1/48 Hasegawa A6M2b Zero, Carrier Akagi,“Pearl Harbor” (Progress and finished)
    February 2012
Posted by lawdog114 on Saturday, April 17, 2021 3:04 AM
Hello, I thought I would share my latest project. Here is the first of my Pearl Harbor builds I decided to take on at the same time (the other being George Welch's P-40 with the Airfix kit).  I enjoyed the Tamiya A6M3 Zero so much, I needed an A6M2 Type 21 as well. Unfortunately, the best in this scale is still the Hasegawa kit.
Unlike the beat up A6M3 experiment, the A6M2 will be somewhat pristine as they were fairly new at Pearl Harbor.  Don't mistake pristine with not used.  It will not get heavy chipping, but it will not look like it was waxed either.  It still has to look like a real plane.  I decided on one of the kit options, Saburo Shindo's AI-102 from the second wave of the attack at Pearl Harbor.  My research revealed he was the leader of 9 Akagi zeros and was tasked with dive bomber escort (Vals).  After the escort, they attacked airfields which included two planes destroyed on the ground at Hickam Field.  There is little information on Shindo but he apparently survived the war.
All Pearl Harbor Zeros were made by Mitsubishi and Nakajima didn't start helping out with them until early 1942. Both manufactures differed in painting technique.  I sought to do this correctly with the help of the J-aircraft site.  I started with AK Real Colors Mitsubishi Interior Green.  It's quite similar to US interior green to my eye.  The Hasegawa pit is average but acceptable.  It doesn't hold a candle toTamiya's though.  I did add an Ultracast seat I had in the stash to spruce it up.
The airframe went together fine. I did add brass tubing for the guns, including the wing cannons.
Typical Hasegawa wing fuselage joint issues.  This area needed some work.
I normally use Tamiya XF-76 for the grey green early zero color, but this time I wanted to try the AK Real Colors offering of this elusive color.  They call it IJN J3 SP Amber Grey.  I faded it a bit but nothing crazy.  I used some spare Montex masks for the meatballs.  I also painted on the stripes and wing warnings. I'm pretty happy with the AK color.
I did rig up the engine with fine solder.
Thats about it.  I used a grey green Mig wash which served a filter which gave it a slightly used look.  I'm pretty happy with the results.  Maybe Tamiya will eventually give us a new Model 21, it shouldn't be difficult from their A6M3 kit. My Pearl P-40 should be finished soon and I wll post that one as well.
From my research, this is the correct way to paint the gear bays on a Mitsubishi built zero.
    January 2021
Posted by fuzznoggin on Saturday, April 17, 2021 6:37 AM
Fantastic build and diorama!  Kudos Yes
    November 2003
Posted by tempestjohnny on Saturday, April 17, 2021 6:45 AM
Great build Joe. Weathered but not weatherbeaten
    February 2012
Posted by lawdog114 on Saturday, April 17, 2021 3:52 PM
fuzznoggin
Thank you! It's just a simple Verlinden cardboard base. Nothing fancy.
    February 2012
tempestjohnny
Thanks Johnny
Posted by keavdog on Saturday, April 17, 2021 7:42 PM
Well done sir.  I just put the Tamiya kit on the bench.  The figure is a great addition.
Thanks,
John
Posted by jeaton01 on Saturday, April 17, 2021 10:15 PM
Another one well done, Joe!  Sweet.
John
    February 2012
Posted by lawdog114 on Saturday, April 17, 2021 10:19 PM
keavdog
Thanks! If it's one of their newer zero kits your going to love it.
    February 2012
Posted by lawdog114 on Saturday, April 17, 2021 10:20 PM
jeaton01
Thank you
    July 2019
Posted by Hoss WA on Sunday, April 18, 2021 8:44 PM
Fantastic lawdog. Love the finish. I'm going to have to try a Type 21 at some point. Congrats. I also just started the Airfix P-40B but I'm doing the Flying Tigers markings. Looking forward to your Pearl Harbor version.
    June 2017
Posted by UnwaryPaladin on Monday, April 19, 2021 5:57 AM
Fantastic! Always enjoy seeing your work.
Joe
    February 2012
Posted by lawdog114 on Monday, April 19, 2021 10:14 PM
Hoss WA
Thanks Hoss. Good kit overall.  watch out for the cowl panels fit and the gear knuckles don't fit that great.   I should have it done here shortly.
    February 2012
UnwaryPaladin
Joe
Thank you!
    May 2004
Posted by cbaltrin on Tuesday, April 20, 2021 3:27 PM
Great looking build. Real nice cockpit work you did there!
On the Bench: Too Much
    February 2012
Posted by lawdog114 on Wednesday, April 21, 2021 5:18 AM
cbaltrin
Thank you,.
    January 2015
Posted by Aggieman on Wednesday, April 21, 2021 6:47 AM
You've turned in another build with your Zero.
    February 2012
Posted by lawdog114 on Thursday, April 22, 2021 9:57 PM
Aggieman
Thank you
    July 2004
Posted by stikpusher on Thursday, April 22, 2021 11:53 PM
Not much more that I can add except for another "well done" on this one. Your Zero turned out very sharp!
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    February 2012
Posted by lawdog114 on Friday, April 23, 2021 3:40 AM
stikpusher
Thanks Stik!
    November 2008
Posted by plasticjunkie on Friday, April 23, 2021 8:01 AM
Outstanding work a set usual LD. Great looking base too.
 GIFMaker.org_jy_Ayj_O
    February 2012
Posted by lawdog114 on Friday, April 23, 2021 4:41 PM
plasticjunkie
Thanks PJ
