well....unless you used acrylic, I dont know how wet paper will soften it ?? I alwys paint with enamel.
Theuns
    August, 2013
Posted by Jay Jay on Monday, February 11, 2019 3:54 AM
I use foam ear  plugs, the kind you have to squish up with your fingers before inserting in your ears but in this case your wheel wells. after a bit they expand and conform to the shape of the whell wells and can be used on any kind of cured paint as well. if they're too large they can be trimed down with scissors
    November, 2009
Posted by Don Stauffer on Monday, February 11, 2019 8:53 AM
I use a combination of poster tack and facial tissue.  A slight dampening of the facial tissue allows you to mold it down into the depression so none sticks out to mask paint spraying.  I use a little poster tack to hold the tissue in the well.  I also use facial tissue to mask cockpits.
    July, 2004
Posted by stikpusher on Monday, February 11, 2019 9:12 AM
GMorrison
Yes, the USN/USMC in WWII usually had their aircraft wheel wells painted the same color as the matching surrounding external area when built at the factory. Light Gray, White, or Sea Blue depending upon the scheme of the time.
As to the original question, I like to use the wet toilet paper technique already mentioned here. Silly Putty is another option.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    May, 2013
Posted by Greg on Monday, February 11, 2019 9:21 AM
Theuns
Theuns
Me too. Except I've switched to using tissue paper (like the stuff fancy gifts are packed in, not "Kleenex") because the toilet paper and/or facial tissue sometimes leaves some fuzzies behind.
-Greg
fox
    January, 2007
Posted by fox on Monday, February 11, 2019 7:40 PM
Silly Putty is my go to for jobs like that.
Jim  Captain
 Main WIP:
   On the Bench:  Revell 1/96 USS Kearsarge - 70%
    February, 2003
Posted by oortiz10 on Monday, February 11, 2019 10:10 PM
I second Silly Putty. It comes out easier and cleaner than poster putty. When possible, I like to press the gear doors into the SP to paint them at the same time as the underside of the fuselage.
It's pretty sturdy stuff. Here are a couple of shots of when I used it on my F-80 under Alclad primer and paint.
Good luck!
-O
-It's Omar, but they call me "O".
    April, 2003
Posted by keavdog on Monday, February 11, 2019 10:17 PM
Lots of good ideas here, particularly the one that says no masks needed ;)  I stuff tissue in and really poke it in with a toothpick.  The mask over the tissue and cut trim with an exact.  I get a little overspray on occasion but easy to touch up.  I do the same with cockpits and cowls.
Thanks,
John
    November, 2003
Posted by mississippivol on Monday, February 11, 2019 10:33 PM
Silly putty is what I use. Super easy.
    December, 2010
Posted by 1943Mike on Monday, February 11, 2019 11:09 PM
Although I haven't built any 1/72 aircraft - only 1/48 and, shortly, 1/32, I am a Silly Putty believer!
I actually bought a pound of the stuff (blue color in a BIG blue egg!) so I obviously find it easiest for me to work with. I know, I know ... I'm nuts to have bought so much but I like the stuff. I transfer the blue stuff to the smaller egg I have to work with on the bench.
"Le temps est un grand maître, mais malheureusement, il tue tous ses élèves."
Hector Berlioz
    April, 2003
Posted by keavdog on Monday, February 11, 2019 11:17 PM
I'll have to try silly putty.  Btw I found a 5 lb blob!!!
Thanks,
John
    July, 2018
Posted by Tickmagnet on Tuesday, February 12, 2019 6:38 AM
Here's another vote for silly putty. It's your friend indeed.
