Since it really is my birthday today, I played hookie and decided to spend some time at my bench. Because I am making good progress on another project that I'm cranking out for a GB, I decided I'd start on my A-10.
I haven't exactly finalized what markings I want to use, but I know that I want it to be a FSD or very early production airframe. For that reason, I had to make a few mods.
In the office, I had to carve out the ACES seat bottom that was molded to the tub and box in the gaping hole. The seat will be replaced with an ESCAPAC seat. I don't think it's the exact version the early A-10 used, but it's not an ACES seat and therefore a little more accurate.
I also had to remove the chaff dispensers from under the wing and wheel sponsons.
In hindsight, I probably could have left the fairings and filled in the dispensers instead of removing it all completely. Oh well. I can live with it.
I also had to remove some sensors from the nose and tail.
A few swipes with my sanding sticks made the job easy enough.
When I opened the box, I was surprised to see Sierra Hotel's resin engine inlet/fan and closed deceleron set.
I decided to go ahead and chop up the nacelle assembly in prep for the resin intake lips.
I also sprayed some paint on the engine parts in prep for assembly.
Here's what the new fans and inlets look like dry-fitted together.
Pretty slick, eh? Well, maybe except for the giant thumb.
Well, that's where things are at. Stay tuned for more, and I promise I'll stay true to my title and have less Ernie and more BRRRT! going forward. Well, after today, anyway.
Comments, questions and criticisms are always welcome. Thanks for stopping by!
Cheers,
-O
